Question about Plumbing
Barclay 4073-PL Diverter Bathcock Tub: Thoughts on why the water pressure is low on the hot spigot but not on the cold, and not on any other faucet in the house?
Has been operating just great until recently when hot water pressure seems stunted. Not so on other faucets so my thought is something is being affected in the tub faucet. I removed the stubborn side and rinsed it out, but still not flowing properly.
    Master:
  • 560 Answers
Debris can get into the shower body/cartridge. Pull out the cartridge and flush the shower body and clean out the cartridge. Sometimes you need to replace the cartridge.
Posted on Dec 28, 2014
arealplumber
  • 33 Answers
SOURCE: low pressure and flow on hot water side of single handle faucet
It could be one of two problems, one simple, one serious.
  • Easy fix
  1. Turn off hot water angle stop under sink to faucet.
  2. Remove supply line from hot angle stop.
  3. Place end of supply line in a small bucket to catch some water.
  4. Turn on cold water for a couple of seconds and backflush debris from faucet.
  5. Reconnect supply line.
  6. Turn on angle stop and test
  • Complex fix
If you have steel pipes you may be experiencing reduced flow due to corrosion in your pipes. Reduced hot water pressure in the kitchen faucet is usually the first sign since this is the faucet that is most used in the home.
Repiping is a job for a professional. Another symptom you may need a repipe is orange colored or rusty water.
Posted on Dec 05, 2008
  • 10865 Answers
SOURCE: Greetings! My Kohler kitchen faucet
Begin by shutting off the water to the faucet. Then, on the back of the handle you will find a small button. remove it with a small knife blade and underneath you will see a 1/8" set screw. Use a 1/8" inch allen wrench to remove the set screw. You can then unscrew the bonnet and remove the diverter. Take the diverter to a hardware store or plumbing supply to purchase the appropriate repair kit. goodluck.
Posted on Jan 21, 2009
  • 374 Answers
SOURCE: moen roman tub faucet on hot water side stops
If this occurs after you were able to get hot water to flow from the hot side then I suspect that it is a piece of debriis that has found its way to block the port opening. Remove the acess panel to the valve shut the water supply off to the tub valve using the handles only first on the valve. With the access panel removed tak e a bucket or other similar container and remove the hot water tubing from the spout. Once that is accomplished stick the tube into the container and turn the hot lever on. This should blow out any debris that may exist. Reassemble the valvle. If this did not work remove both the cold and hot feed tubes from the spout and use an air compressor to blow the spout out. If neither of these worked you will probably need to call a serviceman to resolve as other options require cutting the hot supply to the handle and may require special tools that you may not have handy. Thanks for using Fix Ya.
Posted on Mar 11, 2009
  • 11 Answers
SOURCE: faucet issue
Sounds like it was installed upside down or the cartridge is installed improperly
Posted on May 07, 2009
  • 23 Answers
SOURCE: Leaking valves in new roman tub faucet installation
take the valves out and check the valve seats use flashlight if they look good then very carefully put your finger in and feel for any burrs when in doubt just replace the seats this is always a good practice when replacing valves
Posted on May 12, 2009
Hello. We have a Moen two handle tub/shower faucet. A little over a year ago it started to make a high pitched noise when on. Now the water flow to both the tub and shower are greatly reduced for BOTH...
sounds like the diverter inside the valve body is cloged with debris.
only wat to remedy this is to remove the valve and clean out the diverter, or just replace the valve.
Aug 05, 2010 | Moen 2919 Chateau Two Handle Tub and...
Leaky Tub Faucet (Antique Reproduction)
sometimes check the faucet screws they come loose or if they are old you might want to replace the whole diverter, take them to lowes or home depot and have them guys in the plumbing department hook you up. trust me you are opening a can of worms with rubber valve seats just get new ones. Make sure before pulling you cut off water supply to them.
Jul 20, 2010 | Home
Low hot water pressure on newly installed kitchen faucet
it souns like a factory flaw in the piping or whoever hooked it up, over bent or kinked the line
Aug 31, 2009 | Plumbing
We began replaceing our galvanized pipes. Since
The problem is that when you disturb the galv. pipes, the gunk inside breaks loose, and travels to the faucets, gets stuck, and limits the volume of water that comes out.
If possible open the lines at the service valves, and force water through the spigot to fluch out the faucet. The service value could also be partially clogged, keep that in mind
Aug 05, 2009 | Plumbing
Just installed a Barclay 4000 clawfoot tub conversion to replace old broken one. The tub fill works fine but water won't flow to the shower just a dribble. We bought it online in the original packing. I...
Try unscrewing the shower head and remove the little black water saver in the rear but while you have it off turn on water just to make sure water makes it up to the shower head with pressure
Jul 09, 2009 | Barclay Plumbing
Water sprays out the diverter
Remove hot/cold button in handle, remove screw/pull off handle. Remove the two screws in the wall plate/remove plate. Use a wrench to remove the diverter assembly. Get new diverter assy and reinstall eveything. You don't need to turn off the water.
Jun 09, 2009 | Delta Faucet #RP320 Divert Assembly
Faucet issue
May 06, 2009 | Kohler K-T10335-4-CP Lyntier Rite-temp...
My 3 handle bathtub fauset [price pfisher] cycles hot and cold
You will need to either replace center "shower diverter"assembly or a quicker fix would be to remove old tub water fill spout and replace with a "pull up diverter knob" type water spout. Cost about 10 dollars Hdepot Pull Knob to divert water to shower when showering.
jthomefix
Mar 15, 2009 | Price Pfister Ashfield Widespread Bathroom...
Plumbing Logo
56 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
