Question about Hitachi UltraVision CineForm 55VG825 55" HDTV
My Ultravision TV is now having horizontal lines. Do not know if it has a horizontal hold button hidden somewhere or is the TV going out? Can I fix it myself. Large screen
  • Philip Frye
    Philip Frye Nov 17, 2014
    I wish it was as simple as fixing it yourself but my thoughts are that it may take a qualified technician to do this. It could also be as simple as a loose cable inside the TV yet if its been sitting in one place all the time then that's questionable? My thoughts is that something has failed 'a component or Integrated Circuit! See if you can find a local Repair shop and see if they may have some other repair/fix suggestions.
    Sergeant:
  • 295 Answers
Can you try and see if it is your source that has the lines or the actuall TV that has the horizontal lines.
What is your source? Direct TV, Cable TV or even off air Digital TV.
If you remove your source do you still get the horizontal lines? If you do then what colors are they? Seems if when you remove your source input and you still have these H-lines then you have issues with your individual LCD palets. Especially if they are just Green, Red or Blue?
Posted on Nov 13, 2014
Testimonial: "He was exactly spot on with my issue. Thank you very much. No longer did I have to move that heavy TV to keep trying to adjust the cable wires. Thank you.."
  • Linda Austin Nov 16, 2014
    I have cable with a DVR and usually when i turn off the DVR the TV is blank but now iwith the TV on alone it does have red, blue and green lines through it. Can you help me in fixing the problem? I am not a repair person but a quick study and can follow directions well. If it is a part needed I can and will replace it myself if I know what it is. Thank you very much for your assistance.
  • 927 Answers
SOURCE: Many thin black horizontal lines on my Hitachi Ultravision 50" TV
Good Day, LDS also;
You may have a poor seated cable connector. Unplug TV from A/C, remove back look for a large black connector. It connects between the Main Digital Module and the Drive PWB. Re-insert both ends several times to make better contact, use contact cleaner if have but not always needed. Good Luck, big IRISH.
Posted on Sep 06, 2008
ladywinn
  • 5138 Answers
SOURCE: blue droopy line in middle of tv, everything yellowish above
Your convergence ICs Stk-392-110s Replace Both ICs.If 110s use 180s if 020s use 040s other wise Go by number on ICs .Mat electronics has parts 1-800-628-1118.Thats Cheap for 300.00 if you only have to replace ICs! Check all resistors around ics replace them if burt/read bad.RK42 3.3ohms RK46 1.8 RK50 2.7
RK54 1.5 RK58 3.9 RK62 2.2 ohms.
Posted on Jan 07, 2009
SOURCE: My Hatachi SBX Ultravision TV, has recently
Sounds like the convergence output ICs failed, when they fail they can also open fuses and or resistors.
Posted on Aug 28, 2009
SOURCE: horizontal lines across middle of screen sometimes
Vertical problem coming from bad solder, or vertical circuit problems!!!
Check for bad solder and capacitors problems in vertical circuit.
Posted on Aug 30, 2009
dave1645
  • 834 Answers
SOURCE: I have a Hitachi Ultravision 61SBX59B TV.
that white line is a high voltage leak have you had this set serviced lately? one of the hv lines from the flyback transformer
is not seated or leaking you need a tech to find it not a safety issue just an anoyance
Posted on Nov 19, 2009
Two horizontal lines appeared near bottom of screen
You can spend $300 to $500 fixing this or just do the best thing most cost effective thing and replace the TV.
Aug 23, 2016 | Sharp Aquos Televison & Video
One day I turned on my tv and white line appeared down the middle and won't go away
If your tv is under warranty, just send it to them for fix, otherwise you need to get into the "debug" or "maintanence" menu of the tv. Google the model number of the tv and things like "debug menu", "hidden menu" or "change horizontal scanning".
Your horizontal scanning option is set too far to the right of left.
Oct 07, 2012 | Televison & Video
So I'v had my 47LG60 for a while now and it started getting these green static lines going horizontally. What kind of problem is this and is there a way I can get it fixed?
This sounds like a faulty panel. A quick way to test this is to hit your TV's menu button. If the lines go over the menu the panel is faulty. If the lines are hidden by the menu then the signal is transmitting those lines and you will have to talk to your signal provider. If it is a faulty panel you should call your TV company. Usually faulty panels are automatic replacements if you are still within warranty.
Jul 18, 2011 | LG 47LG60 LCD TV
My flat screen tv has different colored horizontal hold lines across my screen. Where is the button for horizontal hold?
Those colored lines are a bad panel. Is no button to make them go away. The only fix is to replace your panel. Would be more cost effective to replace the TV.
May 06, 2011 | Dynex DX-LCD37 TV
I have a 65 inch Hitachi HDTV. There are red,
Sounds like you need to purchase a convergence kit. Instuctions are included
Jul 21, 2010 | Hitachi 43UWX10B 43" Rear Projection...
Good Day, LDS also;
Jul 21, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
$$$$ fixed
i had the same horz. lines in my t.v. I called everywhere and ended up fixing it myself.(The solution on my t.v. was to unplug the set hold in both channel buttons and plug the set in at the same time you hold the buttons) it then reset the t.v. lots of luck.Bob p.s let me know if it helped you.
Apr 02, 2008 | Televison & Video
Faint horizontal lines in picture
This is usually caused by a problem in the Horizontal Output section, around the Horizontal Output transformer usually a capacitor or diode going or gone faulty... the line you see are the Horizontal "Retrace" lines that are useually "Hidden" when the circuit is OK..
Jul 30, 2007 | JVC AV-27320 27" TV
Horizontal roll on mitusbishi 35" tv
is this a horizontal black line going up or down? if yes, this sympton is caused by a trouble in the integrated circuit or in the vertical oscillator circuit. this symptons has 2 variations. one is the intermittent rolling of the picture. this referred to as the "loose vertical hold" the other variations is the continuous upward or downward rolling of the picture
Jan 15, 2007 | Mitsubishi CS-36509 TV
Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
182 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
