Question about Dryers
Hello, i have a kenmore 80 series gas dryer(110.74842400). it will start, heat up three times, then wont ignitor glows and just shuts off for the rest of the cycle. i was pretty sure it was the coil
Hello, i have a kenmore 80 series gas dryer(110.74842400). it will start, heat up three times, then wont ignitor glows and just shuts off for the rest of the cycle. i was pretty sure it was the coils so i replaced them. didnt fix it same issue. i used an ohm meter and checked continuity on every part i could. coils, thermal fuse, high limit thermostat, ighnitor, and flame sensor all read good. replaced the high limit thermostat and the thermal sensor even though they read good. i dont want to dump too much more money into this thing, anyone have any ideas?
  • brian547
    brian547 Nov 13, 2014
    well i had ordered a flame sensor, and ignitor. old ignitor read open, and new one closed when i checked them. the old ignitor read 63, and new 95. thought for sure that would have fixed the dryer. so all new parts i put in were the thermal fuse, high limit thermo, ignitor, and flame sensor. all are oem parts. also the first thing had done was cleaned the dryer, and vents/ducks from debris. unfortunately the same sympton exists and it lightes 3 times and no more. glows orange then nothing. same problem before i put all the new parts in. afraid there is nothing else that i can replace.
  • brian547
    edit***old flame sensor read open, new read closed
  • Dryers Master
  • 744 Answers
Hello Brian;
My name is Peter. I am a retired field service appliance technician.
Recently, I worked on a LG gas dryer. I Ohm the thermostat and found that to be bad, but when I Ohm the ignitor I got a reading of 135 Ohms. I replaced the ignitor. The new ignitor Ohm reading was 167. In other words, the ignator did glow red, but did not have the power to open the gas valve.
Although, you checked the electrical continuity of the gas valve, that does not check the mechanical issues. Sometimes the spool in the valve sticks or does not fully open. You need to hit it with a hammer and turn the dryer on. Repeat this about 8 times.
Make sure your hot air distribution manifold is not plugged up. This too will shut your unit down.
Posted on Nov 07, 2014
5 Suggested Answers
  • 61 Answers
SOURCE: Kenmore Dryer only lights gas sporaticly
replace the igniter. The ignitor is the most comon problem with gas appliances checking continuity does not tell you if it is bad or not it has to draw a certain amount of amps to open the gas safty valve and the is no safe way to check this on most gas dryers
Posted on Jan 19, 2009
lostinfamily
  • 149 Answers
SOURCE: Dryer Model LGR 8620PW0. Dryer initially
try clearing out the exhaust duct that runs from the back of the dryer to the outside of the house. If this is clogged then this will limit air flow therefore by extinguishing you fire. An easy test to figure this out would be to remove the hose from the back of the dryer and see if you get the same results. If you get the same results try checking all the traps for lint and debris.
Posted on Jun 15, 2010
KevinWhite
  • 1902 Answers
SOURCE: Whirlpool gas dryer model WGD9200SQ0,
Hello & Welcome to FixYa
The problem is with the door switch or the flame sensor that is bad and needs replacement, you can test both these parts and let me know the result. Please get back to me if you have any other questions.
Kevin
Posted on Jul 19, 2011
oldTech2332
  • 2341 Answers
SOURCE: kenmore 500 series gas dryer
Having checked or replaced what you have thus far here a few things still to check
Cycling thermostat in blower housing,in addition to thermal fuse it must have continuty to be good
Timer check wiring diagram in control panel and check for continuty that are supposed to be closed when set to a normal heat cycle
Motor switch heat circuit check again with wiring diagram and see which wires on motor switch must be closed when running so dryer will heat.This a built curcuit asurring the dryer will never heat when motor is off
If your model has it check heat relay in control panel for continuty on heating circuit for relay(not the circuit that closes relay)
as far as power to the ignitor the hot side comes from timer to and through the thermal fuse and cycling t-stat, to ignitor.the neutral comes from neutral wire on cord to and through motor when motor is running and motor switch is closed
so on ignotor plug check hot wire to ground(not neutral) if has 120 vac to it timer/t. fuse/ cycling t-stat and flame switch are all good and its the motor switch is the problem.The motor switch can not replaced seperatly and must replace entire motor
Gene
Posted on Aug 09, 2011
You have answered this question before but does the ignitor stay on during the drying cycle? Kenmore series 80, model 110 72822101 gas, It starts correctly, ignitor glows, gas ignites,run for 5 to 6 min....
yes..
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 07, 2011 | Kenmore 72802 Gas Dryer
Series 80 gas dryer everything functions no heat does not lite
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 18, 2011 | Kenmore 72802 Gas Dryer
Kenmore Series 80 Dryer not drying with heat. Cool air only
heatman101
Dec 27, 2010 | Kenmore 62802 Electric Dryer
Kenmore 70 series dryer starts and heats up then shuts off
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 02, 2010 | Kenmore 73952 Gas Dryer
I have a kenmore 80 series gas dryer that wont heat. I am looking for the igniter but cannot locate it. Is it under the top?
It is in the bottom under the drum...
heatman101
Aug 31, 2010 | Dryers
My kenmore drier (H.D. 80 series) won't heat up. What can it be? Thanks, Joe
heatman101
Aug 14, 2010 | Kenmore Dryers
Dryer runs fine but heating unit will not ignite
heatman101
Jul 11, 2010 | Kenmore 77632 Gas Dryer
Kenmore series 80 dryer, ryns with no heat. i
that is ur glow bar or igniotror that is common,, check ur ignitor, thermal fuse, or secondary gas coils, those are what are usually wrong with no heat on gas dryers
Feb 03, 2010 | Kenmore 62802 Electric Dryer
Kenmore 80 series gas dryer has not heat
most of these dryers have a little plastic plug on the front, left side. pop that plug out and look inside after turning it on. you should see a red glow. if not, then your ignitor has broken. if you see a glow, then the problem is probably one of the two little coils on the gas valve. these coils will sense if there is something to light the gas [the red glow] and open the valve - if the coils are bad, they won't open the valve
Aug 17, 2009 | Kenmore Dryers
Dryer heat turns off after about 5 min- dyer will remain running but no heat
HI, After the heat shuts down, do you hear a click like it is trying to heat again but then get no flame. The most some problem is the coils on the gas valve go bad and will not reopen after they have heated up.
Remove the cap on the front lower left panel. After dryer has ran and heat shuts down, watch and se if the ignitor glows again (you will hear a click) and the ignitor shuts off before a flame. If this happens, change the coils on th gas valve.
Here is instruction: Normal 0 UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the two black coils on the gas valve. When you remove the three wire coil, make sure the sleeve inside it gets put back on the post the coils slides onto.
If I can assist you further, please let me know.
Thanks
Vic
Jun 01, 2009 | Dryers
Dryers Logo
59 people viewed this question
Top Dryers Experts
