Question about Vizio 42 in. LCD TV
Hi. I have a M420NV everything works but no sound
Have tried every thing out the book also the advice of the side knop . Nothing.
    Problem Solver:
  • 6 Answers
Please specify what source you are trying to connect to the TV, and what method of connection you are using (HDMI, Component Video, or Composite-RCA).
Posted on Nov 26, 2014
Hi,my powersteering pump is making a whining sound so i changed it with a new one and i was doing everything by book but stil the same problem, can somebody give advice? Polo classic 16i 98model
at www.reliable-store.com info that cover everything from wiring diagrams, electrical diag, fault/error codes, troubleshooting, service/repair/operation/maintenance info, PCV, etc.
that'll be all you need, without doubt.
Apr 11, 2018 | Cars & Trucks
Hi,my powersteering pump is making a whining sound so i changed it with a new one and ,i was doing everything by book but stil the same problem, can somebody give advice? Polo classic 16i 98model
Wel the Vizio Tv lost Sound.
Check whether the audio is muted by accidently. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Nov 07, 2014 | Vizio m420nv 42 in. LCD HDTV
M420NV
Check and replace back-light inverter board. Check the input supply voltage to back-light inverter board. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact any experienced service technician, or the nearest service center.
Apr 23, 2013 | Vizio Televison & Video
Vizio m420nv has sound but no picture
Hello there
Actually that problem is very common on all LCD TV,, that problem is cause of either inverter board or t-con..
In this case you don't need to check the voltage that is too complicated for you,,only visual check is enough..
I share you my tricks and hope it helps..
Power on your TV turn off your lights..if you will see the light comes from the screen the problem is t-con..if no light the problem is inverter board (backlight) board
Hope it helps..
Don't forget to rate..
Aug 25, 2012 | Vizio m420nv 42 in. LCD HDTV
I just purchased a brand new M420nv 42 HDTV LCD LED and turned it on for the first time & the screen was white with blue vertical lines (very similar to a UPC bar code) on the left side of the screen. ...
For sure a defect. You are looking at a T-con board that is faulty. Return immediately and get a different one. If it's within 30 days just swap out and avoid having to wait for a warranty repair!
Please rate if this helped :)
Mar 09, 2011 | Vizio m420nv 42 in. LCD HDTV
Everything works except the cooking part/no heating/turntable not turning, help!
hi there,
can you provide the brand and model # off your microwave please?
thanks
Sep 03, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Zooming in.
Your camera jumped out of gear. Open the front metal cover and disassemble all arm working with the main motor gear and try to reposition the red dot on the big gear with the small gear side by side. Presto now your camera is aligned. Place all arms back in order to your new alignment.you got your self a working camera. D: 3403 3404 mean error = some thing is block your lense and stopping the motored gear. For future referance don't drop the camera agian, next time it might be a expensive fix next time around.
Apr 26, 2008 | Olympus ? Stylus 500 Digital Camera
Broken knop
sounds like you got milked buy another
Jan 04, 2008 | Presto HeatDish Compact Heater
PANASONIC KX-A144EXS
druk middelste knop ,nr verschijnt !
druk ronde knop rechts,
druk ronde knop naar beneden tot WISSEN verchijnt en druk dan ronde knop rechts en kl is kees
Sep 06, 2007 | Panasonic KX-T7730 Corded Phone
Open Questions:
See all Vizio 42 in. LCD TV Questions
Vizio 42 in. LCD TV Logo
60 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
