Nobody seems to no know a bush idpvr802 is a digital box not a tv so when it freezes it could be rebooted will some one tell me how
Remote works but not with the digital box or tv.Box stuck on bbc1 will not go to menu or reboot even after unplugged overnight and disconnected please advice needed
    Top Expert:
  • Televison & ... Master
  • 74,136 Answers
Sounds like firmware corrupted. Contact the authorized service centre to get it updated. http://electronicshelponline.blogspot.com/
Posted on Nov 07, 2014
Testimonial: "thanks for trying to help will have to contact bush themselves as no one online knows what to do"
  • 4 Answers
SOURCE: Samsung LE26R73BDX 26INCH - LOSS OF DIGITAL SERVICE
Solution that worked for me:
Beware: Although the process should be safe, it technically voids your warranty.
Enter the service menu:
1 - turn of tv with remote
2 - press and release in the following order on the remote: Info, Menu, Mute. Make sure remote is pointing at the tv
3 - turn on the tv from the remote
4 - you will see the service menu. using the down arrow on the remote select the Reset option. Using the right arrow button at this point will do a hard reset.
5 - Wait a few seconds, turn TV on
6 - you will have to rescan analogue and digital channel but it should be working now.
Posted on Jun 10, 2008
  • 16 Answers
SOURCE: TV freezes when switching to a digital channel
The problem your describing can be contributed to your cable box. Depending on your cable company there are times when the box has trouble translating the signal to the tv. You tv is operating normally. Suggest to the cable company to switch your box.
Posted on Dec 07, 2008
macgroovy2
  • 52 Answers
SOURCE: Cox Cable Remote wont program to my Sylvania LC320ss8 tv.
there are different codes for the devices that you are using. When you want to insert the code for the tv. > Switch tv on and then switch all the other devices off. Insert code. For digi box > switch on and all other devices off. Insert code for digibox. You must then switch between tv and digi box using the buttons on the top of the remote. Toggle between tv/ digi box.
Have a go with the codes below with the tv and the digibox both on, you never know you might get lucky as these are new codes, if not revert back to 1st solution.
Universal Codes (both should work using these, i think!!!!! try 'em)
002,
008,
155,
198,
227,
231
Here are the codes for the 1st solution.
Good Luck,
Hughie.
Tv
0062
0004
0009
0135
0189
0183
1141
0227
0456
0008
0068
0075
0141
0161
Digi Box.
0899
0227
0287
0290
0225
0456
0251
0292
0236
0458
1106
Posted on Jun 18, 2009
Obertelli
  • 3006 Answers
SOURCE: Samsung LE32N7 - Analogue channels ok - Freeview
This is very common to a number of Samsung models built at the same time as yours and using the same in-built Freeview receiver.
There is no fix, the built in receiver is simply incompatible with the most recent updates to Freeview (as happened to many external boxes) and cannot be modified, the only puzzle is the length of time that your receiver kept going for. If your tv has a warranty still then you may wish to see if the fault is covered.
Without a warranty, all you can do is continue to use an external Freeview receiver. They're usually better quality anyway, and are easy to replace when they go wrong or become out of date.
Posted on Sep 17, 2010
  • 11800 Answers
SOURCE: I have an Akura ATLDVD1930W-HD
The code for your tv is missing from the remote because there is an cross-incompatibility: at code level some of the commands for the tv are identical with completely different commands on the box. This is why when you press a key on the tv's remote the box freezes - it's commanded something that doesn't makes sense for it.
Unfortunately there's absolutely no way you can change that . All you can do is to stop using the remote of the tv and block its remote/IR sensor so it will not be messed up by the commands to the box. Or you could get a new tv.
Posted on Feb 01, 2011
Does anyone know how to reboot/reset a BUSH idpvr802 freeview digital box without using remote
You can't set it to its factory setting [reboot]; without its remote control. There are two types of reset to. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Nov 02, 2014 | Televison & Video
Bush tv lcd32tv07hd
Usually if there is a guide or epg button on the remote control it will have digital freeview.
Feb 01, 2014 | Bush Televison & Video
I have a bush lcd32f1080p. The remote control worked ok but suddenly failed to work. I know others have the same problem but nobody seems to have a solution. Any ideas anyone
Because the amount of people that have has this problem it seems to be faulty parts in the remotes. The company should be able to know what remotes had bad parts in the remotes by the "batch" and/or "lot" numbers they put on the remotes themselfs.
I am having some trouble looking up the main website for bush. Do you have the customer care contact for them? I will continue to look but I would recomened getting in contact with them. How old is the TV? there is a one year warranty on bush electronics(pretty much industry standard of at least one year)
If they try to sell you a remote it is better to just buy a universal remote. You can even get some that will install the devices off the internet with all the features(in my cases)of the Original remote.
post in comments of you need any more help. Hope I helped!
Mar 20, 2010 | Samsung TXM1997 19" TV
Dec 05, 2008 | LG 32LG40 32 in. LCD HDTV
How can I get Freeview Channels?
I have a Bush 6690D and I can confirm that it does have a built-in digital decoder for terrestrial signals (Freeview).
Have you checked whether ***********'s TV is set to digital mode ? The "Mode" button on the remote cycles between analog, digital and AV inputs.
Oct 23, 2008 | Bush DVD2038 DVD Player
Bush digital terrestrial receiver dfta 11
Hi John
If you havent allready try unpluging the unit from the mains.
Leave out for 5 mins then plug back out & allow system to reboot.
Cant guarantee this will work but it does solve a lot of digi box problems.
http://dysonmanuals.llc.nu/
Chris.
Mar 09, 2008 | Televison & Video
Remote control codes for freeview and dvd recorder
According to the booklet you have to enter the code 119 for a Goodmans TV, however it does not work with my Goodmans portable TV and even quick search / autoscan doesn't find the TV.
Nov 25, 2007 | Jensen JER-422 Universal Remote Control
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
