Question about GE Dryers
What grease to put on idler pulley?
Hello. I have a GE profile prodigy dryer. I changed part for idler pulley but what grease do I put on the the metal bar. Lithium or Silcone? Confused on what to look for and what max temperature the grease should withstand.
  • GE Master
  • 744 Answers
Hello Gausia;
My name is Peter. I am a retired field service appliance technician.
Dryers are subject to lint and dust. They are not like your automobile engine where you need to lubricate bearings and
belts.
Dryers only have sleeve bearings not ball bearings.
Lubricating these sleeve bearings or belt will collect the dirt & lint.
Do not grease at all.
Posted on Nov 07, 2014
The belt on dryer sweeks
its probably not the belt,rather the idler tensioner pulley that keeps the drum belt taught to turn the drum,replace both as long as you have to tear it down anyway part numbers are belt AP4324040 / tensioner idler pulley AP2043227 available from appliance parts pros 1-877-477-7278
Apr 02, 2011 | GE Profile DPSR475EW Dryer
How come when i changed the belt there is so much play on the new belt im not sure if i have the idler tensioner on right ?
That could be the problem look at how the belt is running thru the tensioner and the shaft of the motor. Then run the belt the opposite way if still the same you might have the wrong belt. Get the model number off the dryer and take new belt back to parts house with model number to make sure its right hope this helps.
Jan 07, 2011 | GE Profile Prodigy DPSR513GA Dryer
Dryer makes a squeeking noise
more than likely the belt pulleys or the drum bearings.
Apr 27, 2010 | GE Profile Prodigy DPSR513GA Dryer
How do you take the front panel off of a GE Profile Prodigy Dryer DPSR483 GAWW? There is a squeeking noise inside.
Best off to call a reliable service company such as Sears. You have to remove the top and take 2 screws off that hold the front panel on but this is a gas appliance which requires a gas technician to legally work on it.
Feb 01, 2010 | GE Profile Prodigy DPSR513GA Dryer
My GE Profile Dryer is still operating but produces loud intermitent noise as the drum rotates. What can I do to eliminate the noise?
It sounds like you may have a bad bearing in the back of the drum. That model rotates on a sort of ball and socket type mechanism. You may be able to lubricate it if the noise is just squealing/squeaking. If it is more than that, you'll probably need to replace the bearing mechanism. If you lube it, use a heavy weight lube that is rated for high heat (I've used brake caliper grease.)
Jan 03, 2010 | GE Profile Prodigy DPSR513GA Dryer
Drum turns but makes a banging and metal grinding sound
The felt bearing on the front of the drum is worn out. Immediately stop running the dryer, and replace the plastic drum inserts and put in a new felt bearing before machine damage happens (if it hasn't already). While there, grease the rear bearing and the idler pulley bearing. Check the belt too. Good luck.
Nov 28, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryer belt replacement
put belt around drum then around motor pulley, then pull or push idler pulley so as to put belt over this pulley and release,this will tighten the belt,then manually hand rotate drum to self-align belt on pulleys and drum and put covers back on
Sep 04, 2009 | GE Profile Wizard DPSE592EAWW Electric...
Need a btlt route so i can put the new drum back in my ge profile
route the belt around the drum, pull the spring loaded idler pulley to the postion that requires you to hold it there..
put the belt : 1 through the motor pulley and around the idler pulley, or 2. around the idler pulley which ever works to keep the tensioner tight. (Idler pulley, tensioner same thing its the pulley not on the motor.
Once you put the belt on the durm, pull the idler pull so there is tension on it it should be clear how it goes.
Doc
Feb 08, 2009 | GE Profile Harmony DPGT750EC Electric...
HELP GREASE RUINING CLOTHES IN WASHER
over 5 years or cost over 250?
 throw it away, and get a Whirlpool
Oct 21, 2007 | GE Profile Prodigy WPSE4200A
Dryers Logo
64 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Sal DeAngelo
Are you a GE Dryer Expert? Answer questions, earn points and help others
