Question about PLOOM Pax Vaporizer
<!-- from fixya rte -->How do i get my stuck mouthpiece to open - PLOOM Pax Vaporizer
My Jean Baptiste trumpet's mouthpiece is stuck and
Take it to a music shop and get them to pull it out, they usually do it for free
Sep 03, 2013 | Cell Phones
When calls come through I can hear them but they can't hear me
this is because the mouthpiece of your phone is defective. its either the mouthpiece is fault and needs replacement or there is dust on the mic hole, blocking it from function.
Use a phone screw driver to open up the phone, clean the mouthpiece hole, use a tiny pin to through dirt or dust that may be blocking the mouthpiece hole. couple the phone back ans try again.
If the problem still persists, then it means you will have to change the mouthpiece entirely. Go to any phone part accessories shop/store within your vicinity, buy a new mouth piece for your phone model, do the replacement and your phone should be perfect again.
Also, before you change the mouthpiece, you still have an option of using a hands-free (earphone) to receive and make calls till you replace the phone's mouthpiece. The hands-free hands-free (earphone) has it own mic/mouthpiece so its definitely going to work.
I hope the above solves your problem. Let me know is you still need further assistance or clarification and I will be glad to respond or reply back to you.
Good luck........
Mar 23, 2011 | Cell Phones
I cant hear people and they cant hear me and my ear pieace volume keeps showing up instead of my master volume lg vx5500
Good luck.
Mar 09, 2011 | LG VX5500 Cell Phone
Caller cannot hear me, but I can hear them. I have a Nokia 6110 cell
Good luck.
Feb 25, 2011 | Cell Phones
Hei.is possible keep out the nichel on te mouthpiece millenium?this is too loud...thank
There are many factors in the design of a saxophone mouthpiece that determine if they are loud or not. In my opinion the least of which is the plating material. The tip opening, lay, facing and bore have a lot more to do with it. The hardness and cut of the reed you are using is also important. Have a look at this site for a more complete explanation:http://www.theowanne.com/. When shopping for a mouthpiece, take your saxophone with you to a store with a good selection of mouthpieces and try them one by one.
Dec 17, 2010 | Otto Link "millennium Edition" Tenor Sax...
The person on the other end cannot hear me. i hav to scream at them for them to hear me like thers no mic
Good Luck
Aug 12, 2010 | LG enV VX9900 Cellular Phone
When i call people i can hear them but they cant hear me
Best regards.
Aug 05, 2010 | Cell Phones
How do you assemble a clarinet , i have a clarinet and cant assemble the mouth piece
First you need to have the barrel inserted in the top joint of the clarinet. It is the cylinder with no keys. I recommend putting the reed on the mouthpiece before you insert the end of the mouthpiece in the barrel. Some cork grease (a small amount rubbed on the cork will help it slide in easier. If it is too loose you will need it to be recorked but you might get away with wrapping a strip of paper over the cork as a temporary fix. The reed should be on the bottom looking down the clarinet when it is assembled. Make sure you have a reed that is the correct strength for you. A 2 is a good starter. looking at the squarish hole that the reed covers slide the ligature(looks kind of like a hose clamp, is metal with usually two screws to tighten) over the mothpiece with the screws on the hole side. Wet the reed with your saliva and then gently and carefully slide the reed under the ligature so it rests on the flat surface of the mouthpiece with the thinnest end facing the tip or end that goes in your mouth ( not the cork end). Gently tighten the ligature screws down so it holds the reed firmly in place with the tip of the reed just matching the tip of the mouthpiece. Slide the mouthpiece cap over the reed and assembled mouthpiece to protect the reed while inserting the mouthpiece in the barrel. Grasp the mouthpiece in your left hand with your thumb poiting at the reed end of the mouthpiece. Grasp the barrel with your right hand and the thumb pointing at the end you will insert the mouthpiece. Gently start the corked end of the mouthpiece into the open end of the barrel. Using a twisting motion with your left hand push the mouthpiece into the barrel until it is completely seated with a very thin crack showing i9n the joint where the mouthpiece and barrel meet. Assembled properly the reed should rest on your bottom lip when the clarinet is in playing position.Here is a link with more help:http://www.wikihow.com/Assemble-a-Clarinet Notice the ligature is different than I described as there are different designs. It doesn't really matter if the screws are on top or bottom. It is a matter of preference. Hope this helps. If the mouthpiece will not slide in at all it is the wrong one for your clarinet and you will have to take at least the barrel to a good musical instrument store to match a new one.
