Question about GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket
I am finding the soap dispenser is full of water when I begin a new load of clothes. Where is it coming from? What should I do about it? I have a GE Profile Harmony.
When doing several loads of laundry in a row, the soap dispenser is full of water from the previous load. I have been pulling the dispenser out and dumping the water but this shouldn't be happening should it?
    Problem Solver:
  • 18 Answers
Check that your machine is level or set according to the manual.
If it is tilted forwards the water cannot run out of the dispenser under gravity, which is how it empties.
Posted on Nov 06, 2014
VtToolMan
  • 704 Answers
SOURCE: GE Profile Harmony Washer has loud squeak when filling
Based on your description, it sounds like the water inlet valve is making noise, since you hear a squeaking noise during the filling of the washer. If it sounds like a constant squeak or squealing noise, i'd say it's caused by either the water inlet valve not being pulled all the way open, or because the water supply shut off valve at the house end isn't open all the way. Try opening the water supply shut off valves all the way open, (check to see that they are).
What is interesting is that the squeaking comes back during the draining of the water. Is this while the tub is spinning or only at the very end of the cycle? Again, it could be the water inlet valve, since the washer will "spray" some fresh water into the washer during the final spin cycle to help remove any soap residue, etc.
The part ins't cheap at around $123.00 for this valve, so unless it's really annoying you to no end, I'd wait for the valve to stop working before getting the repair done, unless you want to do the repair yourself, which isn't difficult, with some basic tools and time.
If you wait and let this go until it fails, you'll notice the water in the tub might not fill all the way for the level set, or the valve will start getting even more as it gets worse.
Here's a drawing that shows your washer and the part I'm talking about.
pd_0026_363_wh13x10017?$pddetailsth$ Part #WH13X10017 $123.49 @ searspartsdirect.com
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=WPGT9360E0PL&productCategoryId=0153200&brandId=0432&modelName=WASHER&diagramPageId=00001&componentDescription=CONTROLS,%20BACKSPLASH%20&%20TOP%20PANEL&documentId=G0901083&backToLink=Return%20to%20Sub%20Components%20list
Hope you find this Very Helpful and best regards!
Posted on Aug 22, 2009
  • 1294 Answers
SOURCE: Amana Front Load Washer Soap Dispenser
I suggest you use soap powder for 'front loading washing machines'. The cartons at the market have them specially marked.
Posted on May 09, 2008
  • 3600 Answers
SOURCE: Brand new GE Profile leaves clothes soaking wet
It is under warrenty call the store where you bought it and have them look at it. If you mess with it it will void your warrenty, belt may not be working or transmisson may not be shifting. The house call will be at no charge.
Posted on Sep 10, 2009
Testimonial: "thankyou for the help, I thought I had just made a bad buy. They sent someone out right away and it turns out this particular machine had a bad part."
ginko
  • 19396 Answers
SOURCE: Intermittent water on floor
Check the inlet valve hoses, even if inlet is at the back, the water may drip down and flow on the front part on the machine. There you also have the PUMP, a faulty pump may leak intermittently.
Here you get all diagrams and parts for your appliance.
Posted on Sep 25, 2009
SOURCE: GE top load Super Capacity 16 cycle washer (one year old)
We have a GE WJRR4170 washer, with the same problem. At first I thought I might have to unscrew the entire control panel just to replace the knob. However, replacing it turns out to be easy.
Right behind the knob, holding it in place, is a nylon/plastic retainer clip. If you pull out the knob (into the "start" position), you can use a flathead screwdriver to push the clip out. The knob then will slide easily off the metal stem. A GE replacement knob costs $9 or $10, depending on the source.
Shame on GE, but the knob is designed terribly. The part of it that engages the dial has eight, flimsy plastic teeth. At any time, four of these are supposed to engage four little slots in the dial. However, the way the knob is designed, there will be a lot of wear and tear on these plastic teeth, so they'll wear out on every single machine.
Good luck to the many people who will have this problem!
Posted on Nov 04, 2009
My washer is flooding water out of the soap dispenser and not going into the tub where the clothes are
Washing machines, whether top load or front load types, have a tendency to build up back pressure through the soap dispenser if the pipe/chute is clogged due to soap build-up being present. Check that the pipe/chute that conveys the soap and water to the drum is not clogged.
