When I turn tv off and turn back on I get no sound. But if I change inputs and switch them back it works. Is this fixable??
  • 1,680 Answers
Reflash the rom or factory reset,
Posted on Dec 18, 2014
3 Suggested Answers
SOURCE: I have my satallite on hdmi input 1 and my x-box
I have the exact same problem/symptom. I suspect this is a very common problem only folks just now discovering it as we buy new hdmi devices. I called technical support and got the "sorry, out of warranty" talk. Mr Badge #74754 claimed that this was not a known problem. Would love to hear if others having this problem.
Posted on Mar 07, 2010
  • 905 Answers
SOURCE: Hello, My electricity went out while my tv was
The power supply is probably faulty and should be repairable by a TV repair engineer.
Posted on May 16, 2011
Testimonial: "Thank you so much! I really appreciate your help :)"
I turn on the tv and i get a blue screen for 5 seconds and the tv shuts off. Any ideas?
This is normal on vizios, ours does it too. You have it switched onto RGB input. You need to change input after it comes on. Switch on and keep pressing change input button till it changes and then it will be fine. Alternatively plug in a computer on Rgb and then turn on, you will be able to change input normally.
Sep 29, 2012 | Vizio GV42L 42 in. LCD Television
Black screen- fixable?
probably a faulty internal PSU, changing the capacitors on the on-board PCB should fix it but hard to tell without opening it up and testing.
Apr 26, 2012 | Hannspree XV32 32 in. LCD Television
Tv won't switch to "tv"
Your T.V. is programmed to store the last input you've selected. You have to manually switch it back to your T.V. channel input after each time you switch it to HDMI or any other input even when you turn it off. The "Source" or "Input" button on your original T.V. remote will change this.
Jun 24, 2011 | Vizio 42 in. LCD TV
Techwood 42in tv model 42832 hd digtal it turned itself of,cant get no picture,but blue stand by switch still turns on and off
It sounds like your TV's display has been routed to a different INPUT than the Cable/TV input jack, like a VCR in put or an RCA input. You need to change the input back to TV from VCR or LINE1 or RCA, so on. How to do this without the original remote, you are going to have to look up the program code for the universal remote and program that remote correctly, once done, change the TV Input until you're back on cable.
Mar 29, 2011 | Televison & Video
Sound but no picture
Start by eliminating the variables. Connect a source that you know is working (e.g. a VCR or DVR that is working on another TV) to your TV. If you get the same result, connect it to a different input and, if possible, different input type. If you still get the same result, your TV is bad. Most standard TVs are not worth fixing since it costs almost as much to fix them as to purchase a new one.
If changing the input fixes the problem, the TV has a bad input and you can just switch to a new input.
If changing the source fixes the problem, your source is bad and needs to be repaired or replaced.
Be sure to use cables that you know to be good by testing them on another source/TV system.
If changing the cables fixes the problem, then replace the cables.
Dec 05, 2009 | Cell Phones
Sony Bravia KDL-52WL140. We went to bed with working TV and woke up to vertical lines on entire screen with every input. My husband has disconnected all inputs and cables to check for any noise or...
it is fixable, but it depands on the cost, compared to buying a new 1..the problem is with the vertical deflection board....if can get it hope it will work..other options are, reservice the whole unit ..
Oct 20, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Can not change "Device" input, no sound control,no remote control
I unplugged the manual switch electrical connection. Everything works just fine with the remote.
Not sure what is wrong with the switches just yet, but suspect a resistor problem. I have checked all voltages and have 5.04 v feeding the switch assembly on what I feel are the correct circuits
(5v, ksco, ksc1, man/reset). I have no voltage on the ground circuit with the board plugged in, so the ground circuit should be ok. I have tested all switches with ohmmeter, all switches work. I suspect a resistor problem as I have one with no voltage drop and one resistor with no voltage pass-thru. Would need a wiring schematic with values to pinpoint better.
May 16, 2009 | Mitsubishi WS-65711 65" Rear Projection...
Sharp tv changing channels
Well, the only thing that seems to be working so far is to plug AV cables into the "input 2" ports (on the front of TV). I plugged in my PS2, without turning it on. It has not switched at random since (about 30 minutes - it had been switching off and on for the past 2 hours). Anyone else have similar success?
Oct 28, 2006 | Sharp 32F540 32" TV
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
