127 ERROR CODE ON DATACARD PRINTER CE840
WHEN YOU POWER IT ON , IT GIVES YOU 127 ERROR DURING INITIALIZATION. WHAT MAY BE THE PROBLEM BECAUSE, WE REALIZED THIS PROBLEM DURING INSTALLATION OF THE MACHINE.
  • 163 Answers
SOURCE: Error Code
the high voltage board of your machine is abnormal,check and clean all corona wires or charging roller if problem not go repair or replace the board
Posted on Sep 14, 2007
jtuminaro
  • 56 Answers
SOURCE: machine error. no error code.
Go into maint. mode.
With-in 2 seconds hit Menu,*,2,8,6,4
Then hit 82 when in maint mode.
This will give you a machine error code.
Let me know what that number is and I will help you with a solution.
Posted on Jan 15, 2009
  • 541 Answers
SOURCE: canon clc 4000 error code e194-0101
0101
When the pressure main thermistor fails to reach 80 deg C within the prescribed period of time after reaching 50 deg C during warm-up
you need your fuser rebuilt by a technician
Posted on Dec 30, 2009
  • 421 Answers
SOURCE: Canon MP630 error code 6502
Error 6502 is the ink tank position sensor error. Basically means the printer can't see the inks. Try reseating them. If this fails you need to send it back.
Posted on Jan 08, 2010
SOURCE: error code 117-363 printer starts machine is awake
only see error code 117-363 and not permited other option
Posted on Jan 30, 2010
What does error code 103 mean on a datacard printer sd360 mean? How do I troubleshoot?
Usually that occurs when the card position sensors inside the printer need a thorough cleaning. Get yourself a Datacard cleaning kit for the SD260/SD360 printers, and perform a standard cleaning with it - PLUS - use IPA alcohol soaked wipes to clean the "slot" in the card sensors where the card passes through during printing. That should take care of things.
If cleaning DOESN'T resolve the issue, and you either have extremely high print volumes on the machine (>100,000 cards), OR if it is more than 3 or 4 years old, then it could be the internal transport rollers are worn to the point that they are not consistently positioning the card properly. If that's the case, warranty will cover it (if still in effect), or otherwise repair or replace.
Nov 15, 2017 | Datacard Office Equipment & Supplies
How do I should solve error massage : 103 for Datacard Printer
Power off the printer. Cancel the error message on the PC. Power on the printer. If the issue persists, contact your Datacard dealer.
Aug 02, 2017 | Datacard Office Equipment & Supplies
Error code 127
What does the manufacturer's information say a code 127 is? We need to know that to give you any help. What did they try to fix already?
Jul 21, 2014 | Buffalo Jeans Buffalo 1.5TB DriveStation...
Datacard error PR 01739
Upgrade the printer firmware (Go Green firmware update) as you are likely using the newer eco friendly ribbons. The older firmware versions do not recognize this ribbon, which leads to the PR01739 error.
Download firmware here: https://www.datacard.com/id-card-printer-support-and-drivers/sp55-plus-card-printer
Dec 02, 2012 | Datacard SP55 Plus Printer
Xerox 560 error code 127-212
Error Codes
If an error caused the printing to end abnormally or a malfunction occurred in the printer, then an error message code (***-***) is displayed.
If an error code not described in the following tables is displayed, or the problem persists even after you have tried the following solutions, contact the Customer Support Center.
Tip
If an error code is displayed, all print data of the printer as well as print data stored in the built-in memory of the machine is discarded.
Error Code: 127-212
Error Category: Print; Other Problems
Cause: Detected an internal print check error by the FreeFlow
Print Services Controller.
Remedy: Remove and reinsert the command/video cable between the FreeFlow Print Services Controller and the printer. Power off and on both the printer and the FreeFlow Print Services Controller. If the problem persists, call the Customer Support Center.
*** extracted from my Fuji Xerox Color 560 Printer - Printing Systems User Guide
*** I assume we have the same printer
Jul 13, 2012 | Lenovo ThickCentre M58p Desktop 7479A3U
Datacard CP40 Plus printer with an error. Put a new ribbon in it and it does give us a error message: Error: PR-01739 Ribbon Error Please Help!
Sounds like you are using an incompatible ribbon. Please post the configuration for the printer which is on the left side under the cover (white sticker) and your ribbon part number. If you are sure both are correct you may have a defective print ribbon or your printer will need service.
Contact TulsaBiz.net for more info
Jul 22, 2011 | Datacard SP55 Plus Printer
Datacard SP75 Plus not responding
I have error code h 3 , 7 printer xerox workcenter xd155df
Feb 12, 2010 | Datacard Group SP75 Color Card Printer
Need Datacard CP60 printer service/repair manual.
Contact TulsaBiz.net or MidwestIdSolutions - Can offer assistance as a Datacard CP model is Dealer only you can only get information from a datacard dealer
Jan 08, 2010 | Office Equipment & Supplies
P62 error code
The IBM 6400 printer uses internal programming software that is specific to the printer based on installed interfaces and graphics options. This software resides in flash memory and when the printer is first powered on the software is executed. During this process it initializes the various processors on the controller board, initializes the optional interface cards, and then loads the necessary operating settings into dram. If the programming software becomes corrupt it will fail during startup, giving you the DC Program not valid error or a number of other error messages. The solution to this is a reflash of the printer. Unfortunately, the flash software is proprietary to IBM and they will not distribute it to anybody. The only way to get the printer reflashed is by calling IBM and having one of their engineers reflash the printer.
Jan 28, 2009 | IBM 6400 Matrix Printer
53 people viewed this question
jasbo
jasbo