Aug 23, 2015 | LG Washing Machines
What does de mean on the display of the washing machine? Yesterday I ran a tub clean because my clothes have been smelling moldy. I have cleaned the rubber seal & leave the door open. Please help??
de means your door isn't closed completely.
The moldy smell is really common with this machine, and maybe all of them, but I have the LG TROMM and was ready to throw away all of my towels. Here's a solution I found that helped alot. First, Clorox makes a solution just for front-end loading machines. You run it through on a cycle with no clothes, that helps to clean it out.
I ran my towels through on the cotton/towel cycle on HOT, with nothing more than white vinegar filling the detergent dispenser. After that, I then ran them through again with just a bit of soap and fabric softener. They came out soft and smelling like new.
I read recently that we all use WAY too much soap in both our washers and dishwashers, even though that's what's recommended in the directions. Excess soap in clothes that doesn't get rinsed out will begin to smell moldy. So I now use about 1/4 of what the directions call for, and they come out fine. I have found, however, that I need to repeat the vinegar cycle once every few months. I think the problem is inherent in that model machine.
And that rubber seal? Disgusting! I clean it out regularly, but when it's full of water after every load of clothes, what do they think is going to happen??? You'll find that Clorox cycle will clean the seal pretty well, though. Good luck!
Apr 03, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Soap-not residue-still on clothes
Wow that's a strange one.
Are you pouring the soap into the tub onto the clothes or using a soap dispenser? If using a dispenser, it may be malfunctioning, try pouring soap directly into the tub under the waterfall while it is filling.
When the machine is agitating are the clothes on top being drawn under the water? Usually this occurs as a rolling motion from the edge of the tub towards the agitator. If the top layer of clothes have an air bubble trapped in them they may not be submerging into the water. Any soap on top may not be dissolved.
Finally, if you are pouring soap into the tub, make sure you are not spilling any onto the inside of the lid or in the softener dispenser. It could get trapped in the lip around the edge of the lid and be spilling onto the clothes when you open the lid at the end of the cycle.
Do you have the same problem if you use powder soap?
Nov 12, 2009 | Washing Machines
Leaks from soap dispenser
I don't have a front load, but it sound like a gasket has come loose. Is it for liquid dispensing? Are your clothes comming out clean? If you get inside of the washer and see where the dispenser attaches to the outside drum, my guess is it is either broken and you need to buy a new part or however it is attached has come loose. Not knowing the inside drawing of this washer, my suggestion is to find a mechanical schematic of the machine and go to the root of the problem,the dispenser itself. I am pretty sure it has just loosened up, whether it is a press fit or mechanically attached by screws to it. good luck.
Oct 24, 2009 | Frigidaire ATF6000ES Front Load Washer
Whirlpool Duet GHW9100L pours water out of the soap dispenser dra
probable cause is there is an article of clothing that is stuck between the outer and inner tubs, in the area where the dispenser water and detergent enter the machine. you can run your hand around the rubber boot and you might be able to remove the article, it will be in the upper left part of the machine. if nothing can be found than you have a plugged up dispenser hose.
Jan 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
GE Top Load Washing Machine -- Agitator will not cycle
Agitator's don't spin on wash cycle.
I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
Jan 26, 2009 | GE WBSR3140DW Top Load Washer
Suds residue left on clothes just washed
ck drain hose end of drain hose should be at least 36 ins from floor also be sure drain hose fits loosely in drain water may be siphoning out resulting low water level to wash/rinse ..also recommend using liquid detergent dry doesn't dissolve good in cold water and even though it may be recommended for front load the lower water levels used may not be enough to dissolve it properly
Nov 27, 2008 | Washing Machines
Spin cycle not working
try the door switch the washer will do everything but spin if the door switch is faulty
Jul 13, 2008 | GE Profile WPSR3120WWW
Where's the soap going?
Clean the dispenser water hose ,stuck by liquid dried soup./ the hose going to washer was open during washing time so all soap loaded was gone /
During water refill if nothing water pass to soap dispenser the soap will remain intact / but in washing time all soap will directly washout dispose to drain hose without to clean clothes.
Jan 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Soap door latch won't latch close
Make sure the dial that you turn to start the dishwasher is all the way to the beginning. Sometimes my little grandson comes by and plays with it, turning it. I load, add soap and the dispenser won't close. I check the outside dial, and sure enough, set it to the very beginning and the dispenser locks in place!
Nov 04, 2007 | GE Nautilus 24" Built-in Dishwasher
GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
