Question about Cell Phones
<!-- from fixya rte -->Disable the intelligent sensor - Cell Phones
    Problem Solver:
  • 5 Answers
I don't believe you can. Try apples iPhone support or call them.
~Ian~
Posted on Nov 06, 2014
What makes a 2001 chevy impala backfire
Timing issue , mass air flow sensor , vacuum leaks , crank , cam sensor etc.... without test and just replacing part wouldn't be very intelligent . Your best bet would be to take your vehicle to a qualified repair technicians.
Jan 26, 2017 | 2001 Chevrolet Impala
Tip
Pentair Intelliflo Pump Alarms and Continual re-Priming
Many pool owners seem to experience the situation with the Intelliflo Variable Flo (model numbers have changed over the past 3 years) pump alarming and re-priming continually and then stopping. I had this problem for nearly two years and spoke to the actual pump designer. We ultimately solved it as there was a spring valve in the heat pump I have. Any type of spring valve (or similar item) is a problem for the intelliflo as the pump is tooooo intelligent. When the spring opens and closes with water flow (or depending on what it was designed to do) it makes the pump think that there is a blockage and it reacts by shutting off and creating an alarm.
The solution is to replace the spring valves (or item that is varying the flow in the system) in your pool circuit. I was able to create a work around that used a manual valve just before the spring valve to reduce the flow so that the spring would not move and thus impact the pump. Basically you need to be ascertain if there are any parts in your pool flow that alter the water flow and thus pressure at any time (ie such as a spring valve) as the intelligence of the pump will take that to be an irregularity and shutdown. This can be time consuming and I hope this helps.
Note: you can test the pump to confirm that it is the intelligence that is causing the fault by putting the pump into FULL manual mode - consult the manual as merely pushing the manual switch does NOT disable the fault protection and system intelligence.
on Aug 07, 2010 | Pentair IntelliFlo VS-3050 & VS+SVRS...
Tip
System problem if Hangs at Startup
Instruction applicable for all Window XP system,
For Any Brand and Model PC, whether it is of DELL/HP or any brand ..
Applicable to Desktop PC as well as LAPTOP
If your system hangs about 5 or 10 minutes at Startup/Bootup
And if you can't access the Start button or the Taskbar, most oftenly one of the specific service (Background Intelligent Transfer) running in the background.
Microsoft generally gives a patch for this but usually not work for in most of the cases
So please try this method, it is almost easy with no harm to PC.
  1. Click on Start
  2. Open the Run window,
  3. Type msconfig, then click 'OK'.
  4. Go to the Services tab, find the 'Background Intelligent Transfer' service.
  5. Disable it, apply the changes & reboot.
Next time you reboot the PC it will show System Configuration Utility window, place a Tick Mark in check box and then OK. SO that it would not appear again.
Also one more thing you can do Go to MSCONFIG and in the Startup Tab
Disable the items which you think not necessary to come during startup.
THis will help you lot to reduce the time being taken in Startup.
Hope it will work for you.
With Best wishes Ellin Scott
on Oct 12, 2008 | Compaq Presario 5000 PC Desktop
Intelligent Sensor
Make sure intelligent sensor is turned off, by pushing green button on remote untill you are on the right choice "off". also make sure picture setting is on "standard" not cinema, expert or any other setting These buttons are sometimes near the power button and easily pushed by mistake.
Feb 16, 2014 | LG Televison & Video
How to change the sensor on the LG DLE1310W
Moisture sensor? Why would you need to replace that? Is it tearing your clothes up?
Feb 08, 2013 | LG DLE1310W Electric Dryer, White, Super...
My note book starts too much slowly and mostly stucks it takes about 2 or 3 min to the starting window screen and 2 min in the welcome screen. kindly tell me the solution
It might be due to Virus.So please use a anti-virus software and try scanning the virus
To my knowledge , if you have just updated , you should be OK , MS say they have have fixed all their faulty patches .
Did you download all the security fixes ?
Here are some other things to try .
http://www.techspot.com/tweaks/winxp...rvices-3.shtml
http://www.techspot.com/tweaks/winxp...es/index.shtml
http://www.techspot.com/tweaks/wfp/index.shtml
If your system hangs about 2 or 3 minutes at startup, where you can't access the Start button or the Taskbar, it may be due to one specific service (Background Intelligent Transfer) running in the background. Microsoft put out a patch for this but it didn't work for me. Here's what you do:
Click on Start, Control Panel, Administrative Tools then Services.
Go to the 'Services' tab, find the 'Background Intelligent Transfer' service.
