Question about Maytag Washing Machines
Lights on panel flash, will not go into diagnostic mode
lights on panel flash, will not go into diagnostic mode
    Top Expert:
  • Maytag Master
  • 9,472 Answers
What is the model number?
Posted on Nov 26, 2014
Electrical issue.
Access ECM on the data link connector . Turn ignition switch on(do not start). Turn diagnostic mode selector on ECM fully clockwise. Wait at least 2 seconds. Turn diagnostic mode selector on ECM fully counter clockwise . Self diagnosis in mode 2 Mil should flash. If the scan tool record s codes or the mil light will flash the codes
Feb 18, 2014 | 1997 Nissan Maxima
Hello I have a 1994 maxima manual transmision,it have a check engine light on,when I start the car and beguin to drive it,runs perfect the a few minutes later the car gets very lazy almost want to turn...
Hello! I'll need the trouble code to fix your vehicle...Below is procedure with a code list...Guru...saailer
Remove the trim panels in front of the center console. Locate the engine computer attached to a floor-mounted bracket on the transmission tunnel between the console and the firewall.
  • Turn the diagnostic mode selector, located in a round opening on the side of the engine computer, until it stops. Observe the small red and green LED lights on the side of the computer next to the mode selector. They will flash to indicate the modes, with a pause between each mode. One quick flash is mode one, two quick flashes is mode two and so on. When the light flashes indicate mode three, quickly turn the mode selector counterclockwise until it stops. You have entered mode three diagnostics.
  • Remove the trim panels in front of the center console. Locate the engine computer attached to a floor-mounted bracket on the transmission tunnel between the console and the firewall.
  • Turn the diagnostic mode selector, located in a round opening on the side of the engine computer, until it stops. Observe the small red and green LED lights on the side of the computer next to the mode selector. They will flash to indicate the modes, with a pause between each mode. One quick flash is mode one, two quick flashes is mode two and so on. When the light flashes indicate mode three, quickly turn the mode selector counterclockwise until it stops. You have entered mode three diagnostics.Observe the red and green LED lights on the side of the computer. The red light flashes to indicate the "Tens" digit of the code and the green light flashes to indicate the "Ones" digit of the code. For example, if the red light flashes two times and the green light flashes seven times, this would indicate code 27.
    Turn the ignition key off for two minutes to exit diagnostics. The computer will automatically return to mode one for normal operation...
    Code 11 Crank sensor angle
    Code 12 Mass airflow sensor
    Code 13 Engine coolant temperature sensor
    Code 14 Vehicle speed sensor
    Code 21 No ignition reference
    Code 22 Fuel pump
    Code 31 Engine control unit
    Code 32 EGR sensor
    Code 33 Oxygen sensor
    Code 34 Knock sensor
    Code 35 EGR temperature sensor
    Code 43 Throttle position sensor
    Code 45 Injector leak
    Code 51 Injector circuit
    Code 54 Automatic transmission signal
    Code 55 No malfunction recorded
    May 04, 2012 | 1994 Nissan Maxima
    HOW DO I FORCE A HOTPOINT SIDE BY SIDE REFRIGERATOR (HSS25GFTA) WITH AN ADAPTIVE DEFROST TIMER INTO DEFROST MODE?
    Start a diagnotsics mode and enter test code 1 - 4 of the diagnostics to start the defrost mode
    Self Diagnostics
    To enter Self Diagnostic mode, both temperature control panel displays must be illuminated. A display can be illuminated by pressing an adjacent temperature adjustment button. When both displays are illuminated, set the freezer and refrigerator temperature settings to 5. Simultaneously press and hold all
    4 temperature adjustment buttons for approximately 3 seconds. A flashing 0 in the refrigerator and freezer displays will indicate that the refrigerator is in Self Diagnostic mode.
    To perform a self diagnostic test, locate the test in Table 2, Diagnostic Tests.
    For temperature control panels with single-digit displays, the COLDER temperature adjustment button will increment the numbers up and the WARMER temperature adjustment button will increment the numbers down. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in
    the refrigerator display. When a test code has been entered, the displays will flash to confirm the test.
    Press the HOLD button for 3 seconds to begin the test.
    For temperature control panels with 3-digit displays, the COLDER temperature adjustment button will increment the numbers down and the WARMER temperature adjustment button will increment the numbers up. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in
    the refrigerator display. When a test code has been entered, the displays will flash to confirm the test code. Press any button other than a temperature adjust button to begin the test.
    When testing has been completed, do one of the following things:
    • Enter code 1 5 to completely reset the system.
    • Enter code 1 6 to exit diagnostic mode. The temperature control panel is reset automatically.
    • Unplug the refrigerator for at least 10 seconds. Test mode will terminate when the refrigerator is plugged back in.
    Test mode will terminate automatically after 15 minutes of inactivity.
    (or in your case.... after the deforst cycle completes and possibly + 15 minutes)
    Thanks for choosing FixYa,
    Kelly
    Aug 23, 2011 | Refrigerators
    I have a 1998 Plymouth voyager and the climate control lights are flashing. I ran a test i found on the internet and got it down to two lights flashing(the ac and the recirculate). I got it to where the...
    OK got your message on the other post (About the van) I am assuming that your Voyager is equipped with Automatic Climate Control. Follow the instructions below and you will get a better idea of what is wrong with your system.
    Calibration/Diagnostics
    1. To enter calibration/diagnostics test, set parking brake. Start and warm engine to normal operating temperature. With engine idling, turn blower switch to high. Turn mode switch to panel. Open all outlets. Move temperature to full cold.
