Question about Sewing Machines
WHERE TO LOCATE A MANUAL FOR MY MACHINE, NOT ON LINE.
STUCK IN REVERSE. I HAVE NEVER USED THIS MACHINE AND I DO NOT HAVE A BOOK. PLEASE HELP. I LOOKED ON LINE FOR THE MANUAL BUT THIS MODEL WAS NOT LISTED.
  • Sewing Machines Master
  • 665 Answers
GO TO THE BUSINESS I'VE PUT AHEAD. IT IS BUSINESS WITH ALL SORTS OF SEWING MACHINE MERCHANDISE. IF IT ISN'T LISTED PUT IN THE INFORMATION AND THEY WILL LIKELY BE ABLE TO GET IT. ALSO, GIVE EBAY A TRY.
http://www.sewingpartsonline.com/instruction-book-janome-and-newhome-8000.aspx
Posted on Nov 07, 2014
  • 3 Answers
SOURCE: need a munual for White Speedylock 1300 DE serger
http://sewusa.com/Threading_Diagrams/Threading_Pages/White_Sewing_Machine_Threading/White_1600_Speedylock_Threading_Diagram.htm
If this isn't helpful, email me and I will scan my manual.
Posted on Jun 11, 2008
SOURCE: manual from brother listed sewing machine
I believe these are the UL code and serial number. If there is a display band of decorative stitches on the front of your machine look on the bottom right of that panel. If the number there is a VX-920 there is no manual available for it BUT you can use the manual from the VX 970 which IS available. Do a search for that model manual in Spanish and you should find one.
Posted on Aug 03, 2009
  • 152 Answers
SOURCE: Husqvarna Model 6360 reverse button stuck
This problem comes about due to lack of useage usually. If the machine has been sitting for some time the grease inside hardens. The stitch length regulator, the pattern selector and the buttonhole mechanism could all be contributing to your problem. To fix it properly all three dials should be remove from the machine, disassembled cleaned, assembled and oiled lightly with a teflon lubricant. Since so much is removed from the machine doing this job, every setting in the machine is checked and or reset. It's a major overhaul and costs about $350 and only a handful of Viking Techs in the country can do it.
Posted on Oct 07, 2009
  • 152 Answers
SOURCE: My model 210 is stuck in reverse. Can you help?
The only thing you can do to possible free the mechanism is to turn the lower dial back and forth a bit, from the position where it is in permanent reverse to the numbered area on the dial. Make sure the selector is not on the buttonhole position. That machine doesn't really have a history of that issue but anything is possible, especially if it has sat for awhile and not been used. If moisture was present where it was stored, it's possible the feed linkage is slightly rusted and simply stuck.
Posted on Oct 08, 2009
chris592
  • 86 Answers
SOURCE: need sewing machine manual
You can find it here:
http://ifixmachines.com/index.php?page=shop.product_details&product_id=3252&option=com_virtuemart&Itemid=54
Posted on Nov 16, 2010
The reverse stitch button is stuck in (or broken) and machine only sews in reverse. Can this be repaired?
Have you followed your user guide instructions re making needed setting adjustments back to a sewing mode? Have you checked the guide for instructions on 'resetting to factory default' so that you can reprogramme?
If the above doesn't help, have you tried a 'shock reboot'? Start by turning on machine on and let it sit for a few minutes then without turning it off, pull the power plug from the electrical outlet. Wait five minutes then reconnect and turn on your machine - it should have defaulted back to factory settings. You'll lose your saved stitches but your machine should function properly again.
If that doesn't get your machine sewing forward, something the wee man did snapped something inside the machine (usually a gear and the things are easier to 'snap' than people realise) and it's time for a trip to the repair tech...,,THIS IS ALL I COULD FIND ON THE INTERNET..plus this manual...
http://janome.com/siteassets/support/manuals/retired/computer/inst-book-mc4000.pdf
Dec 06, 2016 | Sewing Machines
My machine has not been used since 2004 and is stuck in reverse How do I fix this?
