My mackie m800 fell an now it plays for about 30 to 40 min an then goes into protection mode the fan goes into high speed an it mute the audio
  • 38 Answers
Sounds like it's overheating or otherwise overloaded. Check the front panel channel status indicator to see if it's a heat issue (hot vs. norm). I'm guessing there's a short at the output that's putting it into overload after 1/2 hr.
http://www.mackie.com/pdf/M800_om.pdf
Posted on Nov 18, 2014
Testimonial: "hey thanks for the ans an it really mute an the hot led comes on when i check the heat sink the big out puts are not hot but the drivers are hot turning on the hot indicator,should i just change out all the drivers"
I have a lennox pulse 21 And if i set the thermostat to auto the unit kicks off after a min and the limit switch goes over 200. But if i keep the fan on the unit works fine.
See if you blower speed is set to low speed in the heat mode.
I think what might be happening is the blower is set to low speed in heat and when you switch to automatic, the blower is switched to high speed. You may have to change the blower speed to high in the heat mode. If not you may have an airflow problem such as a Dirty filter, ducts not sized right, dampers on the room outlets closed.
Dec 12, 2016 | Heating & Cooling
Jl 1000/1 goes into protective mode with low frequency
Do you have a capacitor????? If not, when its up loud and hitting hard it might be going into protection because of a voltage sag....If it goes below 11.8v they will usually do that.....Get a multi meter and put on the hot and ground of your amp when its playing loud and see what the voltage is dropping to.....If its going below 12v, thats your remedy...gd luck....
May 02, 2012 | Jl Audio 1000/1 Car Audio Amplifier
My Toshiba Portege M800 console buttons (Mute, DVD, Play/ Pause, Stop, Rewind, Fast-forward) are not working. What to do?
use the driver cd's delivered with the laptop to install these functionalities. if you don't have these cd's, you can download all drivers from the toshiba website.
Apr 21, 2010 | Toshiba Portege M800 Notebook
Getting out of protect mode I have a Denon 787 receiver. It was working fine for 8 months. All of sudden, my reciever goes into protect mode after playing for about 30 min. Right after it goes into protect...
most of the receivers come with a cooling fan inside see if its working they usually work when you turn the volume up,, if its working that means you are playing it to loud if you lower the volume a little it will play just fine..( if the fan inside is not working thats the reason it goes into protect mode and it means you must have it repaired,, it goes into protect mode to prevent furter damage to the unit or the speakers,,
Dec 18, 2009 | Denon AVR-787
AMp does not display any LED read out
Amps have a part inside that is made to keep the channels equal. The problem is that when there is nothing hooked up to the second channel, then this goes bad and goes into protect. It is really hard on an amp to use just one channel.
Sep 26, 2009 | Bob Mackie Mackie M-1400i Power Amplifier...
Cooling fan not working
check the solder joints from the fan to the board and if they are fine u will need to get a new fan
Apr 17, 2009 | Bob Mackie MACKIE M1400/M1400i Car Audio...
Technics amp su-vx800 goes in to protection mode after approx. 10 to 15 mins of play depending on the volume level.switch it off for 2 mins and it operates again.Could this be a faulty muting ic AN7073, a...
yes it can, it sounds like its over heating, make sure that your product is able to get fresh circulated / cooler air
if it already is, then it probably is a faulty product.
Nov 22, 2008 | MA Audio Hard Kore HK-898 Car Audio...
Ge profile artica refer fan speed PSS29NHPBWW
hmmmm no thats peculiar it will slow down and start back each time the doors are open also fan will turn on even if fridge is turned off if a door is opened londer than 3 mins. If the fan still operates irradicly even in the liner protect mode (turn refrig off open door for 3 mins, fan turns on) then the main board is faulty not uncommon for these refrigs.
Sep 28, 2007 | Refrigerators
Amp heats up and goes into protect mode
Hi Saint108. You're describing it well, and i know what the problem is already. The MA audio amp, can't hold with a 2 ohm load. It's too low for that amp, that's for sure. Those are budget amps and they are not well built enough to handle low ohm setups like that. It's overheating and there's no ways around it.. Other than wiring your subs differently ! Just wire your sub directly (not in parallel) in a 4 ohm load, you will notice it will stop overheating that much. Do it quick, you'll most likely fry your amp giving it such hard work !! The HUM you're hearing could be related to it also. Try that, and keep me posted on the status. Thanks ! Cheebster.
Jul 02, 2007 | MA Audio Hard Kore HK-898 Car Audio...
61 people viewed this question
 Grubhead
Grubhead
