Question about Cameras
When I turn my camera on it says card error - Cameras
  • kakima Nov 07, 2014
    What make and model camera? What type and size memory card?
    Master:
  • Cameras Master
  • 442 Answers
Usually that indicates either a bad card or a card that needs to be reformatted. Use a card reader to reformat the card in your computer and then try it in the camera. If it recognizes the card in the camera then use the camera to format the card again to its requirements. If that fails, try a different memory card.
Posted on Nov 07, 2014
When I turn on my digital camera the lens opens and closes and then the screen appears and says system error and shuts off compleatly what do I do?
Remove any storage cards that may be in the camera, replace the batteries (or put on charger if not replaceable). Try to turn the camera on, if you still get the error, contact Sanyo for help in trying a master reset for the camera. If the error resolves itself, turn it off, put the storage card back in. If the error appears again, then you have a problem with the storage card. Replace the storage card with a different one, and see if error resolves.
Aug 17, 2010 | Sanyo Cameras
Sound on the zoomlens and writing error # 45
To remove the error, follow the instruction.
1) Turn OFF the camera.
2) Remove the memory card from your camera.
3) Reinsert the memory card, then push down on the card until you hear a click. check the memory card is firmly fitted in your camera.
4) Turn on your camera.
This will clear the error. For noise install a fully charged battery or new battery in your camera.
Rating the solution in highly appreciated.. Good Luck
Mar 02, 2010 | Kodak EasyShare Z700 Digital Camera
When i turn the camera on it says memory ard error
If camera show Memory Card Error, Check whether the card is inserted properly or not. For SD card, check out the card lock switch is in the correct position and not stuck in between.
You can Format the memory card in the camera using the Setup Menu option (Format). Please be aware that formatting the memory card will remove any images currently stored on the card along with any other data.
If after formatting the card do not clear the error, try another memory card. If this occurs with only the one card it is likely that the memory card is defective, if the error persists over more than one card the camera may require service.
Rating the solution is highly appriciated...Good Luck
Mar 01, 2010 | Optics
Error on formating new memory card in camera error says memory card is full brand new card i tried 2 in faact same error kodak c310
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
Feb 08, 2010 | Kodak Easyshare C813 Digital Camera
When i turn my camera on it says memory card error
You probably need to format the card in the camera. This will erase all the pictures so download them first.
Sep 18, 2009 | Cameras
Memory card error
You need to format the card in the camera before it will work properly.
Aug 12, 2009 | Leica D-lux 3 Digital Camera
Memory card error with new memory card
Hi there, welcome to FixYa.
Let's work on the camera first.
1) Turn the camera off and remove the battery and the card.
2) Put the battery back in without the card and turn it on.
3) Turn the camera off and insert the CF card.
4) Turn the camera back on again.
See if that takes the message away.
If it doesn't leave me a comment and we go to step 2.
If it does, thanks for coming to FixYa.
Rob
Mar 14, 2009 | Canon PowerShot A75 Digital Camera
Samsung nv3 sd 'card error ! ' message
my camera say card error, can u help?
Apr 04, 2008 | Samsung NV3 Digital Camera
MEMORY CARD ERROR
I will give you the steps that you can isolate whether memory card or the reader has malfunction. check the memory card with external card reader by connecting to computer if card really bad it will alert either error or unformatted (make sure write protection of the card is off if exist). When you format in computer successfully it can work in camera too. If issue persist in camera side you can try another card and next step will be hardware repair of camera reader. hope it will help.
Good Luck
Jan 01, 2008 | Olympus Camedia D-390 Digital Camera
The camera screen displays error message
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card. CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card.
Aug 29, 2005 | Kodak EasyShare One Digital Camera
Cameras Logo
27 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