If it is a mechanical (NOT computerized) sewing machine, it most likely needs a good cleaning and oiling after not being used since 2004. Mechanical sewing machines need to be cleaned & oiled every time a bobbin is changed, every 8 hours of constant sewing, or every six months when not in regular use. Use only good quality sewing machine oil (NOT stale old oil, 3-in-1, WD-40, or cooking oil) and oil only 1 or 2 drops each spot as directed in the owner's manual.
Sewing machine oil tends to degrade over time and will eventually glue moving parts together. Keeping it maintained is a simple way of insuring it will work the next time it is used.
Sep 12, 2015 | Sewing Machines
I HAVE A KENMORE 14813110 SERIAL # 32627. THERE IS NO MANUAL FOR THAT SERIAL #. IT IS STUCK IN REVERSE AND I HAVE NEVER USED THIS MACHINE BEFORE. help
Most manuals are available on-line. Kenmore is Sears. I do not know about Sears specifically for sewing machines, but give it a try. Sears has a parts direc with manual access although not sure about sewing machnes. Or use Google search. Always in PDF. Now, when I get something new I ALWAYS find the PDF of the manual and save it in documents. I have a file called USER GUIDES just for that purpose.
Nov 06, 2014 | Sewing Machines
How to fix a Husqvarna sewing machine 2000SL 6460 stuck in reverse
A machine stuck in reverse usually means the step motor controlling the movement of the feed dogs has gone bad. You will need to have it serviced by a Viking Service Tech. You can find a dealer near you by using the link 'Locate a Dealer' at the Husqvarna Viking Website - http://www.husqvarnaviking.com/us
Sep 05, 2014 | Husqvarna Sewing Machines
I have my Mother's Brother XL3750, no book or accessories. It will sew in reverse only. I don't even know where the reverse button is. The only thing that I have tried is the big lever front...
you can download a manual for your machine from the Brother website,
link is
http://welcome.solutions.brother.com/BSC/public/files/dlf/doch000452/bm2736xl26i35i375ug04enes.pdf
Reverse is the big lever in front but it should be sprung so you need to hold it down to reverse; if your machine is only sewing backwards, this lever might be stuck or locked into position. Check out page 25 and 26 in the manual for specific info.
Sep 10, 2011 | Brother XL3750 Mechanical Sewing Machine
Oct 07, 2009 | Husqvarna Viking 1
Backward stitching
Knowing which kind of machine you have helps alot. Just guessing but maybe the reverse mechanism is stuck and needs some oil in it to free it up. Or the buttonhole mechanism is stuck in reverse part of it.
Probably you should have it looked at.
Dec 31, 2008 | Singer 3116 Simple
Husqvarna Viking Sweden Model 6030
On all sewing machines there is a button or lever which makes the machine go backward. The button could be stuck, if so put a drop of oil on it and try to release it. If there is a lever that has been raised which puts the machine in reverse, simply lower it to the lowest position. This should solve the problem.
Zelma
Nov 29, 2007 | Husqvarna Viking 1
Reverse only?
I too just aquired a husqvarna viking 6030 that was stuck in straight-stitch reverse. No forward, no zig zag, no button hole, no cam stitches. I also suspected a broken spring, since the reverse button was slack and had no resistance. But after inspecting every moving part, I realized it was just stuck from many years of non-use. I finally got it free today! I had used some Tri-Flow oil and applied it sparingly to all moving points (but not belts or motor). I exercised all the buttons and like another poster (either here or elsewhere, not sure) I used my hair dryer to apply heat to the inside of the machine through the cam slot. After you remove the white cover on back of machine that holds the two spool spindles, you will see a formed aluminum part just behind the reverse dial that has a rounded-pointed protrusion which sort of looks like a fat flat head screwdriver. It is supposed to travel in an up-down motion when reverse button is pressed. I used a flat head driver to coax its movement, and once it began moving, I continued with heat and drops of oil. Good luck.
Nov 11, 2007 | Husqvarna Viking 1
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
