HOW DO THE THERMOSTAT CONNECTIONS GO ?
I NEED TO KNOW HOW TO GET THE SERVICE MANUAL
    Master:
  • 602 Answers
Terminals on the thermostat have letters Match the colored wires to the corresponding letters.
Posted on Nov 10, 2014
1982 Honda GL 1100 Gold Wing change thermostat
Hi, Anonymous for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing and printing please click on the blue links below. Good luck and have a wonderful day.
To anyone who is changing the thermostat in gl1100
Thermostat fan switch GL1100 Information Questions goldwingdocs com
Honda GoldWing GL1100 Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda Gold Wing GL1100 Owner Manual
May 19, 2014 | 1982 Honda GL 1100 Gold Wing
My 98 roadglide wont spark
Hi Anonymous, you know if you are going to work on your bike your going to need tools, and the very first and best tool you will ever buy should be a factory service manual. That being said here is a list of could be's: spark plug, spark plug cables, ingnition coil, ignition module, cam position sensor, and my personal favorite wiring, open, shorts, grounds, loose or corroded connections, pin connectors, connector blocks, fuses, circuit breakers, battery voltage and cable connections. Your service manual would have paid for itself, just in diagnostic fees on this problem. If this were my bike I would test my cam position sensor for integrity first. Good luck
Apr 11, 2014 | Harley Davidson XLH Sportster 883 Hugger...
Rheem Furnace
do you have a standing pilot or electronic ignition furnace........you could have a problem with a safety switch, bad electrical connections, electrical short, circuit board issue, hot surface igniter issue....etc...........need to know the type of furnace
Dec 05, 2013 | Heating & Cooling
Need to know wiring diagram for IMIT TR2 9325 thermostat
The three connections are labled (C),(1),and (2). (C) is common (useually the white wire). (1) is hot power into the thermostat (black wire). (2) is ran to your heater. So when the thermostat is turned on it will connect (1) and (2) until it reaches tempature. Hope this helps.
Nov 20, 2011 | Cars & Trucks
My thermostat wires got pulled out of my outside unit and need to put them back but dont know where to start. The wires coming out of unit are blue and yellow and the norm thermostat wiring witch wires go...
Hello Cadbiad Jason,
I understand that your wires go to you outside unit (condensor) have been pulled out. To start with you have two thermostat wires look like telephone wire, and three power wires a ground usually bare or green, a white 120 and a black 120 volts.
I would be glad to help you with your problem. The first thing you need to do is shut off the disconnect box located by your unit as you do not want to get shocked by 220 volts.
1. Disconnect all power to the unit and turn off the thermostat.
2. Take the service panel off the side of the unit (1/4 or 5/16 screws)
3. The service panel you will notice a contactor this contactor will have two connections on the front and back for the white and black wire one side is for power from the disconnect the other side is the power going thru the unit to its parts. Make sure all of these connections are tight.
4. On the sides there are spade connectors one of your thermostat wires goes to one side and the other one goes to the other side (it does not matter which one goes where on a two wire non heat pump unit) you can wire nut each wire to the the ones if they are still usable. If not you will have to crimp new ends on your wires.
5. Replace the service panel
6. Turn the disconnect back on
7. Turn on your thermostat and make sure the unit turns on
If you have any further questions about this unit please fell free to post them to this thread and I will be happy to assist you. Thank you for choosing FIxYa.com
Justin
Mar 26, 2011 | Goodman Heating & Cooling
I need to replace my thermostat on my ge chest freezer model #fcm7sudww, I lost the wiring diagram and I need help to rewire. Thanks
Wiring diagram of the chest freezer turned into chest fridge. The junction box is not required if all connections are made inside the fridge service compartment. Active (A) connection passes via latching relay terminals
inside the thermostat.
Additional information can find HERE.
Hope helps; tell us news.
Aug 05, 2010 | General Electric Chest Freezer FCM5SU
Service engine soon light on 2003 Saturn Vue
Here is the definition of the code in GM manual:
P0128 - Coolant Thermostat Below Thermostat Regulating Temperature, this indicates the engine is running cold, u need a thermostat
Feb 12, 2009 | 2003 Saturn VUE
I have amanual honey well and I want to change it to a programable honeywell but the two wires on the manual thermostat are not labeled, so I don't know where to connect the wires to in the new thermostat
Wires for thermostat control circuits are normally color coded. Check for proper connections at the furnace and connect the same colored wires that you find at the furnace to the like lettered terminals on the new thermostat. R to R, W to W , Y to Y , ans G to G. R is for power to the thermostat, W is for heating, Y is for cooling and G is for furnace fan operation.
Nov 14, 2008 | Honeywell Heating & Cooling
Hunter 44155c wiring from manual thermostat
I have a manual thermostat with the following wire connections (Y, G, R, O, C, & E) with the respective wires attached (yellow, green, red, orange, blue, white). My 44260 has available G, Rc, Rh, Y/O, W/B, Y1. Which wires should I connect to which terminals on the 44160. Thanks.
Jun 19, 2008 | Hunter Fan Company 5/1/1 Programmable...
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
