Question about 2000 Chevrolet Suburban 1500 Differential Gasket
How do i change bearings on front differential Suburban 2004 4WD
I want to solve the noise problem coming from the front of my Suburban myself. I hope it's only shaft bearing problem. What are my chances? Anyone able to give me some detailed information on this job?
    New Friend:
  • 48 Answers
Not so easy..those things have to be pressed on ..and off
Posted on Nov 09, 2014
Front end rotation noise
It should have been thoroughly checked. Noises like these on four wheel drives could several different things. A bearing, CV axle, or the differential, or bearings in the differential. A wheel bearing will make different sounds when making a turn. A CV axle is a constant sound. Differential bearings can come and go, depending on if it is a bearing for the axle or a pinion bearing. Axle side bearings usually make a constant noise. The differential can also come and go. Depends on acceleration or slowing down. All these sounds are also with a vibration. Slight to harsh.
Oct 26, 2014 | 2007 Jeep Patriot Sport
My 2003 chevy suburban has a loud popping in 4wheel drive in 2wheel it is agrinding noise it is how locking up
It sounds like the front differential bearings are gone. Remove the front driveshaft and see if the noise dissapates. Also, grab the driver side halfshaft by hand and see if it is sloppy where it enters the differential.
Mar 19, 2014 | Chevrolet Cars & Trucks
Wheel bearing
If grinding noise is heard coming from front side, lift up both the front wheels and rotate the wheels one by one to listen to the sound, if any. If a noise is heard, replace the front wheel bearings as a set.
If the front wheels do not produce any abnormal noise when rotated, lift down the front vehicle. Lock the front wheels with blocks, release the hand brake. lift up the rear wheels and try to listen to the abnormal noise. If the noise is heard, replace the differential bearings and seals. Top up the differential oil to the mark.
Dec 12, 2013 | 1998 Toyota Tacoma
Reason for humming noise even after changing wheel bearings of car
Depending on how the noise is affected by your driving, it could be an axle joint or the differential in the transaxle.
If it is coming from the back instead of the front you may still need hub bearings.
Sep 03, 2012 | 2005 Nissan Sentra 1.8
I have a noise coming from what sounds like the 4x4 drive axle in front. I have change the gear oil and still have the noise. Any recomendations.
I would check the wheel bearing/hub assemblies as I have replaced several of these. Usually they make a thrumming, rumbling, or growling type of noise that increases with speed and which may get louder or quieter when taking sharper curves at highway speeds. I"ve seen very few problems with the front differentials on these but have put in dozens of hub & bearing assemblies that are noisy or worn. Sometimes, but not always, if you raise the front tires off of the floor a few inches you can rock the top of the tire in & out a bit which can indicate a loose/worn hub but they can also make noise without having any looseness present so it isn't a perfect test. You may need to have the vehicle put up on a hoist where it can be more closely inspected. I have seen some pinion bearings go bad on the front differentials but it is fairly rare. Good luck, hope this helps out a bit.
Jul 07, 2010 | 2002 Chevrolet Suburban 2500
Clanging noise rear and rear don't pull
The axle probably lost a keeper ring on the inside of the differential and the pieces may be going through the differential and ring&pinion gearing making the noises you hear. You will need to drain the oil out, find the broken pieces, and inspect all gearing for broken/damaged teeth, and for any noisy bearings. Flush the case out with cleaning solvent. Re-insert the loose axle after cleaning and inspecting it well--especially the interior end. Replace the keeper (new) on the axle end inside the differential spider gearing. Inspect the brakes on the loose axle side for any oil deposits and for any damage that might have been caused when the axle came out. If the differential is badly damaged, it might be cheaper to find another rear end in a wrecking yard. Hope this helps!
Dec 26, 2009 | 1997 GMC Suburban
Moaning noise
has anyone checked the front drive shaft u joints, play in the differentials? differentials would come and go as you accelerated and let off.
Dec 17, 2009 | 1999 Chevrolet Blazer
2003 chevy suburban front axle noise
Worn side bearings is where the noise is coming from and might as well do both sides, I used replace them in about 2-4 hours, depending on where Murphy happened to be. Disconnect both side inner CV joint, front prop shaft and the 4X4 actuator line. If you want to drop the front pumpken. Not sure if you have enough room if you want to change the bearing without removing the pumpken from the frame. You should see when you disconnect the CV shaft.
The front diffs are toys compared to the rear, if you use auto4wd too much there are bearings in your tranfer case that are similar to the side bearings in the front diff. In both appearance and durability and soon you'll replace those too.
Good luck and keep me posted.
May 26, 2009 | 2003 Chevrolet Suburban 1500
2000 Chevrolet Suburban 1500 Differential Gasket Logo
46 people viewed this question
Top FelPro Vehicle Parts & Accessories Experts
rdjagger
squeely
pjorgo
Level 1 Expert
Are you a FelPro Vehicle Part and Accessory Expert? Answer questions, earn points and help others
