Question about Welding Tools
Wire is stuck in feeder and I can't get it unstuck and pulled out. Any ideas on how to get the stuck wire out
  • 21 Answers
Your going to have to take the feeder apart
Posted on Nov 07, 2014
luis_david
  • 407 Answers
SOURCE: wire feeder need wire guide
You'll find it at any welder store, try your nearest Praxair store.
Posted on Jan 02, 2011
  • 35 Answers
SOURCE: Have a Hobart Beta-Mig 170 Wire will not feed
First make sure the nozzle tip is free of any debris and the wire will slide easily. Lift the case and go to the wire feed unit. Loosen the pressure nob then lift up to release the pressure wheel. Make sure the bottom wheel ( should have two grooves, one for .35 wire and the other for 025 wire.) Make sure the Wire Feed Tip is also free and it allows the wire to pass through. Pass the wire through the feeder across the drive wheel and into the hose. Allow the pressure wheel to drop, then lift the pressure know to the upright position. Turn clockwise to put tension on the wheel. Make sure the gas is OFF, turn power on, depress trigger switch. This should allow the wheel to turn and feed the wire.
Posted on Jan 17, 2011
  • 12 Answers
SOURCE: Hello, I have a Hobart
Sound like you have a bad trigger on the gun. Does gas spray when you pull the trigger? Check the wire plug that goes from the pistol to the unit. It should be under the liner hose where it connects to the machine. Then use a voltage meter on the wires going to the drive feed motor, and see if you get current when you pull the trigger. If gas doesn't spray neither, sounds like you got a bad trigger switch
Posted on Jul 31, 2011
  • 1212 Answers
SOURCE: Installed new spool wire tangled in wire feed
If the feed wheel mechanism does not move, check for voltage at the motor. If there is none present, you need to look for a failure on the control board, which may be a fuse, or even one of the SCR's. Often an 8 amp 200 volt type.
Posted on Dec 29, 2011
  • 11 Answers
SOURCE: my sp 135 welder is burning the wire
If the wire is melting off in front of the feed rollers . Then the torch power cable is probably open circuit , inspect the cable as it leaves the front of the unit, it usually gets damaged there.
Posted on May 14, 2014
A new welding machines lincoln 500s with wire feeder linc feed 45 co2 gas shielding ... when i begin the welding process continueous just for 10 seconds and then the wire feeder stop and then after 50
the obvious, yet sometimes overlooked problem is to check if the wire feeder rollers.do you have the proper tension set?(did you do the wire test when you shot the wire to see if it bends or stops)
Apr 11, 2013 | Lincoln Electric Welding Tools
Ism coil roofing nailer will not hold nails in striking chamber after they advance
The feeder area of the nailer incorporates small levers on both sides of the nails. On the body side, the spring loaded feeder retracts and pulls forward the first nail. On the latch side small spring loaded arm/s hold the nails in place once they are pulled forward. Open the latch and push on both the feeder and the retanier for firm spring tension. On some nailers, due to wear, the grippers on the feeder tend to wear off allowing the nail to slip out of place. On other nailers, the feeder arm/shaft tends to wear and alows the feeder to move out of alignment (check if the actual feeder arm can move from side to side). The feeder shaft should move forward and back with no side to side movement. Finally, some coil nails are welded together with too stiff of wire. After the first nail is driven, the second nail will have one or two strands of wire pointing out not allowing the nails to move into position. After first shot, the two wires should be cut off or bent down out of the way. Good luck.
Nov 02, 2012 | Air Tools & Compressors
Hello, I have a Hobart 180 and the wire feeder motor won't run. I replaced the wire feed motor and it still won't run. any ideas?
Jun 27, 2011 | Hobart Welding Tools
Drive wheel for wire feeder starts slow as if it is stuck at the begining, even if there is no pressure on the drive wheel.
check the feed gear that pulls the wire off the roll there are lots of little teeth on this gear if there striped off the wheel slips also if the welding wire is rusty it will jam in the neck tube
Aug 11, 2010 | Lincoln Welding Tools
Feb 25, 2010 | Hobart Welding Tools
My welder just stopped welding. It's a Telwin 220 Mig. The fan is still running but there is no noise from the welder and the wire is not feeding. I had only used it for around 30 seconds before it...
your feeder may need adjusting or more commonly the tip has tacked itself on the edn cap
keep the line as straight as you can & keep feeder compartment clean!
keep plyers handy for when wire is stuck in the tip
if you need to replace wire spool or a brakage of the wire make sure the wire is free or BURRS b4 you put it in the tube or you will damage the tube!
Cheer Rob.
Jul 16, 2009 | Astro Pneumatic 3 Pk. MIG Welder Torch Tip...
Im tryint to conect my wire feeder
ask weld tech at a welding supply store and ask if your components are compatible (since most wire feeders are 24 volts).
Dec 19, 2008 | Welding Tools
Miller axcess 40v wire feeder
give me a day or so and i will have the solution for you
Sep 11, 2008 | Welding Tools
Hp officejet 7310 document feeder cover
no my friend.. just opened back cover the wire connected in pcb just remove then reconnect. thats all..
Aug 18, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Welding Tools Logo
66 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
