Question about CellPhoneTrek.com LG Optimus Dynamic Multi Color Ice Cream Cones Case
When i turn my phone on all i get is a light colored picture. My phone dosn't turn on
88 landcruiser dosn't start and no lights on the dash
HAVE YOU HAD THE BATTERY TESTED? dO SO. aLSO CHECK THE BATTERY CALBES ARE THEY CLEAN AND TIGHT AND FREE FROM CORROSION?
Nov 05, 2012 | Cars & Trucks
Wire touched and now windows or radio dosn't work
Check you fuses at both the inside fuse box and the underhood fuse and relay box near the battery, use a 12 volt test light with the key turned to run.
Sep 28, 2012 | 1992 Lincoln Town Car
Electrical problems with a 2002 Satun SL 200, the electrical door locks dosn't work, the mirror adjustments dosn't work, the dome light dosn't work. The engine runs good. head lights work
check all your fuses in engine compartment and under dashboard engine check light comes on every 3000 miles for oil change reminder
Jul 23, 2012 | Cars & Trucks
Dosn't shift when runing
First check all the linkage bushes, are they worn and need replacing. If they're OK it could be your thrust bearing (part of the clutch mechanism) has seized.
Dec 20, 2011 | 1990 Mitsubishi Mighty Max
Reverse lights:Lights dosn't turn on.I change the lights and still no results
Check the reverse light switch. Remove the 2 terminals that connect to the switch and jump them. If the lights come on replace the switch. If they don't check if you have power at the switch by using a test light or tester. If there is no power check the fuse.
Oct 05, 2011 | 1994 Toyota Camry
My phone "died" N72 during
Hello!
try this tips If it dosn't work that's mean Death ,
rest your cell phone follow this tips if you want to do this
holding 3 keys;Menu+ Green dial key+, * Star key,
- Press the three keys and keep them securely down and do not release.
- While the keys are still down, turn the power on.
- Do not release the three keys until you see the prompt for the home city.
If it doesn't work, you need the flashe visite cellular phone technicien
good luck
May 23, 2011 | Nokia N73 Cellular Phone
Just replaced the friction plates, the clutch spring hub does not seat onto the splines. What did i do wrong?
G'day.
You don't stipulate your bikes model or year which makes this a bit harder.
When you fitted the outer hub(the one the springs sit in)- you've probably miss-aligned it.
Remove the springs again
Remove the hub- & re-fit over next set of posts(turn the outer hub so it dosn't go over the same posts as before) & it should slot all the way in.
If it dosn't-try again
It looks like the outer hub can fit over the spring posts in any position- but it can't.
I hope this works for you.
Regards Andrew Porrelli
May 20, 2011 | kawasaki VN 1500 Vulcan Classic...
My h2o mop will not allow any water flow the red light comes on after afrw minutes the green light comes on but there is no water or steam flowing out what can i do
Try running a solution of 1 part white vinegar to 2 parts water,turn on & let run through if this dosn't work take the mop head off ( unplugged of course) & poke a needle or paper clip through the hole replace head & try vinegar solution agian. It worked for mine you need to clean out lime scale.
Apr 13, 2011 | H2o TR220002 Steam Cleaner
My tv screen on my nes is really blurry. it usually happens when it is white i play smb3 and the whole game is blurry which makes the game unplayable. could it be my av cables or 72 pin connector
it could be your TV, if your tv has video adjustment, just mess around with the options until the picture comes in clear, if that dosn't work, than it's probably the RF box on the motherboard (if you wanna know what that is search it up, but it's very technical), try getting a famiclone, new third-party NES's, i recommend the Retro Entertainment System, it works great and cheap on some sites. If that dosn't work, try a diffrent TV.
Sep 02, 2010 | Nintendo NES Console
Have picture in black & white no color. audio
Hi,it definetely sounds like the color wheel.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.Found your color wheel here: http://www.discount-merchant.com/MITSUBISHI-00-L3603-002-p/1162430.htm Have a bless one!
Mar 29, 2010 | Mitsubishi WD-52525 52" Rear Projection...
CellPhoneTrek.com LG Optimus Dynamic Multi Color Ice Cream Cones Case Logo
596 people viewed this question
Top CellPhoneTrek.com Cooking Experts
Tom Chichester
ray gallant
Are you a CellPhoneTrek.com Cooking Expert? Answer questions, earn points and help others
