Question about Home
How do I replace the MR16 bulb?
I have a Cooper Lighting EDISON ET7498P recessed fixture in the ceiling. How do I replace the MR16 bulb in the fixture? I looked on the Cooper Lighting website but did not see this fixture, even in the catalog.
  • 4 Answers
SOURCE: Ceiling fan lights do not work
You may have shorted out the light kit. Did you remove the other bulbs and put in new ones? They may have all blown when you heard the noise. Try that first, and if it still doesn't work, you may have to buy a new light kit. They are not expensive, and you can buy one without the glass bulb holders or cans, whatever you have. Then you can still use yours after you install the new light kit. Good luck!
Posted on Jan 07, 2008
  • 4 Answers
SOURCE: Minka aire ceiling fan
This may not apply. There could be an electrical problem. But if you installed the bulb with your hand, the oil on your skin can cause the buld to heat excessively and fail. I suggest you use the packaging or part of it when installing it, taking great care not to touch it.
Posted on Mar 31, 2008
  • 19 Answers
SOURCE: need to replace socket in Hi hat ceiling fixture
Do you have a discription? In order to get to the main wires of a flush mount fan turn off power to fan, remove Lt kit if applicable, Take off blades. Does this sound right ?
Posted on Jan 04, 2009
  • 75 Answers
SOURCE: Hampton Bay Ceiling Fan Plastic Burning Smell
I think you have already figured out what the problem most likely is; 60 watt bulbs. Down-size the wattage or install 'energy saver' bulbs if they will fit the application. Instead of counting on these units for extra lighting, perhaps think about Track lighting to fill in those ares that need more but subtle light.
Good luck. :)
Posted on Apr 26, 2009
  • 136 Answers
SOURCE: How do i remove the light to change a light bulb?
i looked it up online and they called it a:
Single Bowl Twist and Lock Light Kit.
Some things i would suggest:
  1. push it up and turn (like when you open a medicine bottle.
  2. try to look for a spring action peg that clicks in automatically around the glass dome that might be locking it...
please comment my solution :) thanks
Posted on May 31, 2009
Our ceiling was painted and when they replaced our Lightolier track lighting, one of three lights does not work. We tested bulb and it is good. Another light on the same track also works. Please advis
If it is track lighting and the fixtures were taking off of it and it was working before check to see if there is a switch on the fixture may have gotten turned off or possibly the fixture is turned the wrong way on the track or may be not getting a good connection on the track if you are turning the fixture the right way it should go on easy . Hope this helps
Oct 23, 2016 | Home
Can I replace the 13 watt CFL bulbs in my fan light fixture with a higher watt bulb
The bulb fixture itself should tell you what the max wattage is that you can put in there but they are normally at a 60watt limit.
Feb 25, 2015 | Hampton Bay Dryers
We have Lithonia 2 bulb fixtures in a recessed ceiling. We currently have 2 (25) watt bulbs in them. What wattage can I upgrade to ??
The ballast inside the fixture is rated to operate 2 25w bulbs. You can't put higher wattage bulbs in this fixture, unless you change the ballast. Sorry.
Sep 22, 2014 | Lithonia Lighting Fluorescent Flush Mount...
Replaced sylvania 26 w 4 pin in overhead light fixture and it is not working
replace the ballast almost always these lights do not usually burn out the ballasts go bad
Dec 13, 2012 | Lithonia Lighting Fluorescent Flush Mount...
Replace GE 50W Halogen bulb in ceiling fixture
if fixture is as shown, remove the nut in the middle of the fixture, remove the lamp, and replace it, note donot touch the lamp with your fingers, this causes lamp to fail, use a cloth to install then replace in reverse as you took it apart
Sep 27, 2011 | Universal Lighting and Decor White 11"...
How do you take the light fixture apart to fix the balace?
You may find that a new fixture is the easier and cheaper way to go as some ballast can be expensive and hard to find the matching style. A similar style fixture at Home Depot or Lowes cost, in a 2 pack about $18.00. Add a CF bulb to it for another $4.00 and you have a decorative similar fixture. Some ballast cost anywhere from $9.00-$50.00. If you wish to replace the ballast: (turn off the power) remove the globe, remove the existing florescent bulb, take the fixture off the ceiling (usually two screws) remove the wire nuts, make a small diagram of the existing wires and the color codes, take the ballast to the Home Depot or Lowes first, match the ballast. Now reverse the process to replace the fixture. Hope this helps. Good Luck!
Douglas
Oct 31, 2010 | Universal Lighting and Decor White...
How to change a recessed halogen lightbulb?
usually the trim ring that rests against the ceiling just pulls off
Jan 15, 2010 | General Electric Ge Lighting 18534 "ge"...
I have a problem with my kitchen's recessed lighting. For some reason, the six bulbs will go out during the evening hours, then come back on. There is no pattern, with one, two, three or four of them out...
It sounds as if you may have higher wattage bulbs and/or the wrong type of bulb installed in the can fixtures than the recessed cans are rated for.
When the wattage of the bulbs is higher than the rating of the fixture, and/or the wrong bulbs are being used, the recessed can's thermal overload device will shut off the light, to prevent damage and a possible fire situation.
It is unlikely that you've got a faulty dimmer, since you state that not all of the lights go off at once, thus it can be narrowed down to each can and thus the thermal overload being the culprit.
I would suggest you look inside the recessed can light fixture and determine what the maximum wattage bulb you can use, (60, 75, 90 watts, etc.) and use the next lower wattage bulb instead. I also install only Halogen bulbs in recessed cans, (they have a flat lens vs. a rounded bulb lens area like PAR type bulbs). Halogen bulbs are also the most efficient incandesent bulb that provides the whitest light possible and directs more light (and thus heat) downward away from the recessed can.
I avoid using a standard light bulb or PAR type bulbs in any recessed can fixtures as they tend to heat up quite a bit and cause the thermal protection to trip frequently.
As a Master Electrician that has installed literally thousands of recessed fixtures and dimmers, I can say that my customers prefer the Halogen light over standard bulbs and they last longer too.
I hope you find this Very Helpful and best regards!
Sep 17, 2009 | Lutron Diva Dv-600P Light Control By
Good luck. :)
Apr 09, 2009 | Hampton Bay 46056 Callaway II Ceiling Fan
Home Logo
52 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