    2. Press and hold rear wash and rear wiper buttons simultaneously for 5 seconds (Until ALL LEDs illuminate). All LEDs should illuminate for 5 seconds. Rear wiper and intermittent rear wiper button LEDs will flash alternately during calibration/diagnostics test.
    3. After approximately 60 seconds, if only the rear wiper button LED is flashing, calibration is successful and the system is okay. If rear wiper and intermittent rear wiper button LEDs are flashing, Diagnostic Trouble Codes (DTCs) are present. (See "Reading Diagnostic Codes" below)
    4. To exit calibration/diagnostics test at any time, press the rear window defogger button, rear wiper button, or cycle the ignition off and then on. Test will automatically terminate 15 minutes after calibration/diagnostics is entered.
    1. Perform calibration/diagnostics test. If a DTC is present after calibration/diagnostics test has been performed, system will flash rear wiper and intermittent rear wiper button LEDs in sequence. Rear wiper represents code level, and intermittent rear wiper button LED represents code value.
    2. Each time the rear wash button is depressed, rear wiper button LED wil cycle to the next code level in numeric sequence. After code level 5 is reached, rear wiper button LED will cycle back to code level 1. See table below.
    May 12, 2011 | Plymouth Voyager Cars & Trucks
    Heat blows cold air
    The LH models (LHS, Concorde, New Yorker, Intrepid, Vision) do have self-diagnostic capability with the standard type heater controls. I don't know about the Sebring heater controls (my '95 manual doesn't mention it) but if you have the various controlknobs/buttons that I will describe you could give it a try.
    There is a rear window defogger that is initiated by a push button with an LED light. That light is the readout, by its blinking. To begin the diagnostic mode, run the vehicle at idle with the controls set as follows: the blower speed knob should be on any position other than OFF, the temperature knob should be set in full COOL, and the mode knob should be set on Defrost mode.
    To enter the diagnostic mode, press the defogger switch in for five seconds, until it begins to blink, then release it. It will continue to blink for about 30 seconds while it calibrates. If it goes out, the calibration is OK and you can skip 3 paragraphs to "Position...mix mode" below.
    If the light stayed on, switch the mode knob to the MIX (defroster-floor) position. If the light stays on there is a problem with the control head unit.
    Switch the mode knob to the FLOOR position, if the light stays on, it indicates a problem in the blend door or the blend door actuator wiring.
    Move the knob to the Bi-level (panel-floor) position where a continuous light indicates a problem with mode actuator or circuit.
    Position the knob in the MIX mode. The LED light should now flash twice then pause, and continue a two-flash sequence, indicating that the MIX mode is OK.
    In the FLOOR mode the light should flash three times, meaning that the FLOOR mode is OK.
    In the Bi-Level Mode, a four-flash sequence indicates that mode is OK.
    In the PANEL mode the light should flash 5 times to indicate no problems there, and in the recirc-panel mode 6 times and seven times in the recirc Bi-level mode.
    The temperature control can be checked by switching the mode knob to Defrost and rotating the temperture knob. If the temperature contol is OK, the light will flash faster the more you turn the temperature knob up, until the light goes out at the hottest setting.
    Switch the knob between Panel and Recirc-Panel and watch the recirc door (unit under the dash). Proper operation means that circuit and components are OK.
    To get out of the self-diagnostic mode, turn off the blower or push the air conditioning button once.
    If this doesn't seem to apply to your control head or you get no response from an LED light for the rear defroster, then the Sebring may not have this capability. Please let me know your results if any
    Dec 02, 2010 | 2001 Chrysler Sebring
    Unit will not run. cannot enter diagnostic mode.
    i would say that you have a bad touch panel..99 percent positive
    May 10, 2010 | Dishwashers
    Blinking panel button lights
    That has to do with your computer for your body controls, such a/c, heater, wipers, etc...
    Most common problem is drinks spilling into the computer which is right between the cup holder. It will eventually cause a problem with a/c most likely.
    Jun 24, 2009 | 1998 Dodge Caravan
    GU1200xtks0 Blinking Lights
    Try pressing heated dry, normal, heated dry, normal keys within 6 seconds. All lights should come on and the machine should enter diagnostic mode. If this does not work remove the 2 screws that hold the toe panel on at the bottom front of the dishwasher, attached inside you will find a tech sheet that tells you how to enter the diagnostic mode. Once you get it in diagnostic mode let it do it's thing, will take about 20 minutes total. At the end the control will be reset. If the fault comes back then troubleshoot according to the tech sheet, or call for service.
    Feb 20, 2009 | Whirlpool 24 in. GU1200XT Built-in...
    Guessing it is stuck in diagnstic mode 1998 dodge gr. caravan 3.3
    there is a module that needs reprogrammed,this happens all the time
    Feb 03, 2009 | 1998 Dodge Grand Caravan
    Kenmore Oasis Elite---110-27086601
    This error only shows in diagnostic mode, with power off choose any buttons except stop and power, press in intervals 5 seconds on and 5 seconds off until 88 appears and all light light up. If the user panel is faulted F 2 will flash in the display, press the same button you used to start diagnostics to jump to the next error code and once through 88 will flash and diagnostics will start. Sometimes once F2 flashes and the machine has not been repaired it will stick at that mode.
    Aug 07, 2008 | Kenmore Oasis HE 27082 Top Load Washer
    Washing Machines Logo
    Top Maytag Washing Machines Experts
    Bill Long
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
