Question about New The Three Little Pigs Book
Can i take a test on this computer
Iiiiiiiiiiiiiiiiiii want to take a test nnnnnnnnnnnnnooooow
  • 2,355 Answers
Yes, go ahead
Posted on Nov 07, 2014
What does code dtc3 fail mean on my emissions test,,97 nissan pathfinder
I means that the vehicle failed it's emissions test as it failed the digital trouble code reading test 3
the testing station tests the exhaust emissions and the onboard computer
Your computer failed the test
May 16, 2017 | Nissan Cars & Trucks
Tip
How to Diagnose Hardware Failure on Dell Computers
1. Turn off the Computer
2. When you turn the computer on, repeatedly press F12.
3. When a boot menu comes up, select boot to Utility Partition.
3. Press Tab and than select Test System and hit enter.
4. There is than two options:
Express Test - 15-20 Minute Basic Test
Extended Test - Hour long Thorough Test
5. This is built in to all dell machines and it will save you from having to pay a lot of money to have your computer "professionally" diagnosed by computer shops.
on Dec 25, 2009 | Computers & Internet
What is my computer download speed
hi.. You can find your computer's internet download speed at Scanmyspeed.com very easily...It provides Express, Normal and Extended speed tests.... You can choose any level in the above three tests..You can download free speedtest windows gadget on your pc or laptop...You can test your internet speed right on the desktop...
Oct 03, 2011 | Toshiba Tecra A2-S119 Notebook
It said problem on hard disk, install hard disk.. how to install where to get it my netbook has no dvd/cd compress HP mini
Many computer problems are related to soft failures on the hard drive. The comprehensive portion of the HP Hard Drive Self Test repairs soft errors on the hard drive, but does not report the errors. After the test completes, be sure to restart the computer to determine if the test repaired any problems you are experiencing with your computer. If the computer has two hard drives, you should select the multi-bay test option and test each drive separately.
  1. Plug the AC Adapter into the computer.
  2. Turn off the computer and wait 5 seconds.
  3. Press the Power button to start the computer and repeatedly press the f10 key to enter the BIOS Setup menu.
  4. Use the Right Arrow or Left Arrow keys to navigate through the menu selection to locate the Primary Hard Drive Self Test option. Depending on your BIOS, this may be located below either Diagnostics or Tools .
  5. Select Primary Hard Drive Self Test , and then press the Enter key to start the test. NOTE: The exact wording of the option for your particular BIOS may be slightly different.
The Hard Drive Self Test performs a Quick Test followed by a Comprehensive Test . During each test, the window displays a status bar and an estimated time to completion. See HP Notebook PCs - Testing a Hard Disk using the Built in Self Test for additional information.
  • If any test fails , contact HP service and support for instructions on how to order a replacement hard drive.
  • If all of the tests pass, the hard drive is not damaged. As a rule, HP will not replace a hard drive under warranty that does not fail the HP Hard Drive Self Test.
  • If there is no physical problem with the hard drive or memory, then try reinstalling your Windows operating system to troubleshoot the problem.
Instruction on how to Install a new HDD
Please follow the link
Thanks
Proton
Sep 03, 2010 | Computers & Internet
Hard drive crashed
NOTE:
If it fails then you need to replace the HDD. If you can provide me the product no. then I would be able to find the exact part no.of the HDD.
Dreamkam
May 28, 2010 | HP Pavilion dv1000 Notebook
System hangs after 5 minute 0f os Ubuntu
The issue might be due hardware malfunction or lack of system performance or corrupt os.
perform hard drive self test:
Hard Drive Self Test:
1. If the notebook computer is running solely on battery power, plug the AC adapter into the notebook.
2. Shut down the computer if it is running.
3. Press the power button to turn on the computer.
4. Press f10 when the HP/Compaq logo displays.
5. After the BIOS Setup Utility displays, use the Right Arrow key to select the Diagnostics menu.
6. Select HDD Self-Test options .
7. Press enter to display a list of HDD/Self-Test options.
8. Select Notebook Hard Drive and then press f10 to display an Estimated test time .
9. Press f10 to continue. The Hard Drive Self Test executes a Quick test , a Comprehensive test, and a SMART test.
If test pass then perform below steps:
Improve system performance:
Follow the steps provided in the below url:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00815926
if persists, restore the ntoebook to factory settings.following below steps in the url
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00809678&product=18703:
Mar 26, 2010 | HP Pavilion dv9000z Notebook
Computer will only start in safe mode hp cue root and hp help and restore are not working? what is the best resolution? hard drive failure?
I have included some directions from HP about using an embedded Hard drive test. This is done using the BIOS. Try this to rule out a hard drive problem. This is supposed to also repair some hard drive issues. Then, we can go from there.
Brian
Perform a hard drive self test Many computer problems are related to soft failures on the hard drive. The comprehensive portion of the HP Hard Drive Self Test repairs soft errors on the hard drive, but does not report the errors. After the test completes, be sure to restart the computer to determine if the test repaired any problems you are experiencing with your computer. To use the HP Hard Drive Self Test, follow the steps below. NOTE: If the notebook computer is configured with two hard drives, then it may be necessary to test each drive separately.
If any test fails , contact HP for instructions on how to order a replacement hard drive. If all of the tests pass, the hard drive is not damaged. As a rule, HP does not replace a hard drive that is under warranty if it does not fail the HP Hard Drive Self Test.
Mar 01, 2010 | HP Pavilion dv9000z Notebook
Dell172fpb 17" monitor
Self-Test Feature Check (STFC) Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and the monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove Analog (blue connector) cables from the back of computer.
  3. Turn on the monitor. The floating 'Dell - self-test Feature Check' dialog box should appear on-screen (against a black background) if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green and the self-test pattern will scroll through the screen continually.
  4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the monitor.
If your monitor screen remains blank after you use the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Thanks
proton
Oct 26, 2008 | Dell E171FPb 17" Flat Panel LCD Monitor
New The Three Little Pigs Book Logo
191 people viewed this question
Top New Office Equipment & Supplies Experts
jasbo
jasbo
Are you a New Office Equipment and Supply Expert? Answer questions, earn points and help others
