Question about Dryers
My patton fan model#pab06 is running slow i cleaned it it will run without the blad but as soon as you put the blade on it wont turn
  • Anonymous Sep 25, 2016
    I have the same issue, and the issue is the blade. The plastic teeth are worn out or broken, so the motor turns, but the blade won't. I am looking for the blade, but out of luck. I just need to get a longer pin and it should do the trick.
    Top Expert:
  • Dryers Master
  • 3,698 Answers
Www.pattonproducts.com
Did you oil the bearings?
Posted on Nov 17, 2014
SOURCE: replacement fan blade for fan
I have one of these pieces of junk. The motor swarmed, so the rest of the fan is perfect. I'll sell it for $10.00 plus shipping.
Skip marinaman@aristotle.net
Posted on Jul 17, 2008
  • 726 Answers
SOURCE: Blade for Patton Stand Fan Model 1010-MP1
u can get a replace blade from hard wares and fan shops also try ebay and oztion
Posted on Sep 09, 2008
  • 2976 Answers
SOURCE: slow desk fan
The thrust bearing or ball is worn out or missing. When you tilt it, the motor shaft spins freely. When you set it down, the shaft goes to the rear and creates drag on the motor.
Posted on Aug 31, 2009
SOURCE: How do you clean Patton Floor fan?
The grill is in two halves with the back half attached to the motor. The front with the round patton insignia removes easily by applying leverage with a screwdriver. There are eight spots (at least on mine) where it clips. Be sure to remove any disposable plastic fastener holding the two halves together. Its pretty easy.
Posted on Jun 02, 2010
SOURCE: Where do I find a resource for a new fan blade for
i have a good blade for model #u2-1887.
Posted on Jun 14, 2010
Shuts off after 15 mins
its hitting the high limit temperature switch...
is the heater clean inside? clean any dirt or dust off the fan blades and vent grills.
Is the fan turning and running at proper speed?
Jan 07, 2011 | Patton PUH680-U Utility Heater
Sep 09, 2008 | Patton (HASF1016UC) Stand (Pedestal) Fan
Any idea where I can get replacement metal fan blades for a Patton floor fan?
I'm not all up on Patton Model#s, but this is an older unit, correct? You may try contacting Patton (Owned by Holmes now so you may have to go through them)
If they cannot help you, try www.dtvintagefans.org There's collectors there that may have parts fans that they may be willing to sell a blade.
Alternatively, you may try Grainger, as they sell an assortment of blades. You will need to match a blade to your motor though, which should be fairly easy as the Patton fans use a common McMillan motor which most attic fans also use.
Jun 08, 2010 | Patton U2-1487 Floor / Box Fan
Slow desk fan
Aug 31, 2009 | Dryers
Patton 1887 fan blades wont turn
I've had an 1887 since the 90s -- great fan. I have to say that FixinFax (Solution 1 above) probably didn't try to take his unit apart. My blade has stopped rotating several times over the years and I always got it going again by myself. I'm no whiz, just your average amateur handyman. In fact I am fixing the motherbleeper right now because in a week where the heat is 100 degrees it chose to slow down and stop.
Eventually it sucks enough dust into the axle housing so you have to take the motor mechanism apart and clean it. It's not terribly complicated, but you have to note how the electrical and mechanical parts go back together before disassembling. It's a little tricky to get all the housing parts to line up level again, you may have to try a couple times till the blade rotates freely. Wipe out all the dust and gunk buildup. Lubricate the axle with oil, or I just spray with WD-40. Then reassemble.
The only thing I have had to replace is the on-off knob, since it's plastic and it split. Just get a universal knob from your local hardware store.
Aug 19, 2009 | Lakewood HV-18 Floor / Box Fan
Fan keeps cutting off after being taken apart and cleaned
If it was wired wrong it wouldn't run. I would suspect uneven tightening of the motor screws.
Aug 08, 2009 | Patton Electric U2-20 Box Fan
Blades vibrating
The fan blades have to be balanced for it to run smoothly.
This website looks like it's straight from 1995, but the instructions are good and you should be able to rebalance your fan without too much trouble.
Jul 30, 2009 | Patton 20" CVT Performance Air Circulator,...
Patton U2 1887 Fan Won't Run After Cleaning
Do you have the cover back on unit tight has a button that kills the circuit when cover is taken off. Be sure it is on. Get back with me if that isn't it. ken
May 02, 2009 | Heating & Cooling
FAN MODEL# 1010 MP
Hello
This would seem to be the motor heating up and cutting out on a thermal overload. Check to see if the motor area is clean and that the fan blades are clean. To clean the motor you can blow compressed air through it. To clean the blades disassemble the cover remove the blade and clean with a mild soapy solution.
May 28, 2008 | Patton Electric Dryers
Dryers Logo
183 people viewed this question
Top Dryers Experts
