Question about Dryers
My heating coil doesnt work - Dryers
    Problem Solver:
  • 7 Answers
You should call a professional.
Posted on Nov 07, 2014
Samsung DV220AEW/XAA
the heating coils have sensors that will interrupt the power going to the coils which create heat, take a meter and test voltage to each wire on the sensors, if one side of the sensor has voltage and the other doesnt the sensor is bad, replace it or pull the wires off and jump them or tie them together to see if it works, but you will burn your house down if you dont use the sensor, so get it replaced asap
Dec 31, 2012 | Samsung Dryers
Heater doesnt work at all doesnt blow heat in the car floor board wet on drivers side.
your heating coil is bad ,is right underneath dashboard good luck
Feb 17, 2011 | 1995 Oldsmobile Aurora
HEATER COIL DOESNT WORK
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Jan 25, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Dryer works but doesnt get hot to dry clothes
there is only 1 reason as to the unit still running but not heating if its running then all thermos must be intact so it has to be the heating coil take the unit appart make sure the two heating points still have the cables attached if you can do a polarity test on the element that will define its blown then replace the coil in most cases when the coil blows you can see a burn mark were it did
best luck
Dec 02, 2010 | Roper REX4634KQ Electric Dryer
My dryer runs but doesnt dry.. Seems not to be heating
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Sounds like your problem may be with the heating coil. Remove the back of the machine and try to locate the air duct going from the blower to the drum. Normally inside the air duct you will find the heating coil and the thermostats/thermistor. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape. If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Please rate me
Aug 18, 2010 | Dryers
My kenmore elite electric dryer inconsistantly starts to heat and
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jul 27, 2010 | Kenmore 63942 Dryer
We have a GE gas oven/stove top and the stove top is lighting as well as the broiler but we can not get the oven to heat up. What do you suggest we try?
i just moved and our stove in the new place doesnt bake things right. it seems that the top coil doesnt come on. its very difficult to bake anything. seems to come up to temp for pre heating, but only the bottom coil comes on. If you put it on broil, then the top coil gets hot. that works fine. tired of burning pizzas and biscuits. can anyone help with a cheap fix? dont have alot of cash.
Nov 12, 2009 | GE Ovens
My dryer doesnt dry. I believe it is the heating element. only cold air is coming out
To replace coil, unplug and take off the back. Might have to remove heat shroud to get at coil. Remove and replace. You might have bad contacts on relay switch so play with them first and plug it back in to try it. If it doesn't work then do first step
Jun 29, 2009 | Amana DLE330RAW Electric Dryer
No heat
It will initialy take some time to heat, but if it doesnt become hot in 3min or so.. then make sure voltage is properly fed and also check for any switches or reset button. If all this doesnt work then it means the heating coil inside wud have been cut or fused.
Thankyou
Feb 10, 2008 | Waring WMK300 Professional Belgian Waffle...
Dryer lights, heats up some but wont relite
Replace the coil packs on the gas valve this fixes 90% of gas dryers lighting intermittently. The bracket comes off and they are sold seperately from any appliance parts retailer.
This worked for my dryer.
Feb 06, 2008 | Whirlpool LGR5634L Gas Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
