Question about Dryers
Dryer starts and flame ignites three times, but wont flame up after that. did a lot of research and assumed it was the coils. replaced them and still same issue. so i pulled out the ohm meter and set
Dryer starts and flame ignites three times, but wont flame up after that. did a lot of research and assumed it was the coils. replaced them and still same issue. so i pulled out the ohm meter and set it top its lowest setting. checked the thermal sensor, high limit thermostat, flame detector, ignitor, valves. all read good. went ahead and replaced the thermal sensor and high limit thermostat anyways. i dont want to dump to much more money into this thing. anyone have an idea? only thing i can think of is a whole new gas assembly but at that point i mine as well buy a new dryer. thanks in advance.
  • 23 Answers
It is easy to procure the wrong thermostats, sensors, safety switches. They can physically look like just the same old ones, but the voltage limits can be off.
Posted on Nov 07, 2014
  • 61 Answers
SOURCE: Kenmore Dryer only lights gas sporaticly
replace the igniter. The ignitor is the most comon problem with gas appliances checking continuity does not tell you if it is bad or not it has to draw a certain amount of amps to open the gas safty valve and the is no safe way to check this on most gas dryers
Posted on Jan 19, 2009
lostinfamily
  • 149 Answers
SOURCE: Dryer Model LGR 8620PW0. Dryer initially
try clearing out the exhaust duct that runs from the back of the dryer to the outside of the house. If this is clogged then this will limit air flow therefore by extinguishing you fire. An easy test to figure this out would be to remove the hose from the back of the dryer and see if you get the same results. If you get the same results try checking all the traps for lint and debris.
Posted on Jun 15, 2010
heatman101
  • 43501 Answers
SOURCE: gas dryer won't ignite.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Aug 31, 2010
heatman101
  • 43501 Answers
SOURCE: Its a gas dryer. Starts
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Gas valves works off of amps pulled by the ignitor...ohms doesn't matter..
heatman101
Posted on Sep 12, 2010
KevinWhite
  • 1902 Answers
SOURCE: Whirlpool gas dryer model WGD9200SQ0,
Hello & Welcome to FixYa
The problem is with the door switch or the flame sensor that is bad and needs replacement, you can test both these parts and let me know the result. Please get back to me if you have any other questions.
Kevin
Posted on Jul 19, 2011
Dryer starts and flame ignites three times, but wont flame up after that. did a lot of research and assumed it was the coils. replaced them and still same issue. so i pulled out the ohm meter and set it to...
Hello Brian;
My name is Peter. I am a retired field service appliance technician.
It sounds like you are pretty capable with a multi-meter. Best tool you could have.
Forget a whole new gas assembly. When you Ohm the ignitor what was your readings. If the ignitor, lights, it could be going bad.
An ignitor can light, glow red, and yet be too week to open the gas valve.
The major failure with your dyer is either the ignitor or the temperature thermal fuse. I think the iginator.
Also check the gas valve. Ohm it out. Sometimes, the valve will sick. You need to knock it with a hammer to start. If it starts, repeat this cycle about 8 times to free the valve up.
Nov 07, 2014 | Dryers
Dryer wont relight
replace the 2 solenoid (gas coils) there are out very common
Aug 14, 2012 | Samsung Dryers
Whirlpool Cabrio Gas Dryer. Will heat for a short time then stops. usually gets stuck around the seven minute mark and wont move from there. Cothes are soaked. I checked all internal parts with multimeter...
If what happens is the flame comes on when it first starts,after the flame goes off you see the igniter glows then goes off but no flame,the coils that open the gas valve are working while thier cool but once thedryer gets running,when warm to hot the gas valve coils wont open the gas valve so when the igniter comes on and no flame the coils have failed to open gas valve and need to be replaced, all manufactures use the same coil supplied by one parts supplier, and them not opening the valve when warm is a very common occurence regardless of what brand gas dryer it is.
The part number for the coils is 279834 they could be picked up from your local appliance parts store for under $20 or online at;
repairclinic.com
searspartsdirect.com
assuredparts.com
apdepot.com
appliancepartspros.com
Gene
Aug 11, 2011 | Whirlpool WGD6200S Gas Dryer
When the dryer is turned on it glows then the flame ignites and stays on for about 5 mins. then shuts off and wont go on again unless its reset to beginning of cycle. I have replaced exhaust hose...
This is usually the dryer coils have failed. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a video on replacing the dryer coils. If you need further help try this link for troubleshooting a gas dryer for whirlpool and Kenmore styles
Nov 06, 2010 | Roper RGX4634KQ Gas Dryer
My gas dryer starts fine than the flame goes out
replace the coils. i promise you. and here is a guide to most gas dryer problems that even a kid can see.
starts fine, cycles off, igniter comes on, hear a click, and no flame.-coils.
(can also be intermintent)
igniter stays on, no flame.-flame sensor
no glow from igniter.-igniter
remember, always allow about one minute for ignition.
Oct 06, 2009 | Frigidaire GLGR331A Gas Dryer
Dryer tumbles continuously but does not dry. When
Check the following areas to combat this issue. the most common problem spot will be a blown Thermal fuse, but in your case, i would pay close attention to the gas valve coils.
1. Gas valve coils
igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. igniter
igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Oct 03, 2009 | Kenmore Dryers
Maytag MDG5500AWW gas dryer with inconsistent flame
the booster coil gets hot and stops working just replace all three and give me thumbs up...i get$60 for a house call
Aug 08, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Gas dryer , Flame cycles on and off a few times then ignigter glows but flame does not light
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Jul 16, 2009 | Whirlpool LER4634J Electric Dryer
I have a similar problem. But I will provide a little bit of history first. My dryer just doesn't get hot enough (approx 100 degrees just prior to the exhaust vent). Three years ago, I had the same...
If the gas cycles on and off I do not think the coils are a problem.  Sounds like the flame sensor is not working correctly.  The flame sensor keeps the gas valve open after the ignitor shuts off.  Then the temperature sensor shuts off the gas when temperature limit is reached.  When the dryer cools down the gas cycle starts again (usually much more than 30 seconds).
May 29, 2009 | Dryers
Wirlpool gas drier flame comes on for the initial start then goes out and wont come back on to finish drying clothes?
Problem -
Gas flame comes on first few times then quits and igniter keeps cycling on and off but never lets the gas go.
Answer ( most common ) -
Replace the coils on the Gas Valve.
http://www.applianceaid.com/gas_dryer.html
I had a problem much the same as you and replaced the coils. Works like a charm now.
Mar 31, 2009 | Whirlpool LGR7646E Dryer
Dryers Logo
47 people viewed this question
Top Dryers Experts
