Question about Dryers
Hallelujah Hampton Bay fan speed switch is binding what could be solution
    Top Expert:
  • Dryers Master
  • 3,698 Answers
Electronic spray tuner cleaner , unplug unit before using it.
Posted on Nov 17, 2014
Buffalo12980
  • 625 Answers
SOURCE: Installing ceiling fan with two switches AND a remote
in your ceiling box should be three wires. a red goes to the three way switches, a black goes to the hot and the white is the neutral. the fan wires are black, blue and white. since you have a remote, connect the [fan] blue & black together with the [line] black. connect all white wires together. the remote will now ramp up your lights from off to full on and the fan remote will let you choose lo med high and off. just tape up the red wire in the box.
Posted on Aug 22, 2007
  • 26 Answers
SOURCE: Hampton Bay 52 In. Clarington. How do I reverse the fan?
Try these two: 1) look for a small switch up near the light area on the dark-colored area of the fan. If a switch is there, then simply flip the switch to the other position; 2) if you have a remote control for the fan, the reverse mode may appear on the remote control. Hope this helps.
Posted on May 19, 2009
SOURCE: WIRING OF 3-WAY SPEED SWITCH FOR HAMPTON FAN
1 - Red/Pink
2 - Purple
3 - Yellow
L - Black
Posted on Jun 20, 2009
Treefrog15
  • 127 Answers
SOURCE: Hampton Bay Windward II Purchased 2002
Most fans have a small rectangular multi-tap capacitor connected to the speed control in the fan. It is likely that this has gone partially bad. The capacitance values are printed on it. Lighting stores and big box hardware stores generally carry replacements.
Posted on Feb 25, 2010
SOURCE: I can't find a replacement fan 3 speed switch for
Hi azwaverid!
I just had a similar problem with my ceiling fan, not sure if I have the same model as you (the fan was in the house when I bought it). I do have the exact same pull chain switch (K.T.E 2035080).
I went to a big home improvement store and the salesman gave me some 3-way switch and guaranteed it would work. The switch had only 3 wires, not 4 like the original. Can you guess what happened next? That's right, their part didn't work.
Being an engineer, I could not admit defeat. I consulted with other engineers I work with, and they pointed me to a "mom & pop" electronics store close to my house. I went to Centennial Electronics in Colorado Springs, CO. The sales staff didn't have experience with this problem, but at least helped me and offered suggestions.
I ended up buying a Philmore Pull Chain Switch for $2.51 after tax. This worked perfect! Just be sure to place the wires in the right slots. On my fan, the following positions and wire colors were: L - Orange, 1 - Yellow, 2 - Purple, and 3 - Blue (I just matched them up the same as the K.T.E. switch colors & positions).
Hope this helps!
Bob
P.s. The exact part I used was:
Philmore No. 30-9152 (UPC code: 0 38975 39152 6). The box says (everywhere you see a semi-colon is a line break): Philmore PULL CHAIN SWITCH; L-1-2-3, L-2-3, L-1-3, L-1-2, PUSH-IN TERMINAL; 6A-125V AC, 3A-250V AC; Made in Taiwan No. 30-9152; LKG Industries - Rockford, IL
Posted on Jul 09, 2010
Trying to find manual for a Hampton Bay ceiling fan. I have two. Tag on fan says model: AC-552AL, Item# 154620 NN, Another sticker on fan says 05/02 E192641 UL Listed CEILING FAN 47BF
You should find what you need here:
http://www.homedepot.com/b/Lighting-Ceiling-Fans-Ceiling-Fans-Accessories-Ceiling-Fan-Parts-Remote-Wall-Controls/Hampton-Bay/N-5yc1vZbvmuZp4
Apr 03, 2017 | Hampton Bay Dryers
Westinghouse 3speed fan switch 77288
It's the westinghouse switch. Many results on search. I just wasted 2 hours playing switching wires all combos. Others suggested the switch from Lowe's. Harbor breeze #0033905 . Plug wires back in as you listed Black L, Grey 1, Brown 2, Purple 3. Works perfectly for $3.98 plus tax.
Others said you can call Hampton Bay and get the replacement also.
Sep 24, 2013 | Hampton Bay Dryers
I just had a Hampton Bay fan installed, and the pull chain will not change the speed. It stays on high speed.
Replacement switches can be purchased at Orchard supply, Ace Hardware, Lowes, or Home Depot. After checking the wiring at the switch - connections made during fan installation - and no faults are found, switch should do it.
May 04, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Bay Model # 526-012 Fans what size speed control
I can't see any reason why a Leviton fan speed control couldn't be used on any ceiling fan, after all, I don't even think Leviton makes ceiling fans. Second, you may be able to try using the 1.5 amp fan speed control and see if you can get by. The worst that could happen is the speed control wouldn't work or would only work for a short time and be junk.
Jan 03, 2009 | Hampton Bay (261025) Dual Mount Ceiling...
Hampton bay fan, wall mount remote control
Hello burrow31. There maybe a switch located on the fan stating 'remote/manual'. Check your manual. Remove the battiers in your remote and short out the battery contact terminals. Reinstall the battiers, start the fan and after fan has reached set speed press & hold fan speed button for one second. Still no speed change contact the Mgfr. with model & serial #.
Oct 11, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
No middle speed.
Replacing the pull switch (reostat) should have solved your problem. Try going to the internet at www.google.com and in the Google search box enter "Hampton Bay Fans homepage". If any of these suggestions have been helpfull, please rate my solution. Thanks D. Lange
Jul 31, 2008 | Hampton Bay Sidewinder 04890 Ceiling Fan
3-speed switch replaced with hampton bay switch. Only low speed works.
The cause to the problem was replacing a HUNTER fan switch with a Hampton Bay switch. Before removing the old switch, I noted and marked the color and position of the 4 wires. I then duplicated the connections to the new switch.
But the wire positions of Hampton Bay vs Hunter are not identical, therefore 2 wires
were crossed.
The correct way is to note the color of the wires with the corresponding NUMBER
marked on the switches, then duplicate this on the new one.
Du-uh!
Jul 23, 2008 | Hunter 23852 Classic Original Ceiling Fan
Open Questions:
Dryers Logo
44 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
