Question about Midland WR-100 Weather/RDS Radio
<!-- from fixya rte -->I need code for Custer county - Midland WR-100 Weather/RDS Radio
WHAT IS ZIP CODE FOR STARK CO.OHIO
not sure if this is what you are after..Zip Code List County - Stark County, Ohio Zip Code City County 44601 Alliance Stark County 44608 Beach City Stark County 44613 Brewster Stark County 44614 Canal Fulton Stark County 41 more rows
Zip Code List County - Stark County, Ohio - CI Gateway Zip Code List
ciclt.net/sn/clt/capitolimpact/gw_ziplist.aspx?ClientCode...State=oh...Ohio...39... WHAT IS ZIP CODE FOR STARK CO OHIO Google Search
Oct 21, 2017 | Sport & Outdoor - Others
Need code for Custer co
Good morning, afternoon, evening or night; whatever time of day you are viewing this post. It would be more helpful if you could name the state you live in. There are 6 Custer Counties in the United States. But since I don't know which specific state you live in, I will give you the links to each of the five of the six states that contain Custer County (Idaho has no NWR coverage).
1. Colorado (http://www.nws.noaa.gov/nwr/coverage/ccov.php?State=CO)
2. Montana (http://www.nws.noaa.gov/nwr/coverage/ccov.php?State=MT)
3. Nebraska (http://www.nws.noaa.gov/nwr/coverage/ccov.php?State=NE)
4. Oklahoma (http://www.nws.noaa.gov/nwr/coverage/ccov.php?State=OK)
5. South Dakota (http://www.nws.noaa.gov/nwr/coverage/ccov.php?State=SD)
Hope these help.
Nov 06, 2014 | Midland WR-100 Weather/RDS Radio
How to find correct county
A. First, determine the counties you are interested in. Then do one of the following
three steps to get the codes:
1. The National Weather Service Toll-Free Number provides S.A.M.E.
County Codes at: 1-888-NWS-S.A.M.E or (1-888-697-7263)
This is what to expect when you call the NWS number. When you call the NWS
toll-free number, automated instructions will guide you to the S.A.M.E. County
Code(s) you need. The number will be six digits long.
• You will hear, "Welcome to the National Weather Service. You have
reached the Specific Area Message Encoding Program Service."
• If you select "touch-tone" to make your entries, you will be prompted to
enter the name of your state using the telephone keypad.
• Next you will be prompted to enter your county name.
• Then you will hear, "Your geographic code is xxxxxx." (This is your
S.A.M.E. County Code.) Be sure to write it down for future reference.
The system will then give you the option to enter "another combination": This
enables you to get additional S.A.M.E. Codes for surrounding counties.
2. The Internet Web Site of National Weather Servicewww.
nws.noaa.gov/nwr/indexnw.htm.
This is what to expect when you go to the website.
• The link above takes you directly to the list of states.
• Click on (your state).
• Find your county, and record the "S.A.M.E. #" (the S.A.M.E. County
Code) that is listed to the right of your county, and for any other counties
in which you are interested.
WR-100 Owner's Manual
Page 8 www.midlandradio.com
3. Go to the Midland Radio Corporation website at www.midlandradio.com
• Click on the weather radio link at the top of the page.
• At the top of the weather radio page will be the link to the NWS list of
states and corresponding county codes. Click on the link.
• Click on your state and a list of counties and codes will be listed. Locate
your county and then find your code.
To set the country follow the below steps:
A Single S.A.M.E. County Code:
Press "MENU" button to open menu options.
• Press the "UP" arrow to scroll through menu options until "S.A.M.E.
SET" is displayed, then press "SELECT" button.
• Press the "UP" arrow to scroll through: "SINGLE", "MULTIPLE", or
"ANY."
• Display "SINGLE", then press "SELECT." "S.A.M.E.01" will be displayed.
(Note if you are programming a single S.A.M.E. County Code, only the
"01" setting will be used.) Press "SELECT".
• Using the "UP" arrow, find the first digit of your S.A.M.E. County Code.
Press the "RIGHT" arrow to save the digit and automatically
advance to the next digit.
• Program all digits of your S.A.M.E. County Code in the same way.
• Press "SELECT" to store your S.A.M.E. County Code. Press "MENU"
to close the programming menu.
Helpful Tip: The S.A.M.E. code is created using the following method:
• The first digit is the subcounty code-currently 0 in most areas.
• The second two digits represent the state code.
• The last three digits represent the county code.
Multiple S.A.M.E. County Codes:
"ANY."
• Display "MULTIPLE" as explained, then press "SELECT".
"S.A.M.E.01" will be displayed, indicating you will be programming your first
S.A.M.E. County Code at weather radio menu location "01."
• After programming your first S.A.M.E. County Code, press "SELECT" then
the "UP" arrow to advance to "S.A.M.E. 02." Program all of your S.A.M.E.
County Codes in the same way as above.
• When finished entering all your codes, press "MENU" to
Hope that helps.
Regards
Anand
Apr 27, 2011 | Midland WR-100 Weather/RDS Radio
Need code for columbia co. ga 30907
1. Type in this URL address-http://www.nws.noaa.gov/nwr/indexnw.htm.
2. Click on your state
3. Find the county you live in. The S.A.M.E. code should be listed in the "SAME#" column. If you have two codes for your county, it probably means one of the codes transmits for different regions of your county. No problem, all you have to do is check your frequency station. Whatever frequency receives the best reception for your county (for example 162.450), put in the S.A.M.E code for the county that has that frequency.
Aug 18, 2010 | Midland WR-100 Weather/RDS Radio
Need code for washington county
3. Find the county you live in. The S.A.M.E. code should be listed in the "SAME#" column. If you have two codes for your county, it probably means you have more than one frequency channel for your county. No problem, all you have to do is check the frequency channels for your county. Whatever frequency receives the best reception for your region (for example 162.450), try that on the radio along with punching in its S.A.M.E code.
Aug 13, 2010 | Midland WR-100 Weather/RDS Radio
I NEED CODE TO COUNTY FAIR
which county fair is it and how many #'s does it need because because you dont need stuff thats free from the county fair deal with paying it
Jul 23, 2009 | Compaq Computers & Internet
I need to know my county code
To find the county cod, go here:
This will provide you with a list of states. Click on your state, then look for your county on the left. In your case, that's Randolph County. You'll notice there are 4 listings for Randolph County, but the code is the same for all four locations within Randolph County: 037151. The difference is the frequency on which it's broadcast and the station doing the broadcasting. Just enter in the code as is and your radio will pick up the closest station and frequency to you.
And that's all there is to it!
Apr 01, 2009 | Midland WR-100 Weather/RDS Radio
Midland WR-100 Weather/RDS Radio Logo
47 people viewed this question
Top Midland Audio Players & Recorders Experts
Van Allen II
Van Allen II
xxxxxx xxx
Are you a Midland Audio Player and Recorder Expert? Answer questions, earn points and help others
