Question about Tablets & eReaders
The reset button is gone so how can I reset it to get past my screen lock
    New Friend:
  • 19 Answers
Enter your tablets make and model followed by "hard reset" into your search bar, example "Apple Ipad hard reset". Choose one link and follow their instructions. Problem is that everything in your tablet will be erased.
Posted on Nov 07, 2014
I forgot the password to my Kurio interactive. How do I reset it?
Password Was Forgotten ¶ If you forget your Kurio log-in password, you will not be able to get past the lock screen. The only solution is to perform a factory reset. Performing a factory reset will erase everything on the Kurio and return it to exactly how it was when you took it out of the box. To perform a factory reset, unplug the Kurio and turn it off by holding the power button for 5 seconds until the screen displays "Power Off, Shutting Down..." Once the device is off, press and hold the volume down button and power button at the same time until the screen lights up with "KD Interactive." Release the power button, but continue to hold the volume down button until the "DROIDBOOT" screen appears. Then, navigate to the "RECOVERY" option and select it by pressing the power button. This will prompt a new menu, from here select "Wipe Data / Factory Reset." Your Kurio will go through a long restart phase and then welcome you to your new Kurio
Jan 13, 2017 | Tablets & eReaders
Forgot pin code
Angie, You can may have to do factory reset. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Forgot Lock Screen Password or PIN
http://forums.androidcentral.com/samsung-galaxy-note-2/250290-omg-forgot-pin-can-t-get-past-lock-screen.html
Tablets and eReaders Faq
How to Factory Reset Your Android Phone or Tablet When It Wont Boot
Apr 07, 2016 | Tablets & eReaders
Why will the tablet not move past the initial start up screen?
It could have hardware problems. It could have software problems. To troubleshoot software problems, when on the initial start up screen carefully introduce a paperclip end into the *Reset* button hole until you feel a little click. Your device should then turn off automatically. Some start up again automatically, some don't. Give it a minute or so and it it doesn't start back up by itself. Push and hold the power button as usual.
This should clear up any software problems and this doesn't cause you to lose any data or changes you've made.
Hardware problems such as a memory chip gone bad will not be helped by a Reset Button reset nor will they be helped by a *Factory Reset" which is done by holding down a combination of Volume(-) and Power buttons to get into the Android factory reset options text list. These are drastic and will cause you to lose any and all personal data and changes you've made to the device. A factory reset will put the device back to new condition. But, alas, even a factory reset will not help if you have hardware problems.
May 10, 2015 | Tablets & eReaders
Trio 10 1 turns on but wont go past the next screen to see my apps
Press power and volume + buttons together until reset screen comes on, then select factory reset!
Nov 09, 2014 | Mach Speed TRIO Stealth G2 10.1" 16 GB...
How do i get it off the android screen so it will show the lock screen?
Sounds like its borked.
Have you pressed the reset button on the back - pinhole - press it with a pin its a long shot.
The real fix is to go into recovery mode using the power button volume up combo. Then select the restore tablet option.
If none of that works you will have to sideload or reinstall using an sdcard a replacement OS - Try cyanogenmod - your tablet will have to be rooted and have the cm bootloader installed however - tablets are not easy things to repair when the software goes belly up.
May 12, 2014 | Shopnbc Zeki 10.1" LCD Android 4.1 8GB...
Maxwest tab-9155 won't load past android screen
Hi, you can try resetting by following the below steps. It works for most tablets.
1 turn off the tablet
2 press and hold the power button and keep tapping the volume down button at the same time.
3 it should take you to recovery screen. Go to factory reset by using volume button and select by using either the center button on the tablet or the power button if there is no center button.
please reply if it helped
Mar 24, 2014 | Tablets & eReaders
My daughter's zeepad will turn on but only to the screen that says "android". it will not get past this stage. I don't see any reset buttons or a way to access inside the unit to find one. What do
If a factory reset is required. Press and hold both Volume buttons and the Power button simultaneously; an Android logo with an exclamation mark should appear. Press both Volume buttons at the same time to open Recovery Mode and use the Volume Up and Volume Down buttons to navigate.
Jun 16, 2017 | ZEEPAD Tablets & eReaders
Model q8(a-1) forgot password
Locked android. Forgot google account. Need to reset. How to do this and what buttons to use.
Jan 26, 2013 | Universal Q8 7"" Capacitive Screen Android...
How Do I Get Past a Pattern Lock MID8024
  • Turn off the unit.
  • Plug the unit into an electrical outlet.
  • Take a microSD card out of the slot. (Empty the microSD card slot.)
  • Press and hold down the power button for a few seconds while pressing and holding down the "Home" (Silver Push Button) button. (Both "Power" and "Home" buttons must be pressed down until he see the phrase "upgrade system activated" in the middle of the screen.
  • Release both buttons once the phrase "upgrade system activated" appears on the screen.
  • Wait until it reboots. You will see the following sentences on the left top corner of the screen: Can not find any update image. Press MENU/KEY_VOLUMEUP key to init SD card, Press BACK/KEY_VOLUMEDOWN key to cancel.
  • Press the "VOLUME UP" key. The volume up key is located at the left side of the unit and the button is closer to the built-in camera than the volume down button.
  • Wait until it finishes making a partition and shut down the system automatically.
  • Once the unit is turned off, your system will be reset to the factory settings. Thus, your previous data are lost at this point.
Aug 23, 2012 | Coby Kyros MID80244G Tablet
Tablets & eReaders Logo
90 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
