Question about Quinny Buzz 3 Stroller
I broke the chain of the push bar.How i can fix it?
  • panagiotis
    panagiotis Nov 16, 2014
    Sorry,I mean the cable inside the push bar
  • Quinny Master
  • 1,629 Answers
Hi
Not sure what part you mean as there is no 'chain' on the Quinny Buzz. Please contact with images to our Facebook page for further assistance -
Dorel UK Customer Service
Posted on Nov 16, 2014
I have a Remington electric versa saw rm1635w and the chain won't spin around the bar what do I need to get it running again
there is a safety clutch that you disengage when finishing the cut
it disengages the chain from the motor drive by a dog clutch
pull the safety bar back towards the trigger and the chain will cut
if you leave the finger on the trigger and the chain jams in the cut , you push the bar forward and the motor spins free
if that doesn't work take it in for a fix as that clutch is failed
Nov 16, 2016 | Remington Garden
Timing chain
bent push rods could have been caused when the chain broke and not from the chain been replaced wrong or the timing out.
if the engine was running when the chain broke the cam would have stopped leaving all the valves in the same positon as the mometum of the fly wheel continued to turn the pistons in the cylendars could hav come up and hitting the valves and bending the push rods. and or damaging the cylendar head.
recommend removing the head and have it checked for damage, as well as replacing the bent push rods, and cylendar gaskit. once the head is checked and the valves are seated well. then replace and follow instructions in the set up for the pistons and cam prior to replacing the chain and setting the timing.
I hope this was helpful.
Oct 20, 2012 | 1991 GMC C3500
Chain brake broken could this be a reason for when cutting it pulls or cuts to the left or is it out of sync
Pulling to one side or the other usually a result of un even sharpening. Doesn't happen often with pro sharpened chains.
Your chain broke because it was weak ... or a few other reasons. Dont fix it ... not worth it when the dim possibilities are considered. Toss it and get a new chain or two or three or more.
Many saw specialists suggest you have a dozen chains or so., Rotate them through use ... when they are done for, replace the lot as well as replacing the clutch and maybe the bar as well.
Aug 26, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Change the chain instructions
General instructions are, if the machine has a chainbrake make sure this is off, loosen the side cover nut/nuts, wind the bar adjuster screw back to slacken the chain, remove the side cover, push the bar back to the sprocket, the chain should now be lose enough to lift it off the tip of the bar and un loop off the sprocket, now loop the new chain over the sprocket and around the tip of the bar, make sure the cutters on the top of the bar are facing away from the saw ( a pushing chain )now re fit the side/chainbrake cover, if the bar adjuster pawl is in the brake/side cover, make sure this aligns with the adjuster hole in the bar, re fit the bar nut/nuts finger tight, wind the adjuster screw in so as the chain sits snuggly all around the bar, with a gloved hand pull the chain around the bar manualy, it should pull smoothly, lift the tip of the bar up and fully tighten the nut/nuts, run the saw, there will be an amount of initial stretch, slacken the bar nut/nuts and re tention.
Aug 24, 2011 | Poulan Pro Chain Saw 46cc 20"
I can't get a replacement chain back on the bar on
The 450E is a tooless system, make sure the brake is off by pulling the handgurd fully back to the top handle, flip up the lever on the big grey fixing nut, undo counter clockwise, wind the grey knurled adjuster wheel facing out of the cover fully back, remove the chainbrake side cover, push the guide bar fully back toward the sprocket, you now have enough rome to replace the chain onto the guide bar rails, now re fit the side cover, make sure the adjuster pawl in the cove aligns with the adjuster hole in the bar, re fit the big fixing nut finger tight, wind the adjuster wheel down to re tention the chain, when the chain is snug all the way around the bar tighten the nut fully.
May 29, 2011 | Husqvarna 450 e-series 18" Chain Saw
I broke a tooth on the sprocket that drives the chain
Sprockets are a wear item. Just like your bar/chain. Depending on the brand of the saw, it should be readily available as it is designed to be replaced easily and quickly.
Jan 12, 2011 | Husqvarna Chain Saw 20" Bar
Chain fell off poll, trying to figure out how to put it back on.
On the side of the saw where the bar (what the chain goes around/rides on) where it connects to the saw there are a couple nuts. Loosen them up, push the bar back towards the saw to put slack in the chain, wrap the chair around the bar making sure the bottom of the chain is in the groove on the bar and tip of the bar, then push the bar forwards away from the saw to take out the slack in the chain. Hold it tight and tighten up the two nuts. Depending on your model of pole saw, you may have only one nut and a plastic guide that keeps it straight. Same concept though. Loosen the nut, push bar in, put chain on, pull bar out, tighten nut.
If you've ever done it on a bicycle, it's the same concept. Loosen nuts on back wheel, push tire forwards and chain gets loose. Pull it backwards and chain gets tight.
May 11, 2010 | Remington Polesaw Wizard
My crank/chain is skipping on my mongoose pro bmx. This just started when I was riding it, and it skipped. The chain is in the right right place and does not seem to be skipping place, but the crank is...
It seems you will need more tension on the chain. Place the bike upside down, loosen the nuts, grab a broom stick or bar and place it between the rear tire and crank housing straight up and down with the handle bars away from you, push the bar away from you. When done properly the tire will come toward you tightening the slack in the chain. While you hold pressure on the bar tighten the nuts and WALLA.
Dec 04, 2009 | Cycling
Electric chain saw chain adjustment. How loose should it be?
the chain should not be sagging from bottom of bar.when you tighten the chain push the nose of saw up so that all of the slack is out of the chain.chain should snap back in the bar if you pull the chain up and let go.when i adjust a chain i push the saw forward to make the bar go up and stay there while i tighten the nuts.hope this helps, let me know
May 11, 2009 | Desa International Remington 14" Electric...
Threaded stud that holds chain bar broke off, how do I get it off.
If it is broken off at the saw, you need to get an ez out to remove it - follow the instructions with it. pretty unusual for both studs to break off at the same time. Hope this helps you, Rick
Apr 18, 2009 | Garden
Quinny Buzz 3 Stroller Logo
53 people viewed this question
Top Quinny Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Michael Vincent Cruz
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
