TV keeps shutting off a temperature lamp light keeps flashing
  • 21 Answers
Your tv is overheating if its in a tv unit thats why it could be overheating
Posted on Nov 07, 2014
ctf1800
  • 4402 Answers
SOURCE: jvc 52 inch hd-ila hdtv widescreen
you have a bad lamp or balast
Posted on Jan 22, 2008
SOURCE: Panasonic PT-50DL54J DLP TV Flashing Light
I had the same problems that most of you have been having, tv turning on and off, lights flashing in all different colors, having to unplug tv to reset and all of that good stuff. I noticed that most of the time this would happen once the tv would start to heat up, and I could hear the fan working a little harder. Well I am not an electrician but It was very simple to unscrew the lower bottom park of the tv, where the fan and most of the electronics sit, then I used an oxygen tank ( I work for a medical company ) to blow out all the dust in the tv, ( you can olso use the compressed air use for computer, but if grandma or grampa have some O2 laying around, it works really good, LOL. )and was very surpriced to see how dusty it was, then I removed the MAIN FAN ( you only need to remove three screws, however there's a box in fron of it, which you'll have to remove first in order to get to the fan ). this may sound a little complicated, but trust me it is not, once you have taken the fan off, clean it all the way around ( best to use a clean rag, the compressed air was not doing the job.
long story short, once I cleaned the fan and put it all back together. The TV still didn't work LOL, Just kidding, It has been working perfect for a little over a week.
If I can help in any other way, please e-mail me @ gsierra11@yahoo.com
hope this helps.
Posted on Feb 19, 2009
  • 8457 Answers
SOURCE: T.V. doesnt turn on and red light keeps flashing at Power Section
Ur power board have dead capacitors,Know how to solders?Take the tv aparts check for capacitors puff up or burst open in the power board.Replaced those capacitors.Or tries Shopjimmy.com,Ebay.com buy a refurbih power board.
Posted on Jan 21, 2010
  • 68 Answers
SOURCE: flashing red light saying lamp and no picture.
REPLACE LAMP !!!
Buy an Orginal Replacement Lamp.
Posted on May 19, 2010
  • 1456 Answers
SOURCE: Mitsubishi tv keeps turning off.
Hello there please check the following in your tv;
Reset the component settings. Most problems with Mitsubishi projection televisions can be resolved by resetting the television to factory settings
If this does not work then a full system reset should be performed on the control panel by pressing the System Reset button. The television will turn off and the green LED light will flash quickly for a minute. When the light stops flashing, the TV will turn on.
If that still doesn't work, then the projection lamp might need replacing and here is how to do that;
Ensure that the bulb is completely cooled and the television is unplugged. Use a Phillips-head screwdriver to remove the lamp compartment cover. Unscrew the lamp cartridge on the rear of the television. As opposed to the cover door, these screws do not actually come out of their chamber and simply loosen the lamp assembly. Remove the old cartridge and insert the new one. Secure the lamp with screws, then replace the cover and screw in tightly.
Please note that, Finger oils can cause the lamp to malfunction.
Projection lamps are powered by mercury. Wash hands thoroughly after replacing the projection bulb.
GOODLUCK
Posted on Jul 04, 2010
We have a Mitsubishi TV model# WD-60735.. we have changed the lamp because it was flashing red but now its flashing yellow and the tv will not turn on..
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Nov 18, 2015 | Mitsubishi Televison & Video
Lamp keeps cycling on and off.
the circuit is closed somewhere it shouldnt be
Apr 13, 2013 | Sharp XR-10X Multimedia Projector
Wd-60737 mitsubishi blinking yellow status light ?
Oct 25, 2012 | Mitsubishi WD-60737 TV
RED FLASHING STATUS LIGHT
Possible lamp failure but lamp light not status should blink-I have suggestions but want you to try the self check first--if set has been unplugged plug it up and turn on and when it fails:
Mitsubishi TVtroubleshooting
Here's something that might also be useful. After you turn on the set, and getthe regular red blinky lights, hold down the Device and Menu buttons togetherfor about 5 seconds.
33 = Air filtercover is open.
44 = DVI cablebetween FMT and Engine disconnected
Jun 11, 2012 | Mitsubishi WD-62525 62" Rear Projection...
The red and blue light on the front keep flashing when we try and turn the TV on...it was working earlier today.
If Power and Lamp lights blinking 'alternately' it shows problem of temperature arise abnormal and reason could be blocked fan or air flow in tv is insufficient to keep it cool.
If Power and Lamp lights blinking simultaneously then it shows problem with lamp installation, need to inspect lamp cover is fixed in its position securely.
Let me know both lights are blinking at same time on your tv?
Thanks.
Aug 02, 2010 | JVC HD-52G786 52" Rear Projection HDTV
Tv keeps turning off
There should be a sequence of lights flashing before it shuts down. Either the lamp(s) burning out, or there is a temperature issue. Do the lamps even strike...turn on that is?
Jul 01, 2010 | Hitachi 50GX30B 50". Rear Projection...
Tv Shuts off occasionally 1min upon power up shows red lamp light
Feb 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Tv cuts off reset it will come back on fan makes noise then ramps up and shuts tv off
Dec 19, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Tv keeps turning off?
cutta, you will most often hear a click on boot then the fans start up and lamp will then fire. The picture will start to show up....at what point does it shut off? and do you hear a click when the tv is turning off? Is it the complete tv shutting down, fans and everything that turns off? Do you see any lights on the the front panel "POWER", "STATUS" or "LAMP", what are they doing? If you see a Power, Status or Lamp light after it shuts off the below are what they mean if there is an issue. POWER - STATUS - LAMP - CONDITION/ISSUE: Off - Yellow - Off - Temp. high/dirty filter/excess room temp Off - Off - Yellow - 4000 hrs. Lamp usage warning Off - Off - Blink Yellow - Lamp Cover open Off - Blink Yellow - Off - Air Filter Cover open Off - Off - Red - Lamp failure (failed to turn On or broken) Off - Blink Red - Off - Fan Has Stopped Off - Red - Off - Circuit failure (short) or DVI cable disconnected If you want to check for the last "Error Code", after you first turn the TV on, by pressing the front panel ?DEVICE? and ?MENU? buttons at the same time and holding them for 5 seconds, it activates the Error Code Mode. The ?Power LED Light? blinks/flashes (1/2 sec delay) and then flashes again denoting a two digit Error Code indicating no problem or an error has occured since the last Initalization. i.e. "Power light" blinks 3 times (1/2 second delay) and then blinks 4 times then 1 sec delay and repeats a few times. This would mean "Error 34 - Lamp abnormality". See below for error codes..... Error Code - Description or issue 12 - No Error detected, check Power Supply 32 - Lamp Cover is open 33 - Air Filter Cover is open 34 - Lamp abnormality 36 - Light Engine (DMD or LAMP Fan stopped) 37 - Exhaust or Lamp Ballast Fan stopped 38 - Lamp temperature high 39 - DMD temperature high 41 - Short is detected 44 - DVI cable between FMT & Engine disconnected. Sorry for the long answer but it was an open ended question.
Jul 11, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
Electro Med Services...
