Question about Boss Micro BR Digital Recorder
Why are all functions unformatted
Can't record play or listen to anything
What software do i need on my computer?
You could install VLC. It is free of charge and has everything to play your music and video's.
And the best thing it is for Windows and MAC.
VideoLAN Official page for VLC media player the Open Source video...
Jun 30, 2014 | Tascam DP 008 Digital Portastudio
When we try to play LP records, the arm stops half way through the record and wont move any further so we cant listen to the whole LP. We always make sure we have it switched to the correct rpm.
If it's on ONE particular record, it may have a deep groove that the needle cannot move past. It could also be that you don't have enough pressure on the needle which you can adjust on the arm with a turn of the counter-weight (should be a knob on the other end from the needle)
Nov 01, 2013 | Akai Music
When I arm a track to record in tracktion 3 I get a delay when monitoring playback.
If you monitor the recording there are two delays... one as audio is converted and stored... the next is when it is retrieved and converted back to audio. Usually the recording interfaces have a monitor function that loops the audio back out before the conversion. playing back previously recorded audio of course will have the delay to retrieve and convert back to audio.
Jul 03, 2011 | Mackie Onyx Blackjack 2x2 Recording...
My recording function automatically turns on? I do even have to press any keys and it will just start recording. Its very fustrating because while I am playing it will often turn on and interrupt my...
Look for the button that starts the recording and see if it might be sticking down part way. If it is,then wet a Q tip with CRC226 and wipe the sides of that button. CRC226 is plastic safe and is available in the electrical dept of Home Depot.
Apr 29, 2011 | Casio Privia PX-130 Digital Piano 88 key
While the Mackie Onyx 1220i unit is plugged into my computer I can port the sound through to my headphones via the headphone jack on the console. When I listen to sound play for about 2 minutes I'll...
OK... first thing is to DUMP ALL anti-virus and Anti_spyware and real time defragging programs as these resource hogs **** processing away from teh sound generation. Also is you are recording at the same time, if your disk is fragmented requiring a lot of head movement to record the time lags can cause buffer underruns and break up of audio... and eventually having the audio program "crashing" due to lack of throughput.
When doing audio work suspend all the resource hogs like the above mentioned programs. It is a good idea when recording CD's as well.
Feb 10, 2011 | Mackie Onyx 1220i Onyx1220i Onyx-1220-i...
The memory card says unformatted card
Refer to your BR manual for procedure to format the card. Formatting the card in a PC just doesn't cut it.
Look in your index in the manual for "formatting" or "card"...etc.
Apr 13, 2010 | Boss Micro BR Digital Recorder
I was listening to a play back of a song i was recording when everything stop and window indecated that DRIVE BUSY Don't know what to do?
if it came back after a while then thats the way it is with digital recording sometimes. if it didnt come back that indicates something more serious.
Dec 20, 2009 | Boss Micro BR Digital Recorder
I bought a used BR 532 Boss recorder - can't get a
I get an unformatted come on the screen on my Boss BR 532 when I swith on, and also when pressing record, although I can get drum machine to work and guitar go through it ok but no recording Hmmmm Erggg
Nov 16, 2009 | Boss Micro BR Digital Recorder
I can record anything to a cd with my boss 1180 br it always say
Im Guessing Your Trying To Burn It Off Before Mastering It Which Means All The Tracks Between 1 And 10. First You Click Audio Cd Write/Play Then Select Disc At Once And Then It Should Guide You From There. I Hope This Helps
www.Myspace.com/CrossRoadsToNowhere2007
Dec 24, 2008 | Boss Micro BR Digital Recorder
Boss Micro BR Digital Recorder Logo
32 people viewed this question
Top Boss Music Experts
Michial Gueffroy
shaun taylor
Robert Graf
Are you a Boss Music Expert? Answer questions, earn points and help others
