Question about Precision Products TCT15 Gallon Trailing Sprayer
I need operating instructions for precision tct15 sprayer
How do I set up the pressure gauge and the switch by the sprayer as well as the switch in the electrical line? There are symbols with 0 and -. Near the pressure gauge there is a switch saying off and on . Tell me how to set these switches. I have the Electrical cord connected to the battery. I can hear the pump motor running. The gauge doesn't register just sits on 0. Please help.
Stanley backpack sprayer top is stuck....... how do I get it off?
Hi Chris:
Seems a bit extreme to consider using the 12 gauge. I've found that a .22 works quite well. (Humour)
Hint! Pressurized tanks must have the pressure relieved BEFORE the lid can be removed.
If the lid has been over tightened or has stuck, you'll need to get more leverage to unscrew it. Sometimes a rag wrapped around it is all it takes.
You can also try pouring hot water over the cap. Lay the tank flat so the rim of the cap gets the heat. Wrap an old towel around it first so it gets a good hot soak.
Should come off without the artillery.
Cheers
Mar 19, 2016 | Stanley Professional Backpack Poly...
Where is the reset button located?
The manual for your sprayer list several possible causes of the motor not starting, but does not indicate the presence of a reset switch. It has Thermal Overload but is reset by simply letting the motor cool.
From the manua: lProblem
A.
The unit will not run.
Troubleshooting cause
1.
The unit is not plugged in.
2.
Tripped breaker.
3.
The pressure is set too low (pressure
control knob set at minimum setting does
not supply power to unit).
4.
Faulty or loose wiring.
5.
Excessive motor temperature.
6.
ON/OFF switch is defective
Hope this helps!
Dec 05, 2015 | Titan Impact 1140 High Rider Airless Paint...
HOW DOES ONE FILL THE TANK?IE. HOW TO GET THE TOP OFF?
Backpack & Handheld Sprayers - Gas Powered ... - Stihl
www.stihlusa.com > Products > STIHL Products
StihlSTIHL sprayers provide power, precision and portability exclusively used by pest ...Technology & Features · Online Catalogs & Brochures · Top Rated Products. Find a Specific Product: Sprayers ... and high pressure - STIHL gasoline-powered backpacksprayers deliver power, comfort and ease of use. ... Cut-off Machines.
Oct 07, 2015 | Garden
When I pump the handle I can not get it to hold pressure it will not hold any pressure at all it. Seems that the inside of the pump will not build up any pressures
like most pumps; air, hydraulic, etc. there is a one-way valve with a ball or flap mechanism. If a small particle gets stuck preventing it from sealing, it'll leak pressure preventing it from building up. an easy way to try to clean this valve is to apply some air pressure to the hose end of the sprayer while operating the handle. your instruction booklet may cover this.
Sep 13, 2014 | Rl Flowmaster Garden
I need assistance with properly setting the water flow, range, and rotation of the 993hps Gilmour Impulse sprinkler and the 967hzs Impulse Spike Base Sprinkler. There were not directions with the products...
For some simple instructions check out the "additional information" section at http://www.gilmour.com/Watering/Hose-End/Sprinklers/Large-Coverage/Metal-Head-Impulse-.aspx. If your sprinkler doesn't rotate, ensure that you haven't lowered the water pressure by opening another faucet elsewhere. My sprinkler doesn't rotate as freely as it did when it was new, but it probably just needs to be taken apart and cleaned and greased.
Aug 04, 2010 | Gilmour Mfg Metal Impulse Yard Sprayer...
Need air cindition recharge, don't have cash to take it someplace, can you help with instructions to do this
YOU NEED A R-134 GAUGE SET TO CHECK LOW PRESSURE SIDE AND HIGH PRESSURE SIDE.YOU ALSO CAN BUY A LITTLE CHEAPER GAUGE TO CHECK YOUR AC LOW BLUE SIDE AND HIGH RED SIDE AT ANY AUTO ZONE OR ADVANCE AUTO PARTS.WHAT YOU DO WHEN YOU GET YOUR GAUGE SET HOOK GAUGE TO LOW PRESSURE SIDE BLUE CAP PORT AND GAUGE TO HIGH SIDE PRESSURE RED CAP PORT.YOU CRANK CAR UP GET IT OPERATING TEMPERATURE.THEN TURN AC ON HIGH COOL LET RUN 3 TO 4 MINUTES.CHECK LOW SIDE GAUGE READING SHOULD BE 28 - 32 PSI. HIGH PRESSURE SIDE GAUGE SHOULD 199 - 228 PSI. THATS NORMAL CHARGE. SEE YOU CANT JUST RECHARGE AC SYSTEM UNTIL YOU CHECK IT FIRST YOU WILL DAMAGE SYSTEM .NOW YOU CAN GO TO AUTO ZONE PARTS BUY A CHARGE CAN WITH GAUGE AND HOSE.ATTACH TO IT.YOU NEED MORE THAN ONE CAN.WARNING MAKE COMPRESSOR IS RUNNING WHEN YOU TURN ON AC .BECAUSE IF COMPRESSOR NOT RUNNING CHECK FUSE AND AC COMPRESSOR RELAY.IF BOTH OKAY.YOU COULD HAVE OPEN CLUTCH COIL A FAULTY LOW PRESSURE SWITCH WILL CAUSE AC NOT TO WORK. IF LOW PRESSURE GAUGE BLUE SIDE PRESSURE IS 28 OR 30 YOU DONT NEED A CHARGE.PROBLEM SOME WHERE ELSE.BE SURE TO WEAR SAFETY GLASSES WHEN WORKING ON AC SYSTEM.
