Question about Toys
Is there a wiring diagram for the Mr Christmas Lighthous with sea sounds? we purchased at a discount store didn't work. open bottom, has a 'black' wire broken off from somewhere?
There is a black wire that is broken off from somewhere. trying to locate a wiring diagram to figure out where it connects (appeared it was soldered in place once). Thank you.
  • 42 Answers
SOURCE: front light will not work
Before you go any farther stop. Unplug the refrigerator for the wall receptacle then look into the light socket (use a mirror if necessary), now see that contact point in the bottom of the socket? Raise that contact point to where it will ouch the bulb when you screw it back in. Now screw in the bulb plug in the refrigerator and open the door. Did I do OK ?
supertechks
Posted on Nov 23, 2007
SOURCE: Schematic and/or wiring diagram - Magnavox TV Mod 20ms233s
the problem in my tv is the sound no have
Posted on Jul 04, 2008
SOURCE: Creative Inspire 5.1 5200 Remote Wiring
mine goes from left to right with light up and headphone socket close to you
green
light green
black
yellow
white
red
black/grey
blue
i also have a problem with my speakers
the volume seems to get gradually softer until theres nothing. it happens all the time and i constantly must re adjust.
Posted on Jul 23, 2008
  • 489 Answers
SOURCE: LG Dishwasher LE error
When you repair the wires, be sure to wrap the wire harness is plastic like the type you would find in Safeway produce section.  This will keep the wire harness from getting melted on to the black insulation and creating this problem again.
  • 102 Answers
SOURCE: Headlight/turn signal problem
RELAY, NOISE SUPPRESION/is 1323592 its black and mounted under the hood on the shock tower, check page 4 and page 16 under LHB230FT in your book(item 464) ? why are you messing with this relay if you have a light problem ? does left turn signal stay on with key off /with parks only /with head lights /both front and back turns or front only? have you removed both frt and back bulbs together and ck voltage in sockets ?/wrong bulbs? i would need more info
Posted on Sep 02, 2008
How can I fix a mr. Christmas animated symphony of bells
Hello, Barbara -
Apparently there is more than one Mr. Christmas "Symphony of Bells" item.
I suggest you contact the Mr. Christmas company directly to find out about an authorized Mr. Christmas repair center. This is the link to the Contact Us page for the company:
http://www.mrchristmas.com/ContactUs.aspx
This is the link to the 2 pages of "Symphony of Bells" products the company has sold:
http://www.mrchristmas.com/Search.aspx?k=symphony%20of%20bells
Best wishes.
Mar 04, 2018 | Audio Players & Recorders
Tip
How to fix a Mr.Christmas Carousel swing and dis assembly
Mr.Christmas does not offer ANY tech support or dis-assembly diagrams. Once you purchase it, that's it. But......you can try this: The carousel consists of an outer roof which snaps around an inner roof (where the horse poles insert; there are four tabs that keep it attached to the outer roof). Outer roof removal; You need to carefully remove the "crown" (which is glued on) You may be able to use a blow drier on the hot setting to soften the glue,but not too hot to overheat any parts. Twist and pull gently and carefully remove the crown. Once the crown is removed, you'll should see a screw. Remove the screw to remove the outer roof.
Make notes of screws and parts from where they came from and where the components are located. Once the roof is removed, you should see the light circuit and connection pad. You will need to unsolder two wires from the wipers,taking care not to loose the springs.You can now unscrew the nut which holds the light contact bracket in place. Take care in removing this piece., then unscrew the contact board while pulling it over the central shaft. You should now be able to remove the inner roof, and you can lift up the main assembly.
You now are at the base and several screws holding the motor and central shaft to the plastic base. This will come free but will remain wired to the switches. This carousel is driven by a bunch of rubber bands,and If there is no rubber band connecting the shaft to the drive motor,than you have found the problem. If you find that the motor does not function or work, you can check the wiring that runs from the switch to the motor for a bad connection or break in the connection. To reassemble, just reverse the previous instructions. You may have to rotate the roof to allow it to fall into place, it should only go on one way.
on Feb 19, 2010 | Toys
What size bulb do i need for Mr.Christmas Holiday lighthouse?
I can not say for sure but normally these types of houses take the same bulb you would use in a night light. like a GE 120V 4W
Nov 25, 2013 | Gemmy Mr. Christmas Light Show and Sounds...
Digitai temp display dead fridge makes clicking noise
This sounds as if you have lost the low voltage side of the motherboard. You can look over the motherboard by unplugging refrigerator and pulling away from the wall. In photo Here=> PDS22MFSACC GE Cabinet Parts You can see item number 801 in the photo that is the motherboard location. Look it over closely back and front while power is disconnected. You may just see burn marks. The motherboard part number=> WR55X10942 where there is no photo and here where I have a photo=> WR55X10942 in right sidebar half way down that page.
Couple things really are important are the tech sheet and wiring diagram
Here
I know yours is a bottom freezer but clicking on the wiring diagram opens into a new tab GE Service Manual. You can follow with me on that if you would like to do
it yourself. Let me know, Thanks, Sea Breeze
Jan 17, 2011 | GE PDS22MFS Bottom Freezer Refrigerator
I need an ignition wiring diagram for an 1988 Dodge Van V8, please.
Haynes or Chilton Manuals available at most auto parts stores ($20-$30) for general wiring diagrams. Also go to alldatadiy.com for extensive information on wiring diagrams for your vehicle ($20-$30) for 12-months which is renewable at a discount rate.
Nov 13, 2009 | 1988 Dodge Caravan
Wiring Diagram for a 73 ford F-100
If you wish you could purchase the Haynes Manual for your vehicle ( available in Autoparts Stores ). You could also but it online. There are certain Online Vendors where you could get the same at discounted price. Most Ford Service departments also have them, but it may take a little extra effort to get someone there to share them.
You could also tell, me if you want to have a Wiring Diagram for a certain component like Break Mechanism or Engine Mechanism. I could tr to search that for you.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 23, 2009 | 1997 Lincoln Continental
I need diagram of timing belt pullys
You will find the timing gear alignment for belt installation in a Haynes or Chilton manual for that year that can be viewed or purchased at a discount parts store like Kragen,Checker,Autozone,Pep Boys,etc.
Oct 16, 2009 | 1999 Ford Escort
Mr. Heater Buddy Portable Problems...
ok, your unit must be propane. look on the back where the propane line feeds the nozzle. there should be a very small copper line with two spade connectors on it. this is your millivolt generator line. with a flame at the nozzle the generator makes a very small electrical current which feeds to the main valve and keeps it open. take a piece of wire and jumper these two spade connections together and try lighting the unit again. if it stays on, the hi limit is shot. you can get by with the connections jumped out, you just don't have the safety margin if it were connected. IF with the spade connections jumped out the unit still shuts off, the generator tube needs to be changed.
Dec 25, 2007 | Mr. Heater Mr Heater Portable Buddy...
Toys Logo
559 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
