Question about Chevrolet 2002 Chevrolet Silverado 1500 Base
2002 chevy truck v6 not getting gas why has new fuel pump new inline filter and new relay
Put all new parts and it ran good for a day now its doing same thing it was doing before not getting gas
    Master:
  • Chevrolet Master
  • 401 Answers
Sounds like a bad connection to fuel pump. Check your actually pressure at the fuel rail itself. Also take fuel cap off and listen to see if you hear the fuel pump working. Its possible to get a bad pump.
Posted on Jan 12, 2015
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 109 Answers
Check your fuel pressure regulator, when they go bad you get 0 pressure. Also check you connections and grounds
Posted on Nov 06, 2014
Ran out of gas, car wouldn't crank replaced fuel pump, fuel relay, and in line fuel filter and still won't crank on 2002 chevy avalanche
still won't crank ? how's your battery ? starter ? starter solonoid ? if your engine does'nt crank , its dead ! would'nt you check the battery first ? then move on with checking the starter circuit ? seems like your putting the cart before the horse ! first of all, when you run out of gas, you need to replace the FUEL FILTER, your engine just sucked the dirt, garbage, etc., out of the tank. there's plenty of sediment in the tank, don't know how it gets there, but, you'd be surprized ! talking threw experience !!! I operate heavy equipment, its a cardinal sin to run out of fuel !!! you say you replaced the inline filter, which one, up by the engine or the main filter, under vehicle along frame ? are we talking about the same animal, PLEASE CLARIFY !
Mar 14, 2013 | 2002 Chevrolet Avalanche
How do i revtieve the trouble codes for a 2002 chevy astro van
loosen fuel lines at throttle body when turning key to on possion , careful not to spill gas all over engine, do you hear fuel pump running and try to put at least 4-5 gallions of fuel, you could try a (LITTLE ) shot of starting fluid ?good luck hope this helps.
Sep 30, 2012 | Cars & Trucks
The fuel pump was not engaging so we replaced it.
the fuel pump doesnt set off the check light recheck the connections at the fuel pump check for power to the connector also check the pump new doesnt mean not defective
Jan 15, 2010 | 2002 Chevrolet Blazer
1995 Chevy K1500 4.3L V6. Engine has inconsistant idle
Have you changed the fuel pump yet?I had the same exact problem.I replaced my fuel pump with an AUTOZONE PIECE OF JUNK fuel pump.That pump lasted almost 2 days.The second day i had it the truck didnt want to start but it did and it ran like ****,and when i put it in gear it ran as long as I didnt touch that gas pedal.You could go get a fuel pressure test or just replace it,your call.You might want to check your filter too but im sure its the pump.Good luck
Apr 13, 2009 | 1997 Chevrolet K1500
HELP! HELP! SOMEONE PLEASE ! 2001 chevy blazer fuel problems
I would check to be on the safe side the fuel filter is going in the right direction. The arrow is pointing towards the engine away from the fuel tank, Then you need to make sure the fuel pump wiring connections are good contact and did not come loose when driving.
Mar 18, 2009 | 2001 Chevrolet Blazer
Looking for the fuel pump relay in a 1994 chevy camaro 3.4 v6.. cant find it anywhere! do you know where it is located?
1994 Chevy Camaro 3.4L V6
Fuel Pump Relay Location
Behind LH Dash Mat 41860098 Location:
The fuel pump relay is attached foot rest bracket under carpet, forward of left kick panel
Hey My Fellow Member of the Auto DIY World & World I Hope this Brings smiles and A solution to your Problem as it is My Goal and Mission to Help you .. EASY now rejakwilson
Jan 14, 2009 | 1997 Chevrolet Camaro
1990 Chevy Corsica 3.1L V6- Ran out of gas- Relay, fuel pump?
Unfortunatly on GM vehicles when the fuel pumps run dry they usually damage themselves. The problem you are describing sounds like a bad fuel pump. When you turn the key to the run position you should hear the pump come on for 5 seconds and then shut off. It should be a medium pitch whine but sound smooth. Unfortunatly on GM vehicles the tanks must be removed to change pumps and depending on the climate you are in could show other problems. Here in Michigan on vehicles of that age they will usually need new tanks and sending units due to rust. I get around $500 to replace a fuel pump. Of course the price goes up with the more that is needed replaced. Hope this helps
Dec 09, 2008 | 1995 Chevrolet Corsica
1997 chevy pick up no fuel pressuer
SOUNDS LIKE A CLOGGED FUEL FILTER. MAY HAVE INLINE FILTER, OR ITS IN TANK. TANK MAY NEED TO BE CLEANED IF IT IS THE FILTER, RUST BUILD UP FROM WATER IN GAS WILL RUST INSIDE OF TANK AS IT SEPERATES FROM GAS AND SITS AT THE BOTTOM.
Oct 28, 2008 | Electrical Supplies
Chevrolet 2002 Chevrolet Silverado 1500 Base Logo
91 people viewed this question
Top Chevrolet Audio Players & Recorders Experts
D. E. Hev
Lawrence Oravetz
Are you a Chevrolet Audio Player and Recorder Expert? Answer questions, earn points and help others