Jun 26, 2010 | 2004 Hyundai Elantra
Oil light blinks on and off could pressure switch be bad if so where is it located on a 2000 ford windstar 3.0
Oil Pressure Switch Operation:
00134_oil_pressure_switch_gauge.jpgInformation relay unit for the indicator light or gauge on instrument panel. It contains a diaphragm that responds to changes in oil pressure. When the oil level is over a pre-set limit, the diaphragm opens the switch, turning off the light. When level is below the pre-set limit, the dash light comes on. In later model cars, if the oil pressure drops, the switch turns off the fuel pump, to stop the engine and limit damage to internal parts. Oil pressure switches can be grouped into two categories, units for electrical gauges and for mechanical gauges.
Oil pressure can be checked at the sending unit passage with an externally mounted mechanical oil pressure gauge. To get accurate results from the test, make sure you follow the manufacturer's recommendations and compare your findings to specifications.
Testing the Oil Pressure Gauge
  • Test the gauge by grounding the wire that leads to the sending unit on the block.
  • When the wire is disconnected from the sending unit with the key switch on, the needle on the oil pressure gauge should be either all the way high or all the way low. Grounding the wire should make the needle move to the opposite side of the gauge from where it was before the wire was grounded. If the vehicle is equipped with an oil pressure light, touching the wire to ground and then removing the wire from ground should turn the light on and off.
  • If either happens, the gauge and wiring are good and the sending unit is at fault.
Testing Oil Pressure
Pressure can be tested by temporarily installing an oil pressure gauge in place of the sending unit. Before testing, look up the oil pressure specifications for your vehicle in the appropriate service manual.
  • Bring the engine up to operating temperature.
  • Now shut the engine off.
  • Locate the oil pressure sending unit; usually it is on the lower side of the engine block.
  • Disconnect the wire from the sending unit and use an open ended wrench to remove the sender. Using pliers can damage the unit.
f43-19.jpg An oil pressure sending unit is removed with a special socket. Courtesy of Chrysler Corporation.
  • Tighten the oil pressure test gauge into the hole in the block where the sender was removed.
f11-15_3184.gif Measuring oil pressure. Reprinted with permission.
  • Check the engine's oil level and fill, if required.
WARNING Be extremely careful when working near a running engine. Always wear safety goggles or glasses with side shields when working around moving machinery and be sure that your clothing is not loose.
  • Now turn the engine on and check the oil pressure on the gauge.
    • Watch as the engine warms to note any excessive drops due to temperature.
    • Make sure the engine speed is set to specifications for testing pressure.
    • If necessary, us a tachometer and adjust the engine idle speed.
  • Record the measured oil pressure, then turn off the engine.
  • Compare the test results with the manufacturer's specifications.
    • If the oil pressure is within specifications, this shows that the oil pressure sending unit may not be working correctly.
    • In many cases, replacing the oil sending unit will correct the problem.
  • After the test is complete, reinstall the oil pressure sending unit, start the engine, and confirm there are no leaks.
Nov 17, 2009 | 2000 Ford Windstar
Sprayer Question
Hose end sprayers are the simplest and least expensive of the category. A sprayer jar is attached to a regular garden sprayer. Concentrated material is added to the sprayer jar. An adjustment on the jar determines the amount delivered. The force of the water through the hose pulls the material up from the jar and mixes and dilutes it with the water. A built-in anti-siphon device prevents unused material from being pulled back into your water supply. Compression or tank sprayers are the most common type of spray equipment. Concentrated material is added to the tank. Water is then added to a marked fill line. The remaining air is pressurized by pumping the handle a designated number of times. A control lever on the wand controls the spray pattern and amount. Compression sprayers provide a precise, on target, non-drift spray good for soil and lawn pests. Adjust the sprayer for a coarse, drenching spray, a concentrated stream or a fine mist. Tank capacities range from 1 quart to over 3 gallon for handheld models. Homeowner type backpack sprayers hold up 4 gallons. The tanks may be made from polyethylene plastic, galvanized steel or stainless steel. In addition to treatments for pests and diseases, compression sprayers are designed for applying cleaning solutions for decks and siding. Backpack sprayers are operated in the same manner as the handheld compression sprayer. The over-the-shoulder configuration makes it easier to carry the heavier load of material. Some backpack models also use a lever-style pump to maintain pressure without removing the unit form your back. Powered sprayers rely on a gasoline engine for spray power. Great for larger yards or gardens due to portability and capacity (12 gallons). Dusters are a slightly different breed. Dry powders (mostly for blooming plants such as roses) are added to a canister and applied by manually pumping. NOTE: Compression sprayers deliver liquid under pressure. Compression sprayers are powerful and efficient tools. This fact also makes them potentially dangerous. Always read the manufacturer's instructions and safety precautions carefully.
Aug 27, 2008 | Sp Systems 02sv320065 Farm & Home 2 -...
Precision Products TCT15 Gallon Trailing Sprayer Logo
81 people viewed this question
Top Precision Products Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Precision Products Garden Expert? Answer questions, earn points and help others
