Question about Samsung RSG307AABP 30 cu. ft. Side by Side Refrigerator
Why won't door on Samsung side-by-side refrigerator stay closed? Pops open after closing, like the seal isn't working.
Problem isn't consistant. Seal is good. Refrigerator contents aren't getting in the way of the door closing. Drawers are all closed.
  • rc13k506 Nov 07, 2014
    There is a spring loaded water filter on the bottom right side of the refrigerator. If it is in the “Unlocked” position, it sticks out just enough to give resistance to the refrigerator door when you close it. Be sure it is in the “Locked” position.
    Sergeant:
    Champion:
  • 324 Answers
The door isn't lining up right when it's closed. I suspect you have been putting heavy stuff on the door racks, like several 2 liter soda bottles or gallon jugs of milk. Over time the door will sag from the weight until it won't stay closed.
Posted on Nov 07, 2014
Testimonial: "There is a spring loaded water filter on the bottom right side of the refrigerator. If it is in the “Unlocked” position, it sticks out just enough to give resistance to the refrigerator door when you close it. Be sure it is in the “Locked” position."
3 Suggested Answers
cosatto
  • 29 Answers
SOURCE: my refrigerator door won't stay closed!
Don’t mess with this or you could invoke the manufactures warrantee. Contact Customer Services
http://www.samsung.com/uk/support/onlineservice/onlineService.do
Posted on Dec 10, 2008
heatman101
  • 43501 Answers
SOURCE: Samsung RB1955SW refrigerator is not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Sep 30, 2010
Freezer door opens
This sounds like an alignment problem. Loosen the hinges slightly and place the door in the closed position and duck tape it in place. Tighten the hinges and check it for seal. Door is heavy by itself so empty it first and work with some help.
Apr 01, 2014 | Maytag MSD2732GR Side by Side Refrigerator
When I close my side x side frig the freezer door pops open
This happens because the refrigerators of today are air tight, the fresh food door pushes the air into the cabinet as it closes and the air has no place to go but up the air vent into the freezer and "pops" open the freezer door. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly.
Oct 17, 2012 | Kenmore Side by Side Refrigerator
When I close the fridge side the freezer side pops open a little and stays open. The appliance is 5 years old. This started very recently
a couple of problems can cause door problems first open door and check seal for damage [popped off trac or rip-tears]other is hinges worn- bent-loose --if seal is good at top and bottom of door are hinges check for loose if loose tighten -if bushing lookes like a little round washer type is broken or missing replace --needs realignment loosen top hinge and close door and adjust till door is straight and stays closed tighten door hinge done good luck
Jun 28, 2011 | Jenn-Air JCD2389G Side by Side...
Fridgedaire Upright Freezer Door won't stay shut. Normally when closed, you hear the seal take place, now it pops open
Check the seal in the corners on the side of the door your hinges are on, ya may need to tack it down with crazy glue, but usually it'll curl in the corners preventing door from closing or pop open after you walk away
May 06, 2011 | Kitchen Ranges
Refrigerator door does not stay closed. When the freezer door is closed the refrigerator pops open.
The fridge and freezer share their airspace, so when you close one there is a slight increase in pressure in the other unit. (Much like opening a window can cause a door open/close in your house due to pressure change/air movement) The magnet in your seal of the door is weak and unable to resist the pressure change. The seal should be changed.
Could also be that the door is not shutting properly in the first place due to sagging or skewed hinges that need adjustment/replacement and while shutting just may not be getting a complete seal that it should be.
Sep 02, 2010 | Refrigerators
Refrigerator Door won't stay closed
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Part 12 on this diagram is your cam. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=KSRB27FHSS02&productCategoryId=0165000&brandId=0593&modelName=SIDE-BY-SIDE-REFRIGERATOR&diagramPageId=00006&componentDescription=REFRIGERATOR%20DOOR&documentId=O2030395&backToLink=Return%20to%20Sub%20Components%20list
Aug 19, 2009 | KitchenAid KSCS25FKSS Side by Side...
Freezer door pops open when fridge door is closed.
well u need to check the rubber of ur freezer ;s door .some damaging in the rubber is causing the problem.
May 26, 2009 | Amana ARSE66MB Side by Side Refrigerator
Refrig door does not seal shut.
jack up the two front leveling feet a bit to make it lean towards the back. or put a level on it to see how far it is off.
Dec 04, 2017 | KitchenAid Superba Architect KSCS25IN Side...
Freezer door wont seal and stay closed
Your pushing air from the fridge part over to the freezer door when you clos it,the only thing i can suggest is make sure that the seal (which is magnetic) is clean and not falling apart,inspect it all around the door,and when closing the door i would close it gently.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 25, 2009 | Amana ARSE66MB Side by Side Refrigerator
Sub-zero 500 series refrigerator door wont stay closed
If Your Refrigerator's Freezer Door Pops Open When You Close the Fresh Food Door... If a 'top-freezer' refrigerator's freezer door pops open when the larger fresh food door's closed, it's actually a good thing. That tells us the seals are in great shape, sealing well.
Some freezer door 'pop' is unavoidable bc the bottom door's so much larger than the top one and the hydraulic effect of compressing all that air kicks in. The two compartments share the same air via a duct between them, and that compressed air rushes up into the freezer compartment and can 'pop' the door.
To improve the situation, apply a few drops of oil (sewing machine oil or 'three in one' - NOT WD-40) to each freezer door hinge pin. (Even better: if you can, pull the doors and coat the hinge pins with petroleum jelly). This will help the freezer door swing back closed by itself. The freezer door usually stays ajar because it's binding a bit, and that's usually caused by it's swinging 'dry', with no lubrication.
It’s also a good idea to ‘kick’ the habit of letting the refrig door close hard.
Sep 04, 2008 | Refrigerators
Samsung RSG307AABP 30 cu. ft. Side by Side Refrigerator Logo
142 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
