Question about Motorola Walkie Talkie 2-Way Radio
How do i get my two way radios to communicate with each other?
I turn them on and i can't talk through them, the volume is up all the way too
  • protector606 Nov 07, 2014
    Hi Caleb , I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Such as the model number and if they are new or old.
    Master:
  • 442 Answers
It's difficult to say without knowing what model of radio you have but the first thing you should check is that they are both on the same channel (of course) and, if your radios have this feature, that they both have the same squelch code (sometimes called privacy codes) programed into both radios. Check your owner's manual for that info or Google search for your brand of radio.
Posted on Nov 07, 2014
  • Motorola Master
  • 3,957 Answers
Without knowing the model number, here is what I would try:
1 - Fresh batteries
2 - Set radios to same channel and pl code
3 - Set volume to mid range (the louder you set it does not make it transmit any better - volume is for listening)
4 - Key one radio with the other nearby and see if it responds, and then key the other
5 - If nothing happens, one or both are bad. If they are within warranty, take them back.
    Problem Solver:
  • 11 Answers
It sounds as though the CTCSS or DTS coded-squelch modes are engaged and the CTCSS or DTS codes do not match. You can check this by engaging the Monitor Mode and testing the radios. Here is the manual for the T4: http://www.motorolasolutions.com/web/Business/Products/ConsumerTwo-WayRadios/MOTOTLKR_T4/_Documents/T4_Manual_v1.pdf
Page 8 tells you how to engage the Monitor Mode on the T4. The procedure should be the same or similar for other models. Older models may actually have a "monitor" button. In monitor mode the radios should talk to each other. If they do not then one or both of them are malfunctioning and will need to be repaired.
    Champion:
  • 203 Answers
The privacy code setting must be the same on both of the radios if they have this feature and the radios must be on the same channel. If the radios are too close or too far away from each other they may not be able to communicate. One or both batteries may be too weak to fully transmit a signal. And it is entirely possible that one or both of the radios may be faulty.
  • 13 Answers
You have to set the channels and codes to the same value on both of them. For example, Channel 2 on both, code 7 on both...
    Sergeant:
    Champion:
  • 214 Answers
Press the Monitor button on the one you are listening to and transmit on the other radio and notice if you can hear it. Then switch the radios and try it. Make sure they are both on the same channel.
When I talk on my LG HBS-900 Tone Infinim bluetooth headset, the person on the other end can't hear me. How do I fix this?
Make sure your Mic is not muted. Use the sounds and audio devices properties window to check the volume level.
Feb 08, 2017 | LG Radio Communications
Need louder talk back volume general Lee
i needed one as well you can buy a noise canceling talk back external speaker with volume. i bought a astatic classic works perfectly..as for wanting to turn up talk back on radio do you have dynamic mic volume? if so try turning that up a little at a time and see if that helps.also do you have a volume control for talk back? if so turn it up to. hope this helps!!!
Apr 25, 2016 | Radio Communications
Static communication
Or you can adjust the squelch trimmer inside :)) There is always a solution ;)
Apr 09, 2014 | Motorola MH230R Two Way Radio
I can talk but cant hear
Check your Code setting. Both the frequency and the code must be identical for the units to communicate. Shut off any special features and keep the radios at a simple setting until you get communications back.
Apr 02, 2014 | Motorola Walkie Talkie 2-Way Radio
How do you set the volume on a motorola talk about mt 350
Here's a link to the user guide http://shop.giantintl.com/Manuals.asp select your model from the pulldown
Mar 05, 2014 | Motorola MT350R Talkabout MT350 Series...
My Motorola mr350 2 way radios are brand new but just stopped communicating. I cannot hear or talk using any of them. Don't know how to fix it
Try reprogramming your radios back to a very basic mode with all the special features turned off (or set to zero), including the interference eliminator code, Qt filter (if any), and call alerts, etc. Make certain your frequency matches on both radios. The radios should communicate easily in this configuration. If not, since they are new radios, contact Motorola using the number your user guide and talk to them about warranty replacement.
Best regards.
May 06, 2013 | Radio Communications
Volume
If you are talking about a new from the factory radio, there is no way to increase volume. If you are talking about an existing radio which has lost volume over time, short of cleaning the grill of debris, and using a known good battery, there is no fix for low receive audio.
Jun 28, 2009 | Motorola Talkabout T6200 (14 Channels)...
Connex 4600 turbo the talk back
THE TALK BACK VOLUME IS CONTROLLED BY THE MIC GAIN, TRY ADJUSTING YOUR TALK BACK VOLUME ABOUT TURNING THE MIC GAIN FROM 12 OCLOCK TO 6 OCLOCK, DO NOT WORRY YOU WILL NOT LOSE ANY OUT BOUND POWER UNLESS YOU TURN THE MIC GAIN BELOW 11 OCLOCK
Mar 29, 2009 | Connex 4600 Base CB Radio
Cobra LI7200
Dear sir, Pls see if u have same privacy code , pls turn of all privacy codes & sub codes keep every code "00" & keep same channel in both the radios , try now
Regards
raj
Jan 11, 2009 | Cobra Li 6000-2 WX VP GMRS/FRS Two-Way...
Radio Communications Logo
118 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
