How do you record CD's from the speaker - Audio Players & Recorders
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 109 Answers
A computer or mp3 recording device with a microphone hooked to a cdr/ cdrw drive
Posted on Nov 06, 2014
I'm recording from CD to CD but when I FINALIZE it reads 'finalize incomplete' email address: mimaf@yahoo.com
The message in the manual implies there was vibration during the process. Isolate this unit form any air- or surface-borne vibrations and speakers while recording.
Mar 09, 2011 | Sony RCD-W500C 5-Disc CD Recorder
I expected that the RCA leads from my turntable would just plug into the back of the RCD-W500C, but the manual indicates a somewhat complex cabling arrangement through the amplifier. I have not been able...
Your new cd player/recorder is a "component piece" as is your turntable,cassette player, reel to reel or CD player. Connect it as you would any other component piece of stereo equipment. Set up your recorder to "record" in real time(not high speed or synch record). Your tape recorder records anything that is playing through your reciever to your speakers. So, treat your "CD" recorder as you would a "CASSETTE TAPE" recorder. Play your vinyl record on your turntable and record to CD on your CD recorder ! Pay special attention to the dubbing speed, you will not use "synch or high speed !! Good Luck
Feb 26, 2011 | Audio Players & Recorders
I have an old Pansonic RX-DT680, the model were the speakers detach. Can I record from tape to CD ?
The built in CD is just a player not a recorder and the unit does not have line level outputs to run to an external CD recorder so the answer is unfortunately "no". You could use the high level speaker outputs and "pad" down the outputs to line level using a pair of potentiometers, one for each the left and right channels, if you have any electronic wiring knowledge.
Nov 28, 2010 | Audio Players & Recorders
Tascam 788
The 788 can be used to play music from a SCSI attached CD-RW drive, but the record (and all other mixing functions) are disabled so you are not able to record the CD output onto a track using the SCSI attached drive.
Your options are:
1.) Rip tracks files from the CD onto you PC as wav files. You'll have rip (or later convert) those files to mono 16 or 24 bit wav files at 44.1kHz, use the old dos 8.3 naming convention for the filenames, and them burn them onto a CD-R or CD-RW as data files which can then be taken and imported into the 788.
2.) Play the CD through with an external CD player or stereo and route the output into an input on the 788. Assign the input to a track and record. Be careful to use a line level output, like an aux out (or try the CD player's outputs directly into the 788) if you are using a stereo. Avoid using a speaker output as the signal from a speaker output will be too strong and can damage the 788.
Hope this helps.
Cheers.
bd.
Oct 20, 2008 | Tascam 2488 Portastudio Multitrack...
Cdr200 recording
Your CD recorder has 2 sets of phono (rca) sockets on the back. You probably have the outputs connected to your amplifier & speakers. All you need to do is connect your tape deck (or any source except for a turntable) to the inputs sockets on the back of the CD deck.
You might need to switch to external or analogue recording on the recorder.
If you are going to be doing a lot of this type of recording & want it set up more permanently, it might make sense to reconfigure your hi-fi. Shout if you want help with this!
Jan 09, 2008 | Koss CDR200 2-Disc CD Recorder
Connect audio components for recording Cassette to CD
Try this since you do not supply model numbers. If your receiver and CD have digital audio connector (coaxil or fiber) hook the receiver output to the cd input.
If you do not, see if there is a spare set of RCA jacks for output. If not, just hook up the cd player in the cassette jacks-there is always a cassette in and out-and hook your cd player to an auxillary input or use the cd player input.
Remeber though, cassettes have inherently more noise than cd so your cds will not sound like a pre-packed cd.
Dec 22, 2007 | Sony SS-X90ED Main / Stereo Speaker
Post recording
maybe its the format of the material that is recorded on the disk. I.E. maybe MP3 when you should have used CD audio format or some such problem.
Jul 29, 2007 | TDK DA-3826 2-Disc CD Recorder
Speaker problem only when playing records
hi its not the system.... your recorder is set on left good luck
Jan 02, 2006 | Emerson Home Audio System with 5 CD...
46 people viewed this question
 Grubhead
Grubhead
