Question about Health & Beauty
What should be the output voltage be from the controller on a pride victory scooter?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 87 Answers
It depends on the position of the speed pot and throttle pot. At maximum setting, total battery voltage less 1 volt.
Posted on Nov 06, 2014
  • 118 Answers
SOURCE: Pride victory mobility scooter
A fully charged battery should be over 12 volts. You may need to change your batteries.
Posted on Nov 27, 2008
  • 118 Answers
1. Remove the four screws on the outside perimeter of the console base.
2. Lift off console top cover and disconnect the front-to-back cable.
3. Remove the throttle lever from the throttle pot.
Remove the four screws holding the console base to the mounting plate.
SOURCE: pride victory Scooter battery charged won't run
Its probably too late to give my opinion, but here goes anyway.
I had a similar problem with my mothers scooter and it turned out to be a faulty connection on the wires leading to the motor. I simply pulled the plastic connection apart, cleaned and lubricated the contacts, refitted the connection and all was well.
Posted on May 13, 2009
  • 175 Answers
SOURCE: I have a pride victory xl8. Problem - was running
All scooters have a protection system built in to prevent burning up the motor, and the user, should the scooter overheat. It sounds like yours overheated. If the temp. outside was warm to hot, and your weight is near the weight limit for the scooter, and you are taxing the motors over a hill, or unstable terrain, then the scooter goes into "limp home mode", or just enough to get you a bit aways, and then it will turn off. After a few minutes to cool off, it will go again, but shut down fairly quickly because it takes a spell to let the whole transaxle-motor assembly to get cool.
Check your weight, and anything else you may be carrying with you on the scooter. Check the terrain, and incline you are going against. Throttle down for all these occassions. If you overloaded the system at some point, then you may have overheated the brushes. Remove them (2) with a standard screwdriver and see if the copper coil is still flexible and springy. If not, replace it/them.
The damage may already be done, so it may need a new motor/transaxle assembly. An expensive proposition I'm afraid.
Posted on Jul 09, 2009
  • 175 Answers
SOURCE: I have no manual for my Pride victory mobility scooter
http://www.pridemobility.com/pdf/owners_manuals/US_Scooter/US_Victory_10_om.pdf
Click on this link and a pdf manual for a Victory 10 will appear.
Posted on Aug 28, 2009
Controller flashes 9 times what does that mean
Basic Troubleshooting Instructions - Pride Mobility Products
www.pridemobility.com > Resource Center
Pride MobilityINFINFB2468 Jazzy 614/Jazzy 614HD with Dynamic Controller Troubleshooting ... LiftChairs. INFINFB2061 Basic Troubleshooting Instructions: Lift Chairs ...
Pride Mobility Products Corp. - Product Owners Manuals ...
Pride MobilityHelp Me Choose · Where to Buy · Request to Be Contacted · View all Models. Pride Mobility Scooters ... Power Chair Consumer Safety Guide .... Version / Date. Flash. C 01/04. Pride LX Series. C 05/08. Z-11. B 07/04. Manual Wheelchair ... Travel Scooter Throttle Control Lever Operation Product Insert ... Victory 9/Victory 10 ...
Troubleshooting / Repairs Mobility Scooter, Power ...
Dec 03, 2015 | Pride Mobility Pride TSS300 Power Chair -...
Scooter is saying error code 8 which is motor does anyone know what this could be please?
Pride Mobility Products Victory 9 Scooter 4 Wheel Error code
www.fixya.com > ... > Pride Mobility Products Victory 9 Scooter 4 Wheel
Pride Mobility Products Victory 9 Scooter 4 Wheel, error code related issues. ... Question about Thermometer Mobility Scooters ... error code is 8 Error code 8 means an internal controller error or problem and requires replacement of the controller. ... Theysay there is no listing for code 9 I have replaced the batteries,checked .
Basic Troubleshooting Instructions - Pride Mobility Productswww.pridemobility.com > Resource CenterPride MobilityScooters. INFINFB2040 Sonic Troubleshooting ... Chargers. INFINFB2586 Charger Indicator Codes ... Disclosure Statement Pursuant to Cal. Civ. Code 1714.43(a)[PDF]Legend Owner's Manual - Pride Mobility Products
Nov 28, 2015 | Pride Health & Beauty
What should the output voltage be from the controller on a pride victory scooter?
Try searching up said scooter voltage on google and check lots of forums
Nov 06, 2014 | Pride Health & Beauty
Pride controller
It depends on how much voltage your batteries are currently carrying. You can check the voltage of both batteries by placing positive needle of multimeter on breaker and negative on negative terminal of battery. If the batteries are good it will typically read 26.02 or close to it. If the batteries are reading closer to 24v, the batteries are more than likely bad. AGM Batteries are more than likely bad when the volt meter reads 12.06 or below. Place battery under load, if it drops more than 2v, replace batteries (both Batteries).
Assuming the batteries are fine; place the multimeter on the output of the controller unit (white connector) and see if the voltage matches.
Aug 26, 2014 | Pride Mobility Controller Assembly for...
What does the 7 beep code mean on my Pride Victory 10 scooter mean when I turn the key on ?
This is a speed pot or throttle control problem (wig-wag) have you had some speed issues with the scooter before this happened, if so the wig-wag needs replacing. Make sure it is in the centre position at rest and switch the scooter on again.
Jul 11, 2014 | Pride Mobility Products Pride Victory 10 -...
Pride mobility victory XL front tyre wear
Is your track rod bent or out of alignment? Carefully buy the exact wheels with tyres and a track rod if necessary from dismantled Victory XL scooters (a good wheel with a good tyre about €30 - I've done that for my Pride Celebrity XL8 - it was a great success.
Jun 03, 2014 | Pride New Mobility Victory XL 4 Wheel...
Scooter only moves a short distance, then stops?
If the scooter in question is a Pride Victory with on board charger ? ( you plug a mains lead into it ?) now what happens with this particular scooter as the charger starts to fail, it's not charging the battery correctly, if you have access to a multimeter DC setting , check the voltage from one of terminal of the battery to the other terminal of the opposite battery, now it should read at least 18 volts , 0 volts then you need to change from one terminal to the other and same for the other battery ,, now if it below 24v that's the problem because as soon as you put it under load the voltage drops to under the minimum working voltage for the controller , hope that makes sense so other-words you need to replace the on board charger , contact me and I show you a way to do this cheaply...
Regards
www.gewizrepairs.co.uk?fixya
May 31, 2013 | Pride Victory 4 Wheel Mid-Size Electric...
Pride Victory scooter repair manual
Piggies might fly = Pride don't want you to go anywhere near one.
Apr 10, 2013 | Pride Mobility Victory 3 Wheel Electric...
Health & Beauty Logo
93 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
