Question about Refrigerators
Need new filter
Need to replace filter. where do I get it?
    Novelist:
  • 167 Answers
Appliance stores and home centers carry most filters. Be prepared for sticker shock -- many of them are over $40 each.
Posted on Nov 06, 2014
I know this is a bump question With my talon chainsaw 42cc 45cm how do I give it a tune up coz its running rough
That's not a bumb question. So let me help you out.
First find a local dealer and go purchase a new air filter, fuel filter, spark plug, and depending on age new fuel line.
Remove the top cover this is where you will replace your air filter.
drian the fuel in the tank.
Get a long pair of needle nose pliers to reach in side the tank and pull out the fule filter, at this point if you are replacing the fule line you can pull that line out and dis connect it from the tank housing. If not just remove filter from line replace with new filter and reinsert back in tank.
Next using a socket remove spark plug and replace with new.
Add new clean fule and test run. If you equipment still is not running correctly it may need a few adjustments or possibly the carberator will need to be cleaned. If so let me know and I can walk you through those steps as well.
Thanks.
Aug 16, 2016 | Garden
What could cause the engine not to stay running after the fuel filter was replaced? Even after fuel pump was replaced?
From remote site, it is hard to tell what is the root cause, and change pump was done in proper order -- you should post the problem before replacing fuel pump.
Here is what I will do, assume you can do a little by yourself.
Changing fuel filter should be easy by disconnect fuel hose (pipe) from the fuel filter . Since ASE mechanic did job in your house, I assume the old fuel filter is still in your hand. Change it back (replace new filter with your older one) to see if your car will work as before. This supposed to be done before replacing the fuel pump.
If older filter works, then you knew the new filter is the root cause. This could be resolved by replacing another new filter. If the problem appear again, leave the new filter in for over night to see if the new filter will work on the next day (you could use exiting new filter to avoid buying another filter, unless you will get a different brand one). If not, the choice is to use older one for a while when trying figure why new filter does not work.
If old filter does not wok either, then something is in forwarding fuel line between fuel filter and fuel ejection system. Then, that section needs to be cleaned. Assume the pressure is measured at connection between forwarding line and fuel filter.
Oct 05, 2014 | GMC Sonoma Cars & Trucks
What causes a pool pump motor to overheat
Blocked or clogged water input line
Sucking air from a leak, not enough water thru system
Excessive debris in strainer baskets
Filter needs to be backwashed
Filter needs new sand or new cartridge
Filter needs to be taken apart and "fingers" cleaned
Filter Pump Impeller is obstructed
Filter motor is in-correctly wired
Filter motor bushings need replacement
Filter motor bearings are worn
Filter motor is "shot"
Apr 16, 2013 | Emerson Pool & Spa
94 silverado 1500 5.7 runs then dies like if the ignition key was turned off new fuel pump new fuel filter new pump relay new plugs
Check air filter and housing to see if airflow is obstructed.
Check Throttle positioning sensor, replace as needed.
Check plug wires, replace as needed.
Jan 21, 2013 | 1988 Chevrolet Silverado 2500
Fuel pump needs to be replaces on 2000 Chevrolet suburban, do I also need a new filter, relay and induction?
Do you know for sure that the fuel pump failed or do you have a bad relay? If the fuel pump relay is good no you don't need to replace it. The fuel pump unit comes with the sending unit and a sock filter. I would replace the inline fuel filter when you replace the pump. In line fuel filters need to be replaced every 36000 miles. If that filter starts to plug up it makes the pump work harder which leads to premature failure.
Jan 17, 2011 | 2000 Chevrolet Suburban
Need to replace fuel filter. Have the filter just need to know the proper way to remove old and replace new and do i need a special tool?
You shouldn't need a tool. I do believe that on escort it just has those goofy clips that hold the lines to the filter. The filter should come with new clips if you break them when you remove them.
Dec 02, 2010 | 1995 Ford Escort
What is required for the 30,000 maintenance
#1) Oil and Filter Change.
#2) Transmission Filter & Gasket Also Transmission Flush and new transmission fluid.
#4) Complete Brake Inspection Replace if Needed. Also Flush out Brake System with new Fluid.
#5) Inspect Front End for Worn Parts, Check for Alignment--Inspect Tires .Replace if Nessary otherwise Rotate.
#6) Check Wheel Bearings Front and Rear.or Struts -Shocks-
#7) Check and Flush out Power Steering Fluid. with new Fluid. Change power steering filter if Equiped.
#8) Inspect. ignition System, Replace all replaceable Parts. Or only the Damaged.
#9) Replace wiper Blades w/New
#10) Replace PCV Valve--Air Filters-Fuel Filter-Replace any Breather Elements and Check Vacum Lines for Cracks .Replace if Needed
#11) Inspect Radiator and Heater Hoses .Replace.
#12) Inspect Battery Condition, Check Battery Cables for Corrosion -Replace if needed.
#13) Remove and replace Spark Plugs.Cap & Rotor.
#14) Replace Spark Plug Wires,
#15) Check all Lights ,replace Bad lights.Interior and Exterior.
#16) Check Rear End/Diferrential if Equipted.Change out Oil (90) Wt.
#17) Replace Drive Belt (Serpitine) or Drive Bels.
This is what i recommend to reduce Uneccessary Break Downs,And Yhis is A Excellent Preventive Maintence.
By running through this list and replacing the neccesary parts. will also save in Future Everything gets more Expensive as the Days Pass.
Hope i've given what you needed.Please let me Know by Voting for the Quality of My Solutions and a Testamony would be Greatly Appreciated.
Thanks From ==d_hubbs
Oct 05, 2010 | 2007 Chevrolet Avalanche LTZ
Reset change filter light
Push the button in, that you will see, when you open your refrigerator door, hold it for about 10 sec. then let it go, it will turn green, If the light comes on, an says you need a new filter. That is not always true. do the same thing befor buying a new filter, to make sure you need a new filter.
Jul 03, 2010 | Maytag MSD2758GEB Side by Side...
Where is the water filter on a 1997 side by side Roper
Do you have a manual for the refrigerator to check he same
Sep 08, 2008 | Roper RS22AQXKQ Side by Side Refrigerator
Refrigerators Logo
32 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
