I've got 15psi at the regulator but my flame isn't as blue as it was in the past. Last yr. It's orange at top and flickers alot. Its a3 burner with a thermostat. Sometimes only 2 lite and the 3rd blows crazy noise. Any suggestions?
    Problem Solver:
  • 12 Answers
The first thing I'd check is for a restriction in the combustion air. Sometimes birds and bees make nests there.
Second is check orifice for soot or carbon build up.
If I had make and model of furnace I could get more info.
Posted on Nov 07, 2014
Therinnaiguy
  • 1420 Answers
SOURCE: Laars boiler pilot light is blown out when burners shut off
Time for a cleaning and gas pressure test.
Posted on Dec 05, 2008
  • 3 Answers
SOURCE: Glo-Warm flame problem
Hope this helps, here is a link to the owners manuel
http://12.153.20.74/manuals/124011-01B.PDF
Posted on Feb 05, 2009
  • 5 Answers
SOURCE: empire corcho ventless propane wall heater 15000 btu
LOL.... your fuel is not boiling.... the closer propane gets to its vaporization point (-44%F) the less vapor it produces. clean the snow off of the 100# or lay it on its side to give it more surface area for vaporization.
David Lawrence the propane dude
Posted on Dec 10, 2009
  • 221 Answers
SOURCE: furnace howls when burner lights for 30 or so
Hi, the howling you describe is pretty common as gas heaters first come on. NG or LP gas is delivered at a pressure much higher than appliances actually use, step down regulators lower the pressure as the gas flows. So, when you first turn your heater on, the pressure is a little high until the flow causes an equalization of pressure. You could contact your gas supplier and ask them to check your pressure and tell them you suspect a building regulator. If the pressure were to build too high it could cause leaks or damage the appliance controls.  Good luck.
Posted on Jan 10, 2010
  • 188 Answers
SOURCE: infared burners with flame at the tops of them
This may mean that the plaques are cracked, if they are cracked you cannot repair them, you would just have to replace them. You can contact Master Parts they may be able to help you. You can contact them toll free at 800-446-1446. Thank you
Posted on Feb 08, 2010
Viking grill burner low flame
If this burner has tube type, You can loosen a screw in the front of burner and slide open air rater vent just a little just make sure not to open to far. blue-ish/orange flame is what your looking for
Apr 10, 2015 | Viking 500 Series VGBQ53002RELSS 30"...
Flame is just orange
there might be a cloq in line or burners like spider webs
.the air and gas is not the right ratio that is why flame is not blue
May 27, 2014 | Fiesta Blue Ember Gas Grill
Orange flames on two Blue-Flame heaters, dual fuel, currently running propane.
Could be that the burner needs cleaning dirt in the burner tubes
Nov 02, 2012 | Blue Flame Heating & Cooling
Our Uniflame Grill has a round outer burner and a round inner burner. The outer burner has a large orange/yellow fllame. The inner burner has a small blue flame. Is it normal for the inner burner to...
Bob, your wife is partially correct. However, both burners should have blue flames with orange tips. Cleaning the burners and the their venturi valves, should solve the problem. When I say cleaning them, I mean removing and cleaning them.
Hope this helped you and Happy Grilling!!
Jun 27, 2011 | Uniflame FG2204C Grill
Kenmore lp gas sealed burner stove,when opening or closing the oven door the top burners decrease in flame size and go out frequently.
This seems like a pressure regulator / flow problem. If you are running more than one appliance from bottled gas this can occurr if the supply pipe is not of sufficient size. When 'wafting the door' you are increasing air flow to the oven burners which in turn will consume more gas to balance the burn, this starves other burners that are running at the time.
Cure; increase regulator pressure (remove the foil cover to expose the screw) with the top burners alight adjust the screw 1/4 turn at a time until the flames are bright blue at heart and organge tipped. Increase as much as you can without the falme distorting away from blue/orange. If this doesn't cure it you may need to increase the size of your supply pipe to 15mm so that the volume of gas is greater and then split it off to normal lpg pipe to each apliance thereby creating a more even flow of supply. Often a system using say heating and gas fire is perfectly fine but add another appliance like a cooker or change your cooker to one which has more powerful burners and you can expose weaknesses in the flow system.
Jan 15, 2011 | Kenmore Kitchen Ranges
My ge gas stove works, but the flames just don't seem big enough. even on high, it takes forever to bring a covered pot of water to a boil. The flames seem even, mostly blue with some orange/yellow. any...
There can be poor air mix ( oxygen) for the flame to grow up. so remove the burner and use a good metal brush and air jet to clean off allt he crust and dirt of food lodged into the burners.
Now if the regulator gas fflow is down then your jet is blocked. If so you might have to remvoe the regulator to see that the jet is cleaned out . use a thin pin and airjet to clean.
Sep 16, 2010 | GE Spectra JGBP35 Gas Kitchen Range
Propane flame is not blue but too high
A yellow or orange flame means (1) too much fuel, or (2) not enough air. Make sure the air ports where the regulator attaches are clear and that spiders or bugs haven't built a nest in the burner tube. If that's all clear, it's likely that the propane regulator has failed and is allowing too much fuel to enter the burner tube. The regulators are inexpensive and are not repairable; get a replacement unit.
Oct 08, 2009 | Weber Gas Go-Anywhere Grill
Top Burners have a poor flame. How do I access the burners to adjust the flame ?ps No Owners Manual available. Tappan Millennia.(w/digital clock.)
you dont adjust the burners,either you have dirty burners and need service or your gas pressure is wrong,is the flame blue?or has it some orange flickers in with the blue,then you need to clean orfices and tubes
Jul 16, 2009 | Tappan TGF320 Gas Kitchen Range
Burner flame on GE 5 BURNER cooktop (JGP637) is orange
You have trash, corrosion or a mis-aligned part.
Check and repair these and you will be fine.
Feb 20, 2009 | GE 36 in. JGP628 Gas Cooktop
Heating & Cooling Logo
43 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
