Question about Tools & Hardware - Others
Have a craftsman belt sander. Armature bearings are bad. One end has a threaded drive pully which needs to come off to get the assembly out of the main housing. My guess is I need to remove end bearing to put armature in a vise then unscrew drive pully. Problems... Space between bearing and armature is less than 1/8". How do I remove the bearing? Then what kind of socket or other tool do I need to remove the threaded drive pully?
    Problem Solver:
  • 18 Answers
Be careful about putting the armature in a vice. Clamping it tight enough to pull a bearing may damage it. Now, if you have access to the first bearing, get a small bearing puller of this style http://www.summitracing.com/parts/WMR-W84551?seid=srese2 This is just an example to show what type should work. If there is not room for this, then there are other pullers made that have arms that will fit within the 1/8" clearance you have.
On the pulley, if it is a nut holding it on, then a regular socket will work. As stated be careful clamping the armature so as not to damage it. I would take a block of wood, say a scrap pc of 4x4 and bore a hole through it with a hole saw that closely matches the diameter of the armature. Cut it in half long ways, removing enough material so that when you use it to clamp the armature, the two half circle wood pcs don't touch. That way, it spreads the clamping force around a little more of the diameter of the armature.
If the actual pulley is threaded, then clamp the same way and you may have to rig something. Are there holes or slots in the pulley that a spanner wench would work on? There are several universal/adjustable spanner wrenches available for that type of thing. Check to make sure there is not a set screw in the hub of the pulley that keeps it locked from turning. A photo of this would make it easier to make suggestions.
Posted on Nov 09, 2014
Belt on my dewalt dw680 planer slips and starts smoking
If the ball bearing of the armature was getting too hot by working with too hard woods may be the bearing of the armature can melting loss the drive belt have lost a little tension by it the housing and a bearing has to replaced in that case.
Feb 10, 2016 | Dewalt DW680K 3-1/4" Planer
How to stop craftsman rear tiller from breaking drive belts.
belts too tight,1. pully out of round or warped,2. bad pully bearing,3. incorrect install,4.wrong belt ,5. lol.
Apr 27, 2014 | managemylife.com
How do I replace the fan assembly cannot hold armature assembly to get inner bearing out without damaging armature assembly
If you are replacing the fan assembly because the internal thread that holds the rubber/velcro pad has stripped, there might be an alternative.
I had the same problem with my PEX 12AE, which I believe is a similar sander. I found that the hole is threaded a good bit deeper than the screw, so I got a longer screw and so far it's holding ok. If/when that fails, I might try repairing the thread with an insert.
Curious to know how you managed with your sander.
Feb 09, 2012 | Bosch 3107DVS Electric Sanders & Polishers
Replace armature, I have it all apart except I can't see how to release armature from base.
The armature bearings fit very snugly in their holders. If you have the case split and the belt drive pully off, you just have to pry the armature out of the other bearing holder. If you are replacing the entire armature and the new one has a fan on it just pry it out. If the new armature doesn't have a fan on it be careful not to break the fan or any of the fins. It should pull out smoothly, if it doesn't come out with even pressure you still have something on the armature holding it in.
Mar 04, 2011 | Porter Cable Cable 363 4" x 24" 1500 SPFM...
Sander locked up. buzzes but doesn't vibrate.
you have a bearing problem, I would check the lower bearing first by removing the platen assembly, then try and run the motor without it. If you still have a problem then it is the armature bearings, but start with the eccentric bearing
Feb 08, 2011 | Dewalt 14 sheet palm grip sander kit
My Model # 362 Belt sander keeps breaking belts after just a few minutes of continued use. Why?
This is usually indicative of someone pushing down on the sander too hard while sanding. The motor in this sander is strong enough to pull the belt around even with too much pressure on the sander. This causes excessive heat to build in the sanding belt and sander shoe which causes the belt to break down prematurly. It's also very hard on the sander's bearings and motor. Use an appropriate sandpaper grit that will do the job without excessive pressure on the worksurface. This will make your sanding belts and sander work longer and cooler.
Sep 13, 2010 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
I have an old craftsman belt sander that needs oil because the engine has started smoking. I bought the right oil, but can't figure out where to put it in. Help?
Many belt sanders have sealed bearings that are packed with grease at the factory. They require no further lubrication. Sleeve bearings should be lubricated with 30 weight oil or an equivalent after each 10 hours of use.
Only about 2 to 3 drops of oil should be applied to each sleeve bearing. Avoid using too much oil. It can get on the work piece or on the belt and the belt will slip.
Apr 13, 2010 | Craftsman 0.5 amp 3D Sander
How do I release the lock on my Craftsman belt sander to lighten the belt. It's an old Model # 315.1172
I checked Searspartsdirect.com for that model number and they listed that number, but with an extra 0 at the right end. I couldn't find a belt release lever illustrated anywhere like that on my old Craftsman belt sander. On mine, you just flipped the lever either forward or back to release and tighten the belt. (still works great) There is a spring that pushes the front roller assembly forward when the lever is operated.
Dec 03, 2009 | Cars & Trucks
My Bosch 3107dvs random orbital sander stopped working. The screw that holds the sanding disk stripped the part that it screws into. I can't tell from the exploded parts diagram, which part I need to...
Drawing REF: http://www.ereplacementparts.com/bosch-3107dvs-0603310639-random-orbit-sander-parts-c-128_1044_1230.html
To remove the Dust Fan/Coupling Assy. I did the following: I disassembled the plastic housing, removed the Backing Pad Pos. 733 and Dampening Ring Pos. 51.
It seems the Star Washer Pos. 29 holds Bearing Pos. 30. onto the armature shaft and the Coupling Pos. 27 seems to be stuck in Bearing Pos.29. I used a 30mm long M7 hex-head bolt and 11mm ratchet turning clockwise (std RH thread) to pull the Coupling and Star Washer off. Luckily, there was enough thread left in the coupling to do this gear-pulling action with the longer bolt.
To remove the rest of the Fan Assembly I removed the 2 screws Pos. 43 holding the Brush Holder Assembly, Noted the position and removed the Spring Clip Pos. 32, then removed the Armature w/ Fan and Dust Fan/Coupling Assemblies. Firmly gripping the armature I was able to remove the Dust Fan from the armature by turning it clockwise (LH Thread).
Now that I have removed the parts and believe I will be able to reassemble them, I have ordered a new Dust Fan/Coupling Assembly.
I hope this helps someone else having a similar problem.
May 04, 2009 | Bosch 3107DVS Electric Sanders & Polishers
Tools & Hardware - Others Logo
62 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
