Question about Kodak EasyShare V1003 Digital Camera
My camera (Kodak EasyShare v1003) will not take picture even if the battery is fully charged,when i turn on the the power, the red light on the upper left corner always blink...please help me fix this
The flash is not working and it will not take picture
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 5 Answers
Go to menu->setting->flash->select turn on flash->ok
Posted on Nov 15, 2014
SOURCE: Kodak Z700 not firing up
Same problem as described above. Fresh batteries, turn it on, see the Kodak screen for a second, then it just turns off. I found that if you swith it to the favorites icon (the only one below the Off position) it stays on and I can review photos. But no taking new photos! Help!!!
Posted on Jun 02, 2009
leepania
  • 1099 Answers
SOURCE: My kodak easyshare V1003 camera will not turn on.
1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 4. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Dec 09, 2009
  • 44 Answers
SOURCE: Kodak Easyshare Z760 orange light flashing
The flash does not charge separate from the rest of the camera. Try cleaning the flash sensor on the front of the camera or the flash led may be bad.
Secondly, this light functions as a flash sensor which is trying to tell you that you need to use a flash although you may have the flash manually turned off. looks like a bolt of lightning with a circle/slash through it.
Posted on Mar 15, 2010
  • 33 Answers
SOURCE: my camera wont charge
have you check the charger? or is there a power on the outlet? try to charge it from different power source
Posted on May 25, 2010
SOURCE: My Kodak EasyShare M340 turns on, but then shuts off immediately.
omg! thank you so much Stephan you are th best i just bought the camera for Christmas. Went to the beach yesterday and it sttopped working the method with holding the lens and moving it around i saw some sand come out now it works!!!!!! :-D
Posted on Jun 06, 2010
I just set the date stamp in the on position. Then, turned the camera off as I didn't need to take a picture. Now, when I turn it on, the lense comes out and then immediately goes back in flush and the...
How long have you owned the camera? If under a year then I would recommend having it serviced by kodak under warranty. If it's over a year old you may want to try a new battery otherwise consider replacement.
Thank you,
Lee
Jun 13, 2010 | Kodak EasyShare V1003 Digital Camera
My camera wont charge
May 25, 2010 | Kodak EasyShare V1003 Digital Camera
My Sony VSC 1 camera is not turning on!!!! The charge went out and the camera turned off. After that it's not turning on. What do I do?
1. Please make sure that you're using the fully charged battery.
2. Try resetting the Camera. To reset the Camera, remove the battery from the Camera, press and hold the Power button for 30 seconds and then, reinsert the battery.
3. Please make sure that you're using the compatible battery with the Camera.
4. You may also try using a different battery to check whether the issue is with the battery.
Feb 17, 2010 | Kodak EasyShare V1003 Digital Camera
Will not turn on
Here are the steps for your V1003 no power problems: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Feb 04, 2010 | Kodak EasyShare V1003 Digital Camera
My kodak easyshare V1003 camera will not turn on. It worked a few days ago and now it will not charge or turn on. I just bought new batteries and it still will not turn on. Any suggestions on how to fix...
Dec 09, 2009 | Kodak EasyShare V1003 Digital Camera
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Easy Share V1003 Turns on, then shuts down.
Make sure that you are installing a fresh/ full charge battery
Remove the memory card and the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
Aug 23, 2009 | Kodak EasyShare V1003 Digital Camera
My camera will not turn on and the battery is fully charged
take out the battery and plug in your ac charger then turn on the camera, if if the camera turns on, try to clean the contact point of the battery if that doesn't work maybe there's a problem with your camera...
Aug 14, 2009 | Kodak EasyShare V1003 Digital Camera
V1003 cannot hold a charge!
your camera might require a new main board to solve this issue. repairs can run from 80.00 and up. goto digitalcamrepair.com for more help.
Nov 17, 2008 | Kodak EasyShare V1003 Digital Camera
White Sreen
unfortunately it would appear to be a CCD or main board failure.
If the camera is out of warranty (as this should be covered) my best suggestion is to pick up one off ebay with a broken screen and put your screen in it, broken screens are common on these cameras so they go quite cheaply, far cheaper than kodak would charge for repair and the swap is easy.
There are several searchs to try "parts v1003" "spares v1003" "Faulty v1003" "repair v1003"
Best of luck
May 26, 2008 | Kodak EasyShare C513 Digital Camera
Kodak EasyShare V1003 Digital Camera Logo
75 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
