Question about Sharp Televison & Video
What should I do if no sounds comes from the television and the mute button is not on
    New Friend:
  • 19 Answers
Go to settings and look for sound output. Check main speakers not the rca output.
Posted on Nov 07, 2014
Philips HTS3440/37
Please elobrate further your problem.. i'm a bit confuse " If I press mute button it goes to mute,press mute again sound will come back on" This is normal.i.e. that is the function of mute button.
Sep 07, 2007 | Philips HTS3440/37 System
What does the speaker icon followed with an "X" mean on my Sony Bravia?
The sound is MUTED. Press the MUTE button on remote to UN-MUTE.
Sep 22, 2014 | Sony BRAVIA Televison & Video
No sound coming from LG TV 47LB5D
Are you able to hear sound from the head phone socket, if it has one? Do you get sound when you are playing a DVD player? Is any mute button is activated or jammed?
Aug 21, 2012 | LG 47LB5D Television
No sound on tv but volume is up
If you have an older style television and you have cable-then you have 2 remotes-somehow,the tv part went on mute but when you check your sound with the cable remote-it shows high level of bars which makes for confusion!Get out the old tv remote &select your menu then sound &take it off mute----You'll probably see see--sound off! Turn sound on and adjust your sound bars with same tv remote till just a bit more than 1/2 way up.That way you will not have to use cable remote to make it louder-much.In case,you forgot where you put your tv remote& only have cable one--think you can still get it off mute--byshutting down the cable part(which you have probably done several Xs by accident)---and then with cable light not coming on-right- only the tv light =try & adjust with cable remote by pressing mute button-should see MUTE go off!Then bring your cable button back into play and should be all set to go.If that does'nt work and your tv is still a tube tv might need a new part.But hope it was the simple problem.& that I managed to help you.Bye.
Aug 17, 2012 | Televison & Video
Volume Stopping Instantly
A few things to consider: if mute on the set is not on what about the box if you are using one?
Speakers could be switched off in the set.
There could be a internal / external speaker switch(not common but possible)
Sound on the set could be muted or turned real low or off.
if the image you see on the screen is there--either it is from the set or a box if one is used.
only a few things other than the sound circuit being bad will cause this--very few sets with actual no sound problems are around.
Apr 03, 2012 | Mitsubishi Televison & Video
Mute is on when I turn my vizio on. How do I
The OSD consists of several menu options: Picture Adjust, Audio Adjust, TV Tuner Setup, Parental Controls,PIP Set Up, or Special Features. When in the TV menu, select the Audio Adjust and make sure the mute is off. It may be worth checking the manual which is avialble from: http://www.vizio.com/downloads.aspx
Aug 20, 2009 | Vizio L32 32 in. LCD HDTV
Toshiba Regza 32C3000A tv sound keeps droping out, the mute button when pressed on and then off brings it back on. seems as if the tv is auto muting itself?
Could be a contact piece of the MUTE button from your remote that is causing it.
Go out and Big Lots or Radio Shack to get a cheap universal remote control(big lots would be between $5-$10) Pick up the code for it,and when the tv happens again,your the OLD remote MUTE button to turn it back on and then put away this remote control and use the new universal remote control.
However,if the problem is coming from the manual MUTE button on the TV,you need a repair tech, to fix it!
solutiondoct
Nov 10, 2008 | Toshiba Televison & Video
Blach rectangle bottom halfpart of screen
Salutations bachiche13,
It sounds like your "Text" feature of your closed captioning may be activated. It sounds like what you would want to do is go in to your television menu and select CC or Closed Captioning to mute or off.
Hope this helps.
Jon
Go Ahead. Use Us.
May 21, 2008 | Panasonic PV-DF2703 Triple Play 27 in....
Televison & Video Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