Or if you don't want to disable it .
Background Intelligent Transfer Service. Uses idle network bandwidth to transfer data. For the majority of Users this feature should be of little use & as such I'd recommend setting it to Manual. Those on highly active Networks may benefit from having this set to Automatic, although it may be worth testing out to see if it does.
http://rogier.xszone.nl/windows/wintricks.html
• Defragment boot files
The boot defragment option is usually enabled by default, but it may be disabled, or not properly enabled. If it's not working, XP may boot dog-slow.
To enable it:
- Edit HKLM\Software\Microsoft\Dfrg\BootOptimizeFunction, find the string called Enable. If the string value is set to N, change it to Y.
http://support.microsoft.com/?kbid=308041
Resources for Troubleshooting Startup Problems in Windows XPmag-glass_10x10.gif
http://www.blkviper.com/WinXP/servicecfg.htm
http://www.blkviper.com/WinXP/servic...#Network%20DDE
Enable Quick post in BIOS setup , as long as you have a have a lot of memory .
The normal memory test , is tested three times & that alone may take 60 to 90 seconds.
http://www.windows-help.net/WindowsXP/troub-07.html
http://www.tweak3d.net/tweak/winstartupnew/
Disable the Windows XP Prefetcher
Windows XP has a Prefetcher component, which shortens the amount of time it takes to start
Windows and programs. When trouble shooting either Windows or program start-up issues, it might
be helpful to disable the prefetcher, because it runs as a background service while other
applications are running or loading.
To disable the prefetcher:
Start the Registry Editor
Go to HKEY_LOCAL_MACHINE \ SYSTEM \ CurrentControlSet \ Control \ SessionManager \ Memory Management \ PrefetchParameters
Double-click the EnablePrefetcher value (remember the value that EnablePrefetcher is set to!)
Change the Value data to 0 to disable the prefetcher .
Close the registry editor and reboot the computer for the changes to take effect
When done troubleshooting, you can re-enable the prefetcher by changing the Value data to its
original value.
Values for EnablePrefetcher are:
0 - no prefetch
1 - prefetch applications only
2 - prefetch boot only
3 - prefetch both applications & boot (default)
I find 5 is best .
THANKS......
WITH REGARDS........
VAISHU
Sep 26, 2010 | Dell Inspiron Mini 10 Notebook
Ontelligent eye not working
  • Has the I.S. (Intelligent Sensor) ever worked?
  • Did someone make changes in the Picture Menu and now the I.S. is not working?
Sometimes the changes the IS makes are so small you cannot notice, but the I.S. is working.
LG’s “Intelligent Sensor” uses 4,096 sensing steps to evaluate its surroundings. Using a
sophisticated algorithm, the LG processes picture quality elements including brightness, contrast, color,
sharpness and white balance. The result is a picture optimized for its surroundings, more pleasing to
watch and which can also save up to 50% in power consumption.
1. You can go into the Menu, Picture Menu, and then Advanced. From there you can fine tune all the picture settings.
2. You can also try a Picture Reset. Inside the Picture Menu, you can perform a Picture Reset. The Picture Reset returns the “selected picture mode” back to the default factory setting.
3. If all the above fails then the problems are between the Main board (process the picture parameters) and the Intelligent Sensor (is reporting the surroundings to the main board). Either one of these issues will require new parts.
Good Luck.
May 20, 2010 | LG 42PX5D 42 in. Plasma HDTV
I have a problem about quickly on start-up
Try these: start-run- then type msconfig, ok, go to the services tab, find background intelligence transfer service and it, REBOOT. get rid of fancy screensavers, right click my computer,properties, performance settings, do away with some special effects disable hibernation, control panel, power options, hibernate, uncheck the box... Try these and let me know if they are any good.
Aug 05, 2009 | Microsoft Windows XP Professional
How to disable passenger airbag on outlander
Those equipped with intelligent passenger airbags disable automatically based on weight and position on the seat. There is no manual override.
Jul 17, 2009 | Motorola Mobility Q9h Car Charger /...
PQI 2G Intelligent Stick
First double check the stick for a tab with a picture of a lock on it, if that is there then switch it to the other position, if your drive lacks the switch then connect the drive. Go to my computer, right click the drive, click properties and search the taps for write protection and disable it(im sorry but i forget what tap it is under) hope that will help you out some but let me know if neither of those help
Dec 10, 2007 | PQI 512MB Intelligent Stick USB 2.0 Flash...
Cell Phones Logo
22 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
