Question about Alpine Blackbird II PMD-B200 GPS Receiver
I have a blackbird b200 it was working fine i replace the battery and now alpine on the screen stays on
2001 blackbird only running on 2 cilinders: My hbb
stuck float chambers in carbs ...remove service and clean
Aug 01, 2013 | 2001 Honda CBR 1100 XX Super blackbird
How do I open the unit to replace the battery?
On the side it has a lil rugged spot on the grey area. In this same area look for a small screw remove the screw and push on the rugged area and the battery comes out.
Feb 25, 2010 | Alpine Blackbird II PMD-B200 GPS Receiver
I have lost my maps on my Alpine Blackbird PMD-B100 how can I get them back?
I am guessing you did not back them up on your computer.
You need to install the software that came with it on your PC,
assuming you have on, and connect the GPS. Follow the on screen instructions. You may have to purchace new maps.
Tip Backup to your pc this time :)
Good luck
Aug 21, 2009 | Alpine PMD-B100 GPS Receiver
PMD-B200When i put my nav into the dock stationitgoesblank
I have a similar problem where my B200 just blanks right out and doesn't want to come back on until I pull it out of the head for about 1/2 hour! It also did not want to turn on outside of the head at all - I'm assuming dead battery. I phoned support here in Canada and they told me that it might be because the unit is not fully charged while in the head. He suggested that I pull the GPS out and try to charge it using the dedicated AC outlet for it. I'm trying this now! As for the firmware update for the B200, there ISN'T one as of yet. From what I've read, Alpine discontinued the Blackbird B200. Alpine support said that they are working on a newer firmware for the unit but I won't hold my breath if they discontinued the device!
Jul 24, 2009 | Alpine Blackbird II PMD-B200 GPS Receiver
I've got an error message and the gps is totally locked.. And Its not possible to eject it from my w505r...
Try keeping the paper only in the bottom tray (there's a tray in the bottom) Try pulling any paper out of the top and just close that top tray. Open up the head so that u can see the ink cartridges and turn the printer on and off and maybe it will center itself again. If it's still not working (even if lights aren't red and print head wont align in the center) try manually moving the head back and forth like 18 times so you can lubricate that rail in the back that's holding it. After that, re-turn it off and on again.
Jul 19, 2009 | Alpine Blackbird II PMD-B200 GPS Receiver
Download my blackbird gps updates
They FINALLY released the new map database April 08. Also now has a true 3d map and other performance improvments
http://www.alpine-usa.com/US-en/products/product_software.php?model=PVD-B102%20Software%20Update
May 26, 2008 | Alpine PMD-B100 GPS Receiver
Alpine Blackbird II PMD-B200 GPS Receiver Logo
79 people viewed this question
Top Alpine GPS Experts
Shehu Pro
Shehu Pro
richie46
Are you an Alpine GPS Expert? Answer questions, earn points and help others
