Question about Kenmore Refrigerators
The touch pad is not work, so now i can't get any water or ice, why?
    Problem Solver:
  • 7 Answers
First check the water line, cut the valve may be closed, dirty filter, then, check for voltage to the solenoid gets water at the time of pressing the botom, review contron card that is not damaged any relay, switch keyboard
Posted on Nov 08, 2014
3 Suggested Answers
  • 794 Answers
SOURCE: Maytag refrigerator model # mfi2266aeu
Hi sandee462,
The reason why you experience this problem is because you have a control that if it senses the water is ran for over 2 min it shuts dispenser down , in order to unlock the control you have to reprogram it:
1. First, press the door alarm and freezer "-" simultaneously.
2. Release the door alarm but continue on pressing Freezer "-". You'll se PE_ _ _ _.
3. Press Freezer "-" until PE #### shows on the panel.
4. Using Freezer "+" to move cursor, Refrigerator "+" and "-" to change numbers, bring all numbers to "0".
5. Press Freezer "-" until PE and numbers blink.
6. Unplug refrigerator for 45 seconds, never beyond 1 minute or you'll have to start over.
7. Inside your refrigerator look for CODE #### which is at the right of the serial number.
8. Afterwards, plug back in your refrigerator.
9. Again you have to press Door Alarm and Freezer "-" at the same time, then release Door Alarm but continue to press Freezer "-".
10. Using the same method as above, enter the four digit CODE number you found.
11. Press Freezer "-" until PE and numbers blink. You have just reset your panel. Unplug for 45 seconds. Plug in refrigerator and you should now have full use of your door panel.
Hope this helps.
Thank you for using FixYa.
Posted on Jun 03, 2011
  • 796 Answers
SOURCE: We have a GE profile side by side stainless steel refrigerator. The control panel touch pad does not function.
The electronics behind the touchpad may have failed. You usually change the whole panel/pod as a single item - could be expensive and perhaps something else has failed, so it could be a waste. First check all connections to it are dry and not corroded. if they are OK Try to buy a used panel/pod on ebay, then change it
Posted on Dec 14, 2013
Dec 14, 2013 | Refrigerators
My refrigerator won't dispense ice cubes or crushed ice or water at the front door, I was wondering if it could be the Touch pad control panel on the front of the refrigerator. If it is can you give...
The front touch pad board /panel which you are referring is called dispenser board.To access the dispenser board assembly, click this link below:---
http://howtobyme.blogspot.com/2011/06/ge-side-by-side-refrigerator-will-not.html ------------ The dispenser board removal procedure is mentioned at the last on the link instructions.-------- -------------- But the engineer at your place has pointed you to right direction.The main control board is most probably the cause of problem.One more important thing.There are many other users too facing same problem with there ge side by side refrigerators.This problem occurs in many ge model refrigerators. There was service letter released by Ge for this problem.Click this link, to read the letter:--- http://howtobyme.blogspot.com/2011/07/ge-side-by-side-refrigerator-wont.html -----------
You can get required parts from online sites like: --- www.repairclinic.com or from searspartsdirect online site.
----------- This should help. Thanks.Helpmech.
Jul 28, 2011 | Refrigerators
The water stopped coming out of the water dispenser and the ice maker will not make and drop ice. The line from the house to the fridge is not clogged, the lines to the icemaker do not appear clogged.
Sounds like someone accidentally locked you out. If you see a RED light lit above the touch pad.
To Lock Out Press the LOCK Touch Pad for 3-5 seconds. A Red light will appear above
the Touch Pad.
To Unlock
Press the LOCK Touch Pad for 3-5 seconds until the Red light above the
Touch Pad goes out.
Other possibilities:
Household water line valve is not open. -open valve
Freezer door is not closed-Close door tight
Ice & water filter cartridge is clogged-replace filter
Front filter not fully installed, if equipped-Push filter until you hear a CLICK. filter should be FLUSH with cabinet
Here is a link to the user manual.
http://manuals.frigidaire.com/prodinfo_pdf/Anderson/241572801en.pdf
Hope this helps
Thanks
Please rate FIXYA
May 26, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
Eletrolux side by side. temp problems. no water on door and at first when the freezer door would close the ice maker would kick on and ice would start dispensing.
Sounds like the touch pad has a jammed button or is shorted , if it dose not release by depressing a few times firmly, the touch pad on the door may have to be replaced. The temperature problem may be unrelated or the ice maker door flap may be remaining open lowering the temperature. Hope this helps.
May 02, 2011 | Electrolux Refrigerators
The ice dispencer is always running out of ice there is a setting for making extra ice for hot day but lost my manual
To increase ice production for special occasions, such as parties, push the Touch Pad _ for
3-5 seconds to activate this feature. A green light will appear above the Touch Pad. Push the
Touch Pad _ again for 3-5 seconds to deactivate.
Here is a link to your manual. http://www.managemylife.com/mmh/owner_manuals/4709/FRIGIDAIRE-Side-by-Side-Refrigerator-L0302088?brand_name_search=GLRS237ZAW7+FRIGIDAIRE
Jul 08, 2010 | Frigidaire GLRS237ZA Side by Side...
Dispenser pad not engaging
Hi; is the refer. still under warranty. Ask the people You ordered the part from. Also sounds like the touch pad has been pushed too hard or to many times over the years and might need to be replaced...alpharome416
Feb 26, 2010 | LG LRSPC2031 Side by Side Refrigerator
Control pad flashing temp and all lights continuously and ice door continually cycles open and closed
With the problems it is presenting, I would say it's very likely.
However it may take a bit of detective work to find which board is defective.
Check a part suppliers link Here for price comparison so you have some ideas.
Jun 26, 2008 | Kenmore TRIO 77314 Side by Side Bottom...
Problems with water & ice dispenser
If you are pressing the buttons (such as hold for 5 sec to lock), etc. and it's not working properly then the control board could be the problem. Make sure that you start trying the touch pad from scratch in case it's all goofed up (locked but not showing locked, etc.). Unplug the fridge for 30 sec then plug back in and try the whole troubleshooting thing again.
Jan 08, 2007 | Maytag 22.6 cu. ft. Side-By-Side...
Refrigerators Logo
50 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
