Question about Pool & Spa
Spa will not get up to temp I set it to 103 and it only gets to 91
Go to a Pool & Spa Store & take your
owners manual, etc & discuss it there
91 may be a default setting when the pump is off
& it is not used,so you may have a problem
Posted on Nov 06, 2014
Dream maker spaX400. has a green spa control panel keeps flashing SL. I tried setting it to F2can't get it to stay thereIt keeps going back to SL can change the temperature up down temp ofstays at 91
It is in sleep mode. Press your mode button until it says sp again then hit temp up button or whatever button you use to change the f1 f2 f4 messages.. it should change to SD or ST or SN for standard mode...
May 06, 2015 | Pool & Spa
I am unable to lower the temperature on my dreammaker spa
Is it because the buttons are not responsive?
or is the set temp at 100 but just not dropping in actual water temp?
if former, bad control panel.
if latter, allow time to cool?
Mar 15, 2015 | Pool & Spa
The spa is running too much
when the temp drops 1 degree, it will begin to heat up again. you may need a better cover, especially if it's cold outside. i would set it lower (like 100) and then when you know you are going to use it, turn it up and give it an hour or 2 to heat up...i used to have a timer on my old one and i loved that bc i had it set to heat up each night "just in case i wanted to use it"
Apr 13, 2014 | Great Lakes Spas Pool & Spa
Jacuzzi j210 heater
bad temp sensor replace
Feb 01, 2014 | Qca Spas Pool & Spa
SPA WILL NOT HEAT PAST 94 DEGREES. i HAVE IT SET TO 103 AND IT HAS NOT MOVED PAST 94 DEGREES FOR OVER 1 HOUR EXACTLY WHAT BUTTONS SHOULD BE LIT ? IN OTHER WORDS IS THE AIR BLOWER LIGHT SUPPOSED TO BE...
if hook up to the firemans switch turn heater all the way to 104 degrees if using 4 pin connector for aqua link to heater set spa temp to 104 and make sure on aqualink spa heat is enabled and 104 degrees
Nov 30, 2010 | Jandy Aqualink Rs4 One Touch Control...
We only use the heater for the spa. When we used it the other night, the water warmed up but didn't get hot. It said temp was 99 on the heater, but the thermometer in the spa said it was only 86. The...
Water temp sensor. Plugs into thermostat board and follow wires around to the main water header, there it should slide into the header. It will be a small tube connected to the wires. The new one will slide back into place, run wires back to the front of heater and plug back into board.
Jan 09, 2010 | Pentair MINIMAX NT TSI IGNITER
Minimax pool heater cuts out at 91 degrees when remotely set for
Turn the temp set knobs on the front of the heater all the way up do both pool & spa temp.
If that doesn't help flip the selector switch on the front of the heater the pool temp. This switch doesn't control what heats up Pool or spa it just selects the heater on and which thermistat to use
May 23, 2009 | Pentair Minimax Ch 400,000 Btu Propane...
QCA Opal hot tub display reading OH.
The tub experienced an overheat situation. This may be due to leaving the t stat turned all the way up and not monitoring or the hi-limit sensor is defective. The hi-limit sensor will shut down the heating cicuit if temp gets above 105 D optimally.the fact that the heater light is on is a good sign that things are working at this point.Whether or not a suitable temp(100-103 D) will be arrived at is to be seen. If spa heat kicks off before set temp is reached then replace hi-limit sensor.
Apr 10, 2009 | Qca Spas Jewel Series Topaz Plus Hot Tub
Pool & Spa Logo
41 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
