Question about Hama M2140 Bluetooth Mouse - Black
<!-- from fixya rte -->What is the default passkey for this mouse? - Hama M2140 Bluetooth Mouse - Black
Need microsoft mouse bluetooth 5000 passkey
The official documentation says:
If you are prompted for a passkey, enter "0000" (for added security), or choose no passkey. This mouse will not work with any other passkey.
Oct 14, 2010 | Microsoft Bluetooth 5000 Mouse
What is the pairng code for mouse 5000 ?
  1. Windows XP
  2. Click Start, and then click Run.
  3. Copy and then paste (or type) the following command in the Open box, and then press ENTER: services.msc
  4. Double-click the Bluetooth Support service.
  5. If the Bluetooth Support service is stopped, click Start.
  6. On the Startup type list, click Automatic.
  7. Click the Log On tab.
  8. Click Local System account.
  9. Click OK.
  10. If you prompted to restart the computer, click Yes.
How to connect the Bluetooth device to the computer loadTOCNode(3, 'moreinformation');
  1. Press and hold the Connect button on the bottom of the mouse. If your device has a battery indication light, it will blink and alternate between red and green to indicate that the device is discoverable.
  2. On the computer, open the Bluetooth software. The Bluetooth software is typically located in Control Panel. For more information about opening the Bluetooth software, see the "How to open the Bluetooth software" section.
  3. Click the Devices tab, and then click Add.
  4. Follow the instructions that appear on the screen.
    A Microsoft Bluetooth mouse does not require a passkey to connect to the computer. If you are prompted for a passkey, select No passkey. If you do not get the No Passkey option, try to enter 0000 as a passkey by using your keyboard.
Apr 20, 2010 | Microsoft Bluetooth 5000 Mouse
Have a dell studio 1555 with bluetooth configured into the system. Have tried sinking a Palm phone using 0000 and 1234 as passkeys when requested to provide one , but neither passkeys have worked. Are...
I would recommend calling the manufcturer and explaining the issue. They should be able to reset the passkey for you and give you a default one.
Nov 08, 2009 | Dell Studio 15 Laptop
Need a passkey for samsung omnia
hi, default passkey is 0000. Enter this passkey in the asus notebook when it asks for passkey.
Both the passkey should be same to enable file transfer through bluetooth.
Sep 19, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
GOT ONE OF THESE WITH NO DOCUMENTATION AND NEED THE DEFAULT PASSKEY TO USE IT. HELP!
That mouse doesnt require a passkey. Select no passkey while setting up. For more info
http://support.microsoft.com/kb/952818
Jun 13, 2009 | Microsoft Bluetooth 5000 Mouse
Blue tooth connection passkey
Most Bluetooth devices uses '1234' or '0000' as the default passkey. Since you tried using '0000', you may wanna try using 1234.
Have a great day!
May 22, 2009 | RIM BlackBerry Storm 9530 Smartphone
Dell wireless keyboard and mouse will not work
Normal 0 Go to Control Panel and click on Sound.
Next click Bluetooth Devices.
Click Add button, lower left corner of the Bluetooth Devices window.
Insure batteries are installed.
Press the Connect Button on the Keyboard (Usually located on the under side of your keyboard) this allows Windows to see the keyboard so you can pair the keyboard to the computer.
On the computer choose My Device Is Set Up and Ready To Be Found.
Click NEXT.
The keyboard should appear in the Add Bluetooth Device Wizard Window.
Select your Keyboard and click Next.
When prompted, select Choose a Passkey For Me and click Next.
Windows will generate and display a Passkey.
Type the Passkey specified on the Bluetooth Keyboard
(do not use the keyboards keypad when typing the passkey)
No charters will appear on the monitor when typed, but if you make a mistake, you can backspace.
You must enter the Passkey within 30 seconds.
If you don’t enter the Passkey within 30 seconds, click Back and click Next again.
Once the Passkey is entered, the Keyboard should be connected to the computer.
Finish and follow any on screen instructiond.
Hope this helps. Bud
Dec 15, 2008 | Dell Wireless Keyboard Optical Mouse w0147
LOGITECH BLUETOOTH MOUSE
Click NEXT.
Dec 01, 2007 | Logitech 931249-0403 Mouse
Hama M2140 Bluetooth Mouse - Black Logo
51 people viewed this question
Top Hama Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Hama Radio Communication Expert? Answer questions, earn points and help others
