Question about Pool & Spa
Have a Balboa Hydra pool spa model #du-hp-the power comes on power to the fuse and all it does is click when you press the Jets or light like a tick fuse is blown on top 1
  • 1,631 Answers
Balboa Hydra pak?
The problem you stated is not clear.
Check for proper voltage to the main terminal block. You should get 240, reading across both the line terminals, not one to L1 and the other to ground. Across both hots. If you have only a 120 volt system then make sure you have 120 at the terminal block.
Your comment "I have power at..." is very vague. How do you know you have "Proper" power?
Replace any bad fuses with like.
Good luck
Posted on Nov 14, 2014
PartsCenter
  • 125 Answers
SOURCE: We just moved into our home and there is no manual
Here is a link for the Manual and trouble shooting guide. Aqualink
Posted on Mar 04, 2009
  • 12166 Answers
SOURCE: my dream maker spa does not work. there is
open control panel will see a small glass fuse replace if blown if 220 volt check that getting power on both lines
Posted on Nov 04, 2009
  • 990 Answers
SOURCE: Purex Triton Minimax 400 pool/spa heater not igniting
This sounds like you have a problem with your pilot. You can check this with a small mirror to see if their is a spark when you turn it on. If you have any soot build up on the pilot that will stop the spark and keep it from lighting also. If you have a short on your pilot wire this could be the problem also. I hope this helps, good luck.
Posted on Dec 12, 2009
mdhstore
  • 6 Answers
SOURCE: i bought a home and my coleman spa 400 series has
Pump one is the pump that does all the work in your spa. It handles the heating and filtering. If pump one does not work, It will not heat. It is likely pump one is gone but a technician would be needed to determine if it is the pump or the spa pack.
Posted on Jan 11, 2010
  • 760 Answers
SOURCE: pool heater is not working properly
So I assume you have pressed the button by pool to select the pool thermostat? If this doesn't work sounds like another mother board problem, or try powering down the unit a few minutes then restart. IF you haven't pressed the pool button, the read this: The heater comes factory set at 78° F. for the pool mode and 100° F. for the spa mode. If it's in spa mode it's trying to get to 100F. Using the up and down arrows,you can set the thermostats to a minimum temperature of 65° F., or a maximum of 104° F. If you desire to heat only one
body of water, the thermostat is capable of an off mode. As an example, if you only wish to heat the pool and not the spa simply depress and hold the spa down arrow, and the thermostat will lower its setting to 65° F. then go to an off mode. Here is a link to your manual :http://www.pentairpool.com/pdfs/MasterTempOM.pdf
Posted on Jul 08, 2010
What runs on the .3amp fuse?
look on inside cover of control unit it has a schematic
Jul 04, 2014 | Balboa Instruments Pool & Spa
Balboa VL700S control panel jets 1 not working
Your problem is going to be in the circuit board in the spa control box under the skirt.
You have a bad relay.
Rod
US Parts Center
Jun 25, 2013 | Pool & Spa
My balboa spa just keeps running constantly and never shuts off.
It may be in sleep mode or Eco mode. If you hit jets then lights it toggles through. You need to be on st mode. Which is standard
Feb 14, 2011 | Balboa Instruments BALBOA 30kW HEATER ASSY...
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