Apr 02, 2010 | Akai Ewi4000s Electronic Wind Instrument
Whenever i'm trying to call, the person on the other line couldnt hear me if im using my lg prada.. i can hear them but they couldnt hear me, please help
Hello
The mouthpiece of your phone has either moved position or is no longer working.
To know what the problem is, open your phone and look at the part you normally speak through in the phone,you will see the mouthpiece move the mouthpiece so it is parallel to the mouthpiece hole of your phone.
Close the phone,put it on and try making a call to see if it is working
If it isn't then you should get a repairer to change the mouthpiece for you because it is faulty
But as a temporary solution you should get a headphone to use to make your calls
Thank you for visiting fixya
Mar 07, 2010 | LG Prada KE850 Cellular Phone
How do u put on the mouth piece and make a sound?
If you are talking about a single reed instrument such as a saxophone this is how you proceed. First you have to moisten the reed using water or your own saliva. You can do this by placing it in your mouth and rubbing both sides of it with your tongue. Take particular care not to damage the tip of the reed. Take the mouthpiece in one hand and lay the reed on the flat part of the mouthpiece with the thinnest part of the reed towards the tip of the mouthpiece flatside down. The tip of the mouthpiece is the opposite end of the mouthpiece from the one that you put on the instrument. You can't mistake the two. The end that goes on the instrument is like the opening of a tube. With the reed laying flat on the mouthpiece gently slide the ligature ( clamp with one or two screws ) over the end of the mouthpiece and the reed. Take care once more not to damage the end of the reed. Line the very tip of the reed up with the very tip of the mouthpiece leaving a sliver of the mouthpiece showing. Holding the reed in position move the ligature along the reed and mouthpiece so that it is covering the bark part of the cane reed about 1/8 to 1/4 inches from where the bare part of the reed starts. Some mouthpieces have a guide line marked on them. Once the ligature is positioned you can tighten the screws. Do not overtighten them. They just need to be snug enough to secure the reed in position. The reed should be in the position I described in order to speak or vibrate easily. Now you can slightly fold your bottom lip over your bottom teeth and insert the mouthpiece and reed into your mouth. Your top lip should not be folded over your top teeth. Your top teeth should rest on the top of the mouthpiece and your bottom lip should provide a cushion between your bottom teeth and the reed. You should have as much pressure applied between your top and bottom teeth so that someone cannot easily pull the mouthpiece out of your mouth. You will learn how much pressure to apply to affect intonation and produce a good sound with practice. Now with the mouthpiece in your mouth you can blow through it to produce a sound. Your mouth should provide an airtight seal around the mouthpiece if you followed my directions. You can steady the mouthpiece with your hand while try to get a sound. If all you produce is a sqwawk that shouldn't discourage you. What you are trying to do is make a piece of wood vibrate in a controlled manner using breath pressure and your jaw muscles to control the vibration. Do not use too much pressure or the reed will be clamped shut at the tip and not be able to vibrate. You should have at least an inch between your bottom lip and the ligature as to how much mouthpiece should be in your mouth. Once you can consistently make a sound then you can proceed to putting the mouthpiece on the gooseneck with the gooseneck properly installed in the saxophone. You should rub a little cork grease on the cork of the gooseneck before putting the mouthpiece on it. The distance that the mouthpiece goes on determines the tuning. Your lip pressure also affects the tuning but a lot less in comparison. You can vary your lip pressure rhythmically to produce vibrato. Most sax players now hardly use vibrato or use a slow shallow controlled vibrato on notes at the end of phrases. Another thing to note is that to start with you should use about a number 2 reed unless your mouth is particularly sensitive and then I wouldn't go anything less than a 1 1/2 for a little while until you get used to the vibrating sensation and the feeling of your bottom lip between the reed and your bottom teeth. Hope this helps. By the way I have been playing since 1963 and I hope you enjoy it as much as I have.
Aug 24, 2009 | Rico Tenor Sax Reeds Box of 10
PLOOM Pax Vaporizer Logo
137 people viewed this question
Top PLOOM Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a PLOOM Health and Beauty Expert? Answer questions, earn points and help others
