Question about Microwave Ovens
Bought Panasonic NN-S766 microwave in 1997. Been great. Has begun to run 2-4seconds, blows fuse. Also makes a louder(different) hum while running. All switches look good, magnatron magnets look good. Need some help.
    Problem Solver:
  • 5 Answers
With the prices of microwave's & since you've had it since '97 that's almost 18 yrs. don't you think you can put it out of it's misery & get a new one? Check Craig's list, the penny saver or yard sales, you'd be surprised how inexpensive they are now. I use to sell Panasonic when they first came out, so many yrs. ago,. I've always had great results with Panasonic microwaves.
Posted on Nov 09, 2014
MicrowaveSvc
  • 9047 Answers
SOURCE: NN-T990SA Panasonic Microwave Stopped Heating
This model uses an inverter to produce high voltage instead of a convential transformer system. While an inverter (switched-mode power supply) is more efficient from a power consumption standpoint, it is more complex, thus more statistically prone to fail. These should only be examined and worked on by someone who has the necessary technical qualifications. Seriously. Often the machine-soldered connections in a microwave inverter are too weak, so they eventually fail, especially if heat is high in the area. They sometimes fail catastrophically. When not catastrophically damaged, you may hear clicking or squealing and may smell an electrical odor, which is sometimes obscured by the cooling fan. Some manufacturers do not encourage or assist technicians to repair microwave inverters. Most offer the inverter as a whole assembly. But sometimes that is actually cheaper than the time and labor required to fix the old one. If a technician is willing and able to troubleshoot and repair the inverter to component level, it will may be expensive, but may be worth it, especially if he or she will resolder and reinforce connections as needed as part of a thorough repair. That could easily make your inverter beter than a new one! You might be able to get some verbal estimates if you call Panasonic-authorized repair shops and ask then specifically about inverter repair and inverter replacement costs for your model number.
Posted on Dec 23, 2006
jsrock516
  • 5911 Answers
SOURCE: Panasonic Microwave
The fuse is usually a 250V 15 or 20 AMP and can be found at any hardware store. As for those screws...those are special tamper proof screws made to keep the average consumer out of dangerous appliances. There's about 4000 volts inside a microwave oven when it is energized. That's why the manufacturers don't want the average Joe tampering with it. You can, however, buy the tool required to get inside the unit for a reasonable price. I think it's less than $30 and I know Craftsman makes it. The line fuse is located on or near the input line filter board. Just follow the input power cord and you will find it. Just keep in mind, that if the fuse is blown, it usually blows for a reason. You may have other problems. Let me know if this helps you.
Posted on Jun 23, 2007
ukvacfan
  • 328 Answers
SOURCE: Panasonic Inverter NN-V673S microwave- shuts off after 2-30 secs
If the screen is showing a fault number or a number you havent seen before then its probably a program fault which can't be fixed. Check that the vent holes on the back of the oven aren't dirty and ensure that the whole oven is clean inside. Sadly it sounds like a program fault which cant usually be fixed by the owner though.
Finding a Panasonic oven repairer in the UK shouldnt be a problem though. My parents had a simlar problem wth their Panasonic Inverter oven, called the UK customer services and Panasonic contacted an authorised repairer in Scotland to visit them. Call customer services on 0844 844 3868.
If the call out charge exceeds £80 then you're probably better off buying a new oven.
Posted on Apr 19, 2008
SOURCE: Ge jvm1650wb005
weve had our fixed before and it's the heating element $75-$100 to fix.
Posted on Sep 01, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Panasonic nn-p295 blows buss fuse when turned on for cooking
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer. But this is likely an inverter model, so it wouldn't have one and would be some other component in the inverter I'd say.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/xformer.html
http://www.gallawa.com/microtech/mag_test.html
The best place to order Sharp parts is Tritronics. Or you can call them toll-free at 866-779-5835.
Posted on Dec 26, 2008
My Panasonic NN-S533 1300 Watts,don't work.
HI,
Just visit this link HERE and your whole problem will be solved.
Refer the points 6.17,6.20,6.21,
Goodluck,
Please don't forget to rate the solution
Apr 03, 2008 | Panasonic NN-S561 Microwave Oven
Where is the high voltage capacitor at on panasonic microwave model nn-sn960s
behind the control panel,while your checking the h.v. cap check the h.v. diode for a shorted condition as this will also blow the 20 amp fuse too
Jan 06, 2013 | Panasonic NN-H275 Microwave Oven
I have a panasonic convection/microwave. Last night, after I cleaned it, using oven cleaner on a sponge, it made a loud humming noise after running on microwave for about 10 sec. It does not make the noise...
Since the unit makes the noise on Microwave but not convection it is a problem it he Microwave Circuit. Probably in either the rectifier of bad mag, one of them shorted. Just looked at the date you posted this, Im sure you have fixed or replaced this by now
May 31, 2017 | Panasonic NN-C980 Convection/Microwave...
Microwave fuse keeps blowing on my Panasonic Microwave NN-9854P
I would check the door interlock switches and then if that doesn't fix it replace the invertor board and possibly magnetron.
Feb 21, 2011 | Panasonic NN-P295SF Microwave Oven
Panasonic NN-P794SFR microwave unit that spins not rotating
there is a switch to turn it on or off. the turntable is replaceable
Feb 07, 2010 | Panasonic NN-P794SF Microwave Oven
Panasonic NN-T994SF Microwave Oven quits after 15 seconds
my microwave shuts off after a few seconds. is there a fuse that needs replacing?
Feb 01, 2010 | Panasonic NN-T994SF Microwave Oven
My 4yr old NN-S262SF OTR runs for 2secs and stops whenever start
Hello
Microwaves use alot of power and should be on their own 20amp circuit. Get an electrician to put the microwave on its own circuit.
John
Nov 25, 2009 | Panasonic NN-S262SF Microwave Oven
Fuse blows on microwave switch on
one of three things shorted could cause this: H.V. diode,capacitor,or the magnetron tube, take screw driver and short terminals on capacitor before touching anything inside the case, then chk resistance on capacitor should show infinite after needle settles, diode should show hi resistance one way and a lower resistance in the other direction(use the RX100 scale not the RX1) on both parts diode should not show very low resistance or it could be leaking,mag is a different story,it can be chk'd but in a different way
Jul 24, 2009 | Panasonic NN-H275 Microwave Oven
What cause the wattage difference?
Wattage is based upon voltage & current. I would think that on the 1300W unit, either the voltage or the current is higher than that which is used on the 1200W unit.
Perhaps the magnetron in the 1300W unit is being driven harder. Are the fans the same size?, The magnetron in the 1300W could be running harder and they have a larger fan in it.
In any event, if the part numbers are the same, you should have no trouble using one units parts to fix the other.
- Jim
Feb 17, 2008 | Panasonic NN-S561 Microwave Oven
Microwave Ovens Logo
50 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
