Question about Maytag SkyBox MBV1976A Beverage Dispenser
Maytag skybox. I installed hard start correctly... Not hearing any noises or feeling any warmth. I checked continuity and I'm not getting any readings. What's the problem
  • 221 Answers
You need to be more specific about where you are taking readings.
Posted on Mar 01, 2015
SparkGap
  • 363 Answers
SOURCE: Maytag skybox not cooling
Sounds like the refrigerant gas has leaked out. Any reputable refrigeration engineer can fix this.
Posted on Sep 30, 2007
watugot
  • 290 Answers
SOURCE: maytag skybox cooling
Is it cooling at all? Do you hear the compressor start or just a buzz for a few seconds? This sounds like a compressor or compressor start relay failure. Unplug the machine. Access the compressor and remove the relay that is plugged to the side of it. Shake it and see if it sounds like there are a lot of loose pieces in it. Inspect it for burned spots. If you find either one of these, it is bad. If it doesn't rattle or appear burned then the compressor is probably bad. Even if it seems ok, I would try a new one on it anyway. They aren't usually very expensive. If the relay is not the problem, check your owners manual for the warranty info. The compressor may still be covered by warranty even if the rest of the unit is out of warranty.
Posted on Oct 10, 2007
SOURCE: maytag skybox schematic
there is a basic schematic on the back of the unit
Posted on Apr 30, 2008
  • 90 Answers
SOURCE: Maytag skybox start relay is bad
you need to change the overload relay ---- there is a company called appliancezone.com
they sell the overload relay unit with all the parts for $26.00
email me back if you cant find it---- put in the model # for the skybox unit and you will see the item
item # 4387835
this is the problem -- if this relay goes bad the compressor will stay on and not supply cold air to the unit ----
Posted on Dec 30, 2008
SOURCE: Maytag SkyBox
For the soda name tags, I pulled logos off the internet and printed them the correct size on 20-pound paper. Different paper gives different translucence, so you might have to experiment to get the right amount of light coming through.
PS: thanks for the part no. on the relay
Posted on Feb 15, 2009
I do not have a skybox problem ... I was looking at Starter relay information and skybox guy posted starter relay info ... I decided to pay for help ... Frigidaire Gallery side by side DFRS26ZSHB2 ... no...
If it's not cooling and the internal lights and fan are working, then the problem is either the start relay or the overload relay. I checked the model number you posted and I didn't get any information for the number. Please double check the number that is posted inside the unit. In the mean time, take a look at this relay kit. It is a combination start relay, run capacitor and overload relay all in one. Usually the start relay will run you around $25.00 alone so this is what I use to repair this type of problem at a fraction of the cost. Again, please check that model number again and I will get you the pricing for the individual parts. It is best to replace all the relays if one goes out.Here is a link to the ERP410 relay kit.
Regards,Richard
Dec 09, 2011 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag skybox stopped cooling Skybox stopped cooling. Sounds like the relay will kick on briefly and then click off. Everything else works. I took the back panel off and could hear the relay clicking on...
The relay on your box is damaged.. You have to get it replaced.. Not to be tried by a novice but if you have some experience in electronics it can be fixed by you. The relay costs around 75$. Good luck!
Mar 26, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
The maytag skybox doesn't get cold anymore. we had it outside for a while (we didn't realize you couldn't have it outside) & it worked great all last summer. this spring, we realized it...
First you need to find out if the compressor is kicking on or not. If it isn't then it could be the starting capacitor (item 23), start relay (item 7) or the compressor itself. Since you had it outside I would suspect the capacitor or relay. http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Refrigerator-Parts/Model-MBV1976AAB/3048/0168000/M0510224/00001
Does the skybox make noise (like your refrigerator starting a cycle)? If not, I would unplug it for a short while and let it set. Then when you plug it back up listen for noises on whether the compressor kicks on or not. If it doesn't then you can check the cap and relay board. Or have your compressor checked for operation and freon.
Jun 21, 2011 | Maytag SkyBox MBV1976A Beverage Dispenser
It does not continuously run and it is not cold
These units are not repairable.(per Maytag) The entire unit must be replaced.(per Maytag)
May 26, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Hi my skybox stop cooling
The SkyBox operates with two individual systems. The dispenser assembly, the LED indicators and the circulating fan operate on a low voltage circuit. The circulating fan runs anytime the SkyBox is plugged in.
The cooling system operates on 120vac. The cold control inside the beverage compartment is an on demand switch that sends 120vac to the compressor when cooling is needed. There are no parts available for the compressor, so if it determined that power is reaching the compressor, the windings are ok, a 3 in1 hard start kit (Supco URCO210) can be installed by a qualified service technician.
Mar 16, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag Skybox
good to hear another skybox lives...thanks for the kind words. alex
Dec 10, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox by Maytag not cooling
our skybox just stopped cooling. i think the compressor kicks on but wont cool. can somebody please help me! thanks barbie
Jul 01, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
MBV1976AAP
Maytag did not offer any parts for the compressor on the SkyBox. Purchase a SUPCO URCO410 relay/overload/capacitor kit and install it per the instructions on the package.
May 02, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag SkyBox
Apr 21, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag skybox cooling
Oct 10, 2007 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag SkyBox MBV1976A Beverage Dispenser Logo
Top Maytag Retail Supplies Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Maytag Retail Supply Expert? Answer questions, earn points and help others
