Question about Universal Rapoo H6060 Bluetooth 2.1EDR Wireless Stereo Headset Headphone with Microphone - Black
My headset isnt being detected by any of my devices
Music player through my bluetooth
Hi Mike Cronk,
I see that you have a Bluetooth Headset and that you are tryingto connect it to your BB.
You mentioned it will not play or you cannot hear Audio From it from your BB?
Did the Bluetooth Headset sync to your BB? you need to make sure that the headset is sync properly on your BB and that the BB is dectecting your Bluetooth Headset. make sure that the BB is also set to be detected by any device for the Bluetooth to detect your BB as well for proper syncing of both devices.
try your Bluetooth headset on another devices as well see if it will sync to a different device just to see if the Bluetooth headset is working fine.
I hope this helps,
michaelvincentc
Dec 25, 2011 | Jabra BT2080 Bluetooth Headset
I am using a Koss CS-100 Headset, and i only have one 3.5mm plug on my laptop so im using a splitter on it, and my laptop wont detect it, and even when i just plug one into the 3.5mm plug it still wont...
Windows isn't directing sound to the headset plug. This can be changed under control panel sound.
Sometimes it will asign itself if you turn on the computer with the headset already plugged in.
Also check the settings under all programs --- accessories -- entertainment -- volume control
and make sure the volume isnt too low or muted for the device.
May 16, 2011 | Koss CS-100 Headset
I cannot pair my nokia e63 with genius bt-03i. seems the phone can't sense the signal from the headset or either the headset is not transmitting bluetooth signal
Make sure the blue-tooth headset is charged
Make sure the phone is set to automatically detect new blue-tooth device.
On the headset, press the power key for five seconds until the RED light blinks quickly.
Phone should detect headset within 10 - 30 seconds. It should eventually say BT-03A then ask for aOnce it does, type 0000 into the phone when it asked for a device ID.
May 05, 2011 | Genius BT-03A Bluetooth Headset
Bluetooth connection
Ensure that your phone is switched
on and the headset is switched off.
2. Press and hold the power key until
the green indicator light starts to
flash quickly.
3. Activate the Bluetooth feature on
the phone, and set the phone to
search for Bluetooth devices.
4. Select the headset from the list
Feb 09, 2010 | Nokia BH-208 Wireless Headset
Activating the buetooth function.
You have to "pair" your bluetooth device with your phone. This is just a fancy way of saying "sync" with each other. Check your bluetooth headset instructions on how to do this.
I am using a Motorola H700 Bluetooth Headset. To "pair" it with my phone I have to hold down the call button on the actual bluetooth headset itself while the headset is turned off. This puts the headset in "pairing" mode so its ready to detect any phone that wants to sync with it.
Then I have to go to my actual LG CU400 and enable bluetooth settings. Next, go to "Device List" settings and select "new". The phone will scan for the headset. Once the phone detects the headset it will request a numercial passcode. Your bluetooth headset instructions should list this passcode. Enter the passcode and the phone and headset are now connected! I hope this helps. Good Luck!
Jan 05, 2009 | LG CU400 Cellular Phone
Cannot pair Nokia N70 to Jabra BT150 bluetooth headset
turn on cell phone. activate bluetooth. press right button to search for bluetooth devices. Then press the on button and the volume UP button at the same time on the Jabra headset. The cell phone then finds the device. put in the password/pin (usually 0000). and voila! it works
Dec 07, 2008 | Jabra BT150 Wireless Headset
Unable to Detect the Jabra BT125 headset from any Bluetooth Device
If you hold down the button, it will turn the light blue, keep holding it till you can connect it. It will come up as Jabra BT125, hit connect. Then it will ask for a password. The password is 0000. Then it will connect :)
Feb 21, 2008 | Jabra BT125 Headset
Nokia 6102i will not detect my BH-600
Hey I found the solution :
1. When the headset is off, press and hold the multifunction key until the indicator light is continuously displayed.
2. Switch on your compatible phone.
3. Activate the Bluetooth feature on the phone, and set the phone to search for Bluetooth devices.
4. Select the headset from the list of
found devices.
5. Enter the passcode 0000 to pair and connect the headset to your phone.
In some phones you may need to make the connection separately after pairing. You only need to pair the headset with your phone once.
If the pairing is successful, the indicator light starts to flash slowly, and the headset appears in the phone menu where you can view the currently paired Bluetooth devices.
The headset is now ready for use.
Enjoy..
Pavan
Jan 27, 2008 | Nokia BH-600 Wireless Headset
Logitech USB headset no sound
Have you tried changing the Audio Device that windows is using?
Under the Sound and Audio Devices in the ontrol Panel. Under the Audio tab, try the Default Device under Sound playback. Change this to the headphones.
Oct 22, 2007 | Logitech 250 Headset
Universal Rapoo H6060 Bluetooth 2.1EDR Wireless Stereo Headset Headphone with Microphone - Black Logo
57 people viewed this question
Top Universal Radio Communications Experts
eradiostore
eradiostore
L Pfaff
L Pfaff
Mario van Limburg
Mario van Limburg
Are you an Universal Radio Communication Expert? Answer questions, earn points and help others
